Browse Forums Building A New House Re: Recessed sliding door is flushed to internal floor slab 3Jun 23, 2017 10:36 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Recessed sliding door is flushed to internal floor slab 7Nov 06, 2019 8:59 pm Did you ever get a reply on this??? Can anyone tell me if the builder is responsible for ensuring when the door is recessed into the slab to account for the floor inside? Builder has recessed the door but the door is pretty much touching the concrete. Slides fine without flooring but as soon as I want to put the tiles in, it won’t fit. The builder is claiming I need to cut the door so that the tiles fit under the sliding door? Re: Recessed sliding door is flushed to internal floor slab 9Nov 07, 2019 12:59 pm I thought we had the same issue. They simply trim the bottom of the door upright frame things and it was fine Hope this is the same for you Re: Recessed sliding door is flushed to internal floor slab 10Nov 07, 2019 3:50 pm You are correct. It's just the fins on the sliding door that get trimmed. Ultimately you should not be able to see the edges of the tile. For the OP the tiler will need to install a tile edge along the door so there's a neat edge. It's not ideal but not the end of the world. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Hi Stuey, think you’ve got a couple of options here you’d just need to decide your preference/which options suits best. You could recess the windows (just keep in… 1 3210 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 12165 |
