Browse Forums Building A New House Re: Steel frame in Adelaide 6Aug 21, 2008 10:50 am mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Steel frame in Adelaide 8Aug 21, 2008 11:19 am mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Steel frame in Adelaide 11Aug 21, 2008 11:04 pm mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Steel frame in Adelaide 13Aug 21, 2008 11:24 pm mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Steel frame in Adelaide 15Aug 21, 2008 11:31 pm mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Steel frame in Adelaide 17Aug 21, 2008 11:34 pm mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Steel frame in Adelaide 20Aug 22, 2008 5:49 pm Id like to add 2 cents worth here, if I may.
1)Steel is good, probably more expensive, but well worth the initial outlay (no more termite worries). Very strong and durable. 2)Timber is also good, a little less cheaper, yes. Precautions in construction detailing will eliminate the nasty termites anyway (termite caps, provision for reticulated termite treatment, termite barriers etc. Water pipes, electrical wires etc etc can as easily be reticulated through steel framing as timber framing, there is no difference (except for the drill bit used to form the holes required). You can add to a steel frame house, outwards, upwards, whatever direction you desire, the only thing to remember is to consult a structural engineer, he will work out all the forces, weights, stability etc etc, he will advise on what you can and cant do. Your probably bored of me saying this in my replys, but there is a reason why they exist, if in doubt, consult the professionals. Noise if dealt with correctly will not be an issue, everyone these days should be packing their homes with as much insulation as possible, insulation cuts down / eliminates noise transfer. Pat. Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14448 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8032 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4460 |
