Browse Forums Building A New House 1 Jun 20, 2017 3:09 pm Hi everyone and hoping to get some advice from all the clever people here. I've recently purchased a small corner plot in Melbourne with a rather dilapidated single storey dwelling on it, and planning to knock it down and rebuild. The plot is fairly small, at 22.7m long x 15.2m wide. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The current setback is 9.5m at the front and 1.9m at the side. The property is in a GRZ2 residential growth zone, with no particular requirments, so I'll have to follow the standards A3 and B6. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is the situation of the neighbouring properties around my house (my one is the one in pink) and setbacks have been rounded to nearest whole number. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I've approached several of the volume builders (Carlisle, Metricon, etc) and they all tell me that they don't have anything that would fit onto a plot that size. I'm wondering what my options are?. My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Re: Help with my plot setbacks 2Jun 20, 2017 3:18 pm So the building envelope I gave to the builders looked like this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ There's quite a deep front setback of around 8m (same as my neighbour), and a 2m side setback. But I've noticed my other neighbour has a 3m setback, so can I turn my plot around so that the "front" of the house faces the side, and therefore I only need a 3m setback on that side, and then my front of the house becomes the side with a 2m setback? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ None of the builders I've approached have mentioned this to me, so I wonder if that's possible? My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Re: Help with my plot setbacks 3Jun 20, 2017 4:32 pm That's what I thought when I looked at it, use your current side as the front, which would give 3m setback for the front, and then 2m on the side (what is currently the front). You could see what they have in a ranch style home, these are generally a lot wider than they are deep (most of the project builders should be able to rotate one of their designs and put the entry on the longer side Re: Help with my plot setbacks 4Jun 20, 2017 4:54 pm Thanks for your comments joanna. But what constitutes the front of the house? Are there regulations concerning that? So if I turn the plot around and go for one of the typical long front to back house plans, the garage and front door will face the side setback and the side door to laundry will face the front. Are there any issues with that? For example, does the front of the house need to have a front door? Or is it an arbitary designation only? My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Help with my plot setbacks 5Jun 20, 2017 5:06 pm ben888 But what constitutes the front of the house? Are there regulations concerning that? So if I turn the plot around and go for one of the typical long front to back house plans, the garage and front door will face the side setback and the side door to laundry will face the front. Are there any issues with that? For example, does the front of the house need to have a front door? Or is it an arbitary designation only? These are questions for your Council. Make an appointment to go and speak with them before you potentially get some wrong information set in your mind from here. With respect to which house to build, you might consider a building designer or designing it yourself and having a draftsman draw it up for you. It may seem daunting at first, but you'll be surprised how quickly you learn and rise to the occasion. Re: Help with my plot setbacks 6Jun 20, 2017 6:20 pm Thanks for the advice. Yes, I'll certainly pop down to see the duty building officer later this week to discuss. Whilst I would love to design the house fully with a draftsman, I know that custom builds do generally cost considerably more than volume builds. My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Re: Help with my plot setbacks 7Jun 30, 2017 7:52 am ben888 Thanks for the advice. Yes, I'll certainly pop down to see the duty building officer later this week to discuss. Whilst I would love to design the house fully with a draftsman, I know that custom builds do generally cost considerably more than volume builds. How did you go with the council? All I know is side setback regulations are different to front. You can apply to have a reduced minimum setback but need the plans to apply. If you haven't yet definitely talk to council directly, not sure where you are but city of Kingston you can go in and chat with someone easily. Don't know if this applies but regulations for setbacks for subdivided blocks are different, so you can't use subdivided blocks as an example of others who have built forward. You can use other houses in your street. I've just put our application in to reduce our front setback by 1.4m, I'll let you know how I go. Thanks for the insight! My plot is a new development so hopefully I won't have too much problem during build as everyone should be roughly building together. I also… 2 3381 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15782 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6936 |
