HenleyNeil
Thank you, very good option
Hi Sumit,
May I please know what sort of Heating is included with Henley i.e. Bravis or other brand.
How much is zoning of Heating costs, if you have gone with zoning option.
Thank you.
Regards,
Neil
Browse Forums Building A New House Re: Emporio 43 with henley 41Feb 19, 2018 10:10 pm HenleyNeil Thank you, very good option Hi Sumit, May I please know what sort of Heating is included with Henley i.e. Bravis or other brand. How much is zoning of Heating costs, if you have gone with zoning option. Thank you. Regards, Neil Re: Emporio 43 with henley 42Feb 21, 2018 8:28 am Hi Neil Bravis heating is included but added 3 zone panel for $2200 Re: Emporio 43 with henley 43Feb 21, 2018 7:35 pm Thank you Sumit, You have been very helpful. Regards, Neil Re: Emporio 43 with henley 44Mar 19, 2018 9:48 am So Frames as done and Darbecca has done the inspection Found 22 defects but SS said they all are minor and will be fixed this week. Hope he is right on it. Next week will be the roof. Once roof completed, will have some photos to upload. Re: Emporio 43 with henley 45Mar 21, 2018 2:14 pm Hi Sumit. We are also building with Henley and building an Emporio home. Our timing is similar to yours. Signed Contract 1st week of September last year. Was initially advised that slab will be done December but Slab started and finished first week of Feb this year instead. Apparently next stage (frames) won’t start till April-May. Did you have to do any persistent chasing for building to progress at your rate? Re: Emporio 43 with henley 46Mar 21, 2018 2:16 pm LTT Hi Sumit. We are also building with Henley and building an Emporio home. Our timing is similar to yours. Signed Contract 1st week of September last year. Was initially advised that slab will be done December but Slab started and finished first week of Feb this year instead. Apparently next stage (frames) won’t start till April-May. Did you have to do any persistent chasing for building to progress at your rate? yes, I have too. They are too slow for everything apart from sending the invoices. We are in week 9 after slab and still no roof yet. Hopefully next week before Easter holidays. Where are you building? Re: Emporio 43 with henley 47Mar 21, 2018 2:39 pm We’re building in Greenvale. Our “to be” next door neighbor also built with Henley, and was still following up on fixes last December. Made me nervous even before construction started, so am interested in following your stream to see how they deal with fixes during and after construction. Re: Emporio 43 with henley 48May 01, 2018 3:34 pm bhutani.sumit LTT Hi Sumit. We are also building with Henley and building an Emporio home. Our timing is similar to yours. Signed Contract 1st week of September last year. Was initially advised that slab will be done December but Slab started and finished first week of Feb this year instead. Apparently next stage (frames) won’t start till April-May. Did you have to do any persistent chasing for building to progress at your rate? yes, I have too. They are too slow for everything apart from sending the invoices. We are in week 9 after slab and still no roof yet. Hopefully next week before Easter holidays. Where are you building? Hi Sumit, I am new to this forum and glad that I found this thread. I liked the Emporio and was wondering if you could help me some costs. Your build seems to be quite like what I have in mind. - What were your site costs - was there a fall in your land and was any cut and fill involved? - What was the cost of adding shower to powder? - What was the cost of converting study to bedroom? - Cost of converting butlers pantry to prayer room? - Cost of facade upgrades - did you go for one? Re: Emporio 43 with henley 49May 05, 2018 6:59 pm Hi Sumit, LTT & Neil, We are looking to build the Emporio 39 with Henley. Are any of you doing a knock down & rebuild? Or all building on new estates? There are so many scary stories regarding builders so I was looking for some tips as to what are the key points to watch out for? Did any of you investigate the quality of their construction by visiting houses recently built by Henley. Please give me suggestions on what upgrades are absolutely necessary to take and what we can do later. Like any of you taking flooring, drive way and cooling as upgrade or will it be cheaper to do it separately after handover. Are you using an independent building inspector to check for you at all stages? FOLLOW MY BUILD: https://forum.homeone.com.au/viewtopic.php?f=31&t=92532 Re: Emporio 43 with henley 50Jul 08, 2018 10:40 pm HenleyNeil Thank you, very good option Hi Sumit, Wonderin about your progress with building. How is your experience with Henley so far? Thank you. Re: Emporio 43 with henley 51Jul 09, 2018 2:36 pm HoneyDee Hi Sumit, LTT & Neil, We are looking to build the Emporio 39 with Henley. Are any of you doing a knock down & rebuild? Or all building on new estates? There are so many scary stories regarding builders so I was looking for some tips as to what are the key points to watch out for? Did any of you investigate the quality of their construction by visiting houses recently built by Henley. Please give me suggestions on what upgrades are absolutely necessary to take and what we can do later. Like any of you taking flooring, drive way and cooling as upgrade or will it be cheaper to do it separately after handover. Are you using an independent building inspector to check for you at all stages? Hi HoneyDee, I’m building in a new estate but my sister is knock down and rebuild. The upgrades we chose were mostly driven by our personality - a little lazy to do diy mostly. We took up flooring as we didn’t want accidental holes in the wall by flooring people after handover. Saying that.. we are battling through their “variation” but wanting us to sign and acknowledge at our expense of late.. and no, we haven’t budged- thank goodness for the stoic hubs handling the to and fro. Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 10527 |
