Browse Forums Building A New House Re: Building at Bardia - New Breeze 635Mar 31, 2018 5:07 pm Hi all I'm new to this forum. I'm building in Bardia New Breeze on a 300sqm block. Just wanted to know what the setback boundaries are for the front, back and side of the property. I'm on a zero lot block for one side of my land. I'm most interested in the side setbacks as that seems to be my biggest issue with finding a design that will fit and have the rooms that I want! Thanks! Building in New Breeze, Stage 3 Parkside Bardia Re: Building at Bardia - New Breeze 636Mar 31, 2018 10:21 pm NZ89 Hi all I'm new to this forum. I'm building in Bardia New Breeze on a 300sqm block. Just wanted to know what the setback boundaries are for the front, back and side of the property. I'm on a zero lot block for one side of my land. I'm most interested in the side setbacks as that seems to be my biggest issue with finding a design that will fit and have the rooms that I want! Thanks! Hi NZ89, You will need to talk to your builder in regards of the setback. Setbacks are defined according to the building dimensions, not by the total size of your land. Standard setbacks on the side is 90cm. zero lot block means you can have your garage attached to someone's else, but just in case, please check with the banks (if you are doing finance) before continue. Read the following links for more info and make sure you have all the criteria on "How do I get approved?" section. https://www.homeloanexperts.com.au/prop ... tion-loan/ Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Building at Bardia - New Breeze 637Apr 02, 2018 8:39 pm wentworth33 Hi NZ89, You will need to talk to your builder in regards of the setback. Setbacks are defined according to the building dimensions, not by the total size of your land. Standard setbacks on the side is 90cm. zero lot block means you can have your garage attached to someone's else, but just in case, please check with the banks (if you are doing finance) before continue. Read the following links for more info and make sure you have all the criteria on "How do I get approved?" section. https://www.homeloanexperts.com.au/prop ... tion-loan/ Hi Wentworth33, Thanks for the reply! I've spoken with over 20 builders and narrowed it down to 3 potential builders. I love the Maza 29 layout by Metricon: https://www.metricon.com.au/new-home-de ... oorplan=29 I have a 10 metre frontage. The house width is 8.99m which leaves the 900mm for one side (I have an easement) and 50mm for my zero lot side. (It doesn't need to be attached to the next door neighbours garage, I double checked. It's basically building right on the boundary, well, 50mm from it). Anyway, the builder said I can't do this because I need a 1.5 metre setback on one side. But so many people are telling me different things.....uh! Where are you building? I'll be in Parkside Building in New Breeze, Stage 3 Parkside Bardia Re: Building at Bardia - New Breeze 638Apr 02, 2018 11:09 pm NZ89 wentworth33 Hi NZ89, You will need to talk to your builder in regards of the setback. Setbacks are defined according to the building dimensions, not by the total size of your land. Standard setbacks on the side is 90cm. zero lot block means you can have your garage attached to someone's else, but just in case, please check with the banks (if you are doing finance) before continue. Read the following links for more info and make sure you have all the criteria on "How do I get approved?" section. https://www.homeloanexperts.com.au/prop ... tion-loan/ Hi Wentworth33, Thanks for the reply! I've spoken with over 20 builders and narrowed it down to 3 potential builders. I love the Maza 29 layout by Metricon: https://www.metricon.com.au/new-home-de ... oorplan=29 I have a 10 metre frontage. The house width is 8.99m which leaves the 900mm for one side (I have an easement) and 50mm for my zero lot side. (It doesn't need to be attached to the next door neighbours garage, I double checked. It's basically building right on the boundary, well, 50mm from it). Anyway, the builder said I can't do this because I need a 1.5 metre setback on one side. But so many people are telling me different things.....uh! Where are you building? I'll be in Parkside Hi NZ89, Have you check it with other builder ? Please double check with the builder and ask why you need 1.5m on the side. If not mistaken, you DO need 1.5m if you have a water tank on the side. But, why not move the water tank behind the garage ? (ie. close the garage door access to the garden, you dont need it do you ?) check it with the builder, If you dont have water tank on the side, do you still need 1.5m or 900mm ? Hope this info helps. Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Building at Bardia - New Breeze 639Apr 02, 2018 11:12 pm NZ89 wentworth33 Hi NZ89, You will need to talk to your builder in regards of the setback. Setbacks are defined according to the building dimensions, not by the total size of your land. Standard setbacks on the side is 90cm. zero lot block means you can have your garage attached to someone's else, but just in case, please check with the banks (if you are doing finance) before continue. Read the following links for more info and make sure you have all the criteria on "How do I get approved?" section. https://www.homeloanexperts.com.au/prop ... tion-loan/ Hi Wentworth33, Thanks for the reply! I've spoken with over 20 builders and narrowed it down to 3 potential builders. I love the Maza 29 layout by Metricon: https://www.metricon.com.au/new-home-de ... oorplan=29 I have a 10 metre frontage. The house width is 8.99m which leaves the 900mm for one side (I have an easement) and 50mm for my zero lot side. (It doesn't need to be attached to the next door neighbours garage, I double checked. It's basically building right on the boundary, well, 50mm from it). Anyway, the builder said I can't do this because I need a 1.5 metre setback on one side. But so many people are telling me different things.....uh! Where are you building? I'll be in Parkside btw, I am on the lot 5 series, the very early first stage. behind the sales office and its about to be registered next 2 weeks. Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Building at Bardia - New Breeze 640Apr 02, 2018 11:24 pm wentworth33 NZ89 wentworth33 Hi NZ89, You will need to talk to your builder in regards of the setback. Setbacks are defined according to the building dimensions, not by the total size of your land. Standard setbacks on the side is 90cm. zero lot block means you can have your garage attached to someone's else, but just in case, please check with the banks (if you are doing finance) before continue. Read the following links for more info and make sure you have all the criteria on "How do I get approved?" section. https://www.homeloanexperts.com.au/prop ... tion-loan/ Hi Wentworth33, Thanks for the reply! I've spoken with over 20 builders and narrowed it down to 3 potential builders. I love the Maza 29 layout by Metricon: https://www.metricon.com.au/new-home-de ... oorplan=29 I have a 10 metre frontage. The house width is 8.99m which leaves the 900mm for one side (I have an easement) and 50mm for my zero lot side. (It doesn't need to be attached to the next door neighbours garage, I double checked. It's basically building right on the boundary, well, 50mm from it). Anyway, the builder said I can't do this because I need a 1.5 metre setback on one side. But so many people are telling me different things.....uh! Where are you building? I'll be in Parkside Hi NZ89, Have you check it with other builder ? Please double check with the builder and ask why you need 1.5m on the side. If not mistaken, you DO need 1.5m if you have a water tank on the side. But, why not move the water tank behind the garage ? (ie. close the garage door access to the garden, you dont need it do you ?) check it with the builder, If you dont have water tank on the side, do you still need 1.5m or 900mm ? Hope this info helps. Hi Wentworth33, I've checked with two others, but their house designs were smaller, so it wasn't as tight of a fit as the one I really want. I'll check with a few more! I guess once I get closer to the land registering, I will get my top three designs and see which council approves?! Do I need a water tank? I never heard about that..... I hope I don't need one. My lot is so small! Do you need one? What is the lot 5 series? I'm not sure of all the different stage names there. I think I'm Parkside release 2? I'm the street after Alamien Street to the right http://www.newbreeze.com.au/pdf/NewBree ... an_WEB.pdf Building in New Breeze, Stage 3 Parkside Bardia For reference, this is the Austlii reference. My take on this is, that they would be breaking the law denying access to a homeowner in Victoria, or their agent from having… 1 8933 Is it just a report written to give to the bank initially and it is based on what and how your payments are made up for, or is it a full service where they go out and… 2 5541 Hi Suku18 In NSW the statutory required insurances are: 1. HBCF ( Home Building Compensation Fund) - This is if the builder dies or goes broke. But this only covers 20%… 1 2666 |
