https://1drv.ms/f/s!AoKBYVes8JAPjTu-QGBikZCk-1De
Browse Forums Building A New House Re: Building at Bardia - New Breeze 784Jun 06, 2018 4:38 pm Tolgz Sa. Thanks hasan have you gone to tender or was that a quote they gave you verbally? Yes I have a tender. I do kitchens/vanities/wardrobes for this company. They do amazing luxury houses for really cheap prices. My tender for this with pool was $700k 438sqm total construction size. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building at Bardia - New Breeze 785Jun 10, 2018 10:28 am Good morning everyone, What grade slab are your builders advising? I know that it will/can vary between locations, but im also curios to see if anyone has had high saline in their soil. Thanks Re: Building at Bardia - New Breeze 786Jun 10, 2018 2:25 pm M class for me. I am with Rawson and building on Arthur Allen Opp to school. GLO Good morning everyone, What grade slab are your builders advising? I know that it will/can vary between locations, but im also curios to see if anyone has had high saline in their soil. Thanks Re: Building at Bardia - New Breeze 788Jun 14, 2018 3:14 pm GLO Does anyone in Bardia have a large balcony? I'm keen to see what is the largest front or rear balcony locals have built. Thanks I dont like balcony. Lol Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Building at Bardia - New Breeze 789Jun 14, 2018 4:20 pm wentworth33 GLO Does anyone in Bardia have a large balcony? I'm keen to see what is the largest front or rear balcony locals have built. Thanks I dont like balcony. Lol lol Re: Building at Bardia - New Breeze 790Jun 14, 2018 6:38 pm GLO Does anyone in Bardia have a large balcony? I'm keen to see what is the largest front or rear balcony locals have built. Thanks We are looking at putting in a large balcony across the front as our view will be of the pond/parks between bruce ferguson and bardia ave. We are drawing inspiration from the Allcastle Homes Grandworth 38 in terms of size. I've seen this range up close and we quite like it. We've also checked with our Architect and this would be approved on our corner block - from memory you too are on a corner? http://www.allcastlehomes.com.au/displa ... orth-38-7/ Re: Building at Bardia - New Breeze 791Jun 16, 2018 6:50 pm Hi All, I heard from one the builder recently that Edmondson Park South DCP has changed and the minimum land size for a secondary dwelling is 250 sqm. This would mean any smart living lot <250 sqm with dual lane access does not qualify for having a studio or fonzi on top of a rear loaded garage. Just wondering if anybody else in this forum heard about the changes to DCP and confirm if it is indeed correct. Thanks Re: Building at Bardia - New Breeze 792Jun 16, 2018 8:42 pm Cooky GLO Does anyone in Bardia have a large balcony? I'm keen to see what is the largest front or rear balcony locals have built. Thanks We are looking at putting in a large balcony across the front as our view will be of the pond/parks between bruce ferguson and bardia ave. We are drawing inspiration from the Allcastle Homes Grandworth 38 in terms of size. I've seen this range up close and we quite like it. We've also checked with our Architect and this would be approved on our corner block - from memory you too are on a corner? http://www.allcastlehomes.com.au/displa ... orth-38-7/ Hi, Im opposite the corner beside a rural block. I’m having a balcony off the rear Master. Would your balcony be larger than 12sqm? Re: Building at Bardia - New Breeze 793Jun 16, 2018 8:51 pm GLO Cooky GLO Does anyone in Bardia have a large balcony? I'm keen to see what is the largest front or rear balcony locals have built. Thanks We are looking at putting in a large balcony across the front as our view will be of the pond/parks between bruce ferguson and bardia ave. We are drawing inspiration from the Allcastle Homes Grandworth 38 in terms of size. I've seen this range up close and we quite like it. We've also checked with our Architect and this would be approved on our corner block - from memory you too are on a corner? http://www.allcastlehomes.com.au/displa ... orth-38-7/ Hi, Im opposite the corner beside a rural block. I’m having a balcony off the rear Master. Would your balcony be larger than 12sqm? Yep, around 22 sqm. It will span the full length of the front of the house to make good use of the view. Plus we like having the larger balcony. My architect said this would be approved, no issues. I'm not sure about the rear though as there are issues with privacy, these are noted in the dcp. Re: Building at Bardia - New Breeze 794Jun 16, 2018 11:58 pm Cooky GLO Cooky [quote="GLO"]Does anyone in Bardia have a large balcony? I'm keen to see what is the largest front or rear balcony locals have built. Thanks We are looking at putting in a large balcony across the front as our view will be of the pond/parks between bruce ferguson and bardia ave. We are drawing inspiration from the Allcastle Homes Grandworth 38 in terms of size. I've seen this range up close and we quite like it. We've also checked with our Architect and this would be approved on our corner block - from memory you too are on a corner? http://www.allcastlehomes.com.au/displa ... orth-38-7/ Hi, Im opposite the corner beside a rural block. I’m having a balcony off the rear Master. Would your balcony be larger than 12sqm? Yep, around 22 sqm. It will span the full length of the front of the house to make good use of the view. Plus we like having the larger balcony. My architect said this would be approved, no issues. I'm not sure about the rear though as there are issues with privacy, these are noted in the dcp.[/quote] Sounds very nice! What height ceilings are you doing on Ground Floor. I have read that there is a 6m from boundary for rear balcony which I satisfy. But I have also read a 12sqm limitation if balcony is above 3000mm height above natural ground level. Re: Building at Bardia - New Breeze 795Jun 17, 2018 12:38 am GLO Sounds very nice! What height ceilings are you doing on Ground Floor. I have read that there is a 6m from boundary for rear balcony which I satisfy. But I have also read a 12sqm limitation if balcony is above 3000mm height above natural ground level. Yes, thats right with the 6m. I thought you were stretching the house as far back as you could. The ground floor height is 2.7m so i will re check your advice to make sure we get it. Allcastle homes seem to have been allowed to do their displau homes like that withthe full stretched balcony in edmonson park so i presume we should be okay but you never know! Re: Building at Bardia - New Breeze 796Jun 17, 2018 12:59 am Cooky GLO Sounds very nice! What height ceilings are you doing on Ground Floor. I have read that there is a 6m from boundary for rear balcony which I satisfy. But I have also read a 12sqm limitation if balcony is above 3000mm height above natural ground level. Yes, thats right with the 6m. I thought you were stretching the house as far back as you could. The ground floor height is 2.7m so i will re check your advice to make sure we get it. Allcastle homes seem to have been allowed to do their displau homes like that withthe full stretched balcony in edmonson park so i presume we should be okay but you never know! My ground floor is the same so I’m keen to see if I can get it through like you. Double check. If I was to get the regular rear balcony off the master it would be approx 5m x 4m Re: Building at Bardia - New Breeze 800Jun 20, 2018 4:06 pm GLO Cooky GLO Sounds very nice! What height ceilings are you doing on Ground Floor. I have read that there is a 6m from boundary for rear balcony which I satisfy. But I have also read a 12sqm limitation if balcony is above 3000mm height above natural ground level. Yes, thats right with the 6m. I thought you were stretching the house as far back as you could. The ground floor height is 2.7m so i will re check your advice to make sure we get it. Allcastle homes seem to have been allowed to do their displau homes like that withthe full stretched balcony in edmonson park so i presume we should be okay but you never know! My ground floor is the same so I’m keen to see if I can get it through like you. Double check. If I was to get the regular rear balcony off the master it would be approx 5m x 4m For a rear balcony, you have to put in a privacy screen if your balcony will be 3 m above ground level. For reference, this is the Austlii reference. My take on this is, that they would be breaking the law denying access to a homeowner in Victoria, or their agent from having… 1 9094 Is it just a report written to give to the bank initially and it is based on what and how your payments are made up for, or is it a full service where they go out and… 2 5599 Hi Suku18 In NSW the statutory required insurances are: 1. HBCF ( Home Building Compensation Fund) - This is if the builder dies or goes broke. But this only covers 20%… 1 2712 |
