Browse Forums Building A New House Re: Which rendering company Metricon uses? 2Jun 10, 2017 7:47 am yhfg27 Can anyone let me know which rendering company Metricon uses? Tried to contact Site Supervisor and he did not answer the phone for many days. They use a lot of hebel for that look. Try contacting head office 1300446637 Re: Which rendering company Metricon uses? 3Jun 12, 2017 10:27 am There wouldn't be a specific company they they use, it's all subbies depending on the area of work hence why you need to discuss with the supervisor. Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4889 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7414 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5228 |
