Browse Forums Building A New House 1 Aug 20, 2008 2:51 pm Hi guys,
Want to install a desk. But a desk top that sits on a horizontal batten on the wall. A noggin will need to go in before plaster to support this batten. So question is : how far up the wall from the concrete slab should the top edge of the noggin sit, taking into account depth of carpet pile & underlay? Is there a standard measurement or should we take a guess ? I intend having a carpet with a low profile eg twist, no loop pile. Thanks for any suggestions. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Noggin height 3Aug 20, 2008 3:30 pm Thanks Al,
I'm guessing studs are installed at a particular position to satsify buidling codes ? Is this installation height therefore at a correct distance from the slab, for the batten to be fixed at the right spot ? Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Noggin height 4Aug 20, 2008 3:51 pm Studs are the vertical timbers in the wall. Should be 450 or 600 apart. Your timber for the benchtop to sit on will run across several of these. Screw in where appropriate and you can have the bench at whatever height you want. Re: Noggin height 6Aug 20, 2008 7:05 pm Buy a stud-finder, they're cheap enough. If the house was built in the last 20 years or so they'll be at 450mm centres.
As Al said, simply screw batten/bugle screws into each stud. If you batten is 35mm thick (eg. 70x35,90x35) use 75mm batten screws. Re: Noggin height 8Aug 20, 2008 7:22 pm Phoenix has added a bench to her study and it's attached straight to the wall. Might help if you looked at her home building thread? It's a great idea! Happy at Home Re: Noggin height 9Aug 20, 2008 7:35 pm House-To-Be Phoenix has added a bench to her study and it's attached straight to the wall. Might help if you looked at her home building thread? It's a great idea! You know I knew that I had read about this somewhere........but couldn't remember in which thread. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Noggin height 10Aug 20, 2008 7:39 pm Southies House-To-Be Phoenix has added a bench to her study and it's attached straight to the wall. Might help if you looked at her home building thread? It's a great idea! You know I knew that I had read about this somewhere........but couldn't remember in which thread. Here you go, need to look at page 66 https://forum.homeone.com.au/viewtopic.p ... &start=975 Happy at Home Re: Noggin height 13Aug 25, 2008 10:26 am Sorry Southies, i must have missed this thread. When we put in our noggins, we used framing timber. So std noggin material....and put them in at about 800mm high from the concrete slab.
If you position the noggins with the thicker side of the timber running vertically instead of horizontally as like the normal studs it will give you a bit of play for the positioning of the height. So just turn the noggins 45 degrees and you'll be right. I've been asked to dig up a photo of the noggin layout before plaster so will post a pic for you here if you want? On top of that we also used some 45 degree aluminium to support it around the walls and attach it firmly to the plaster/noggins. Hmm i might actually raise a thread just in case anyone wants to see it in more detail.... Good Luck! Re: Noggin height 14Aug 25, 2008 10:29 am **Phoenix** Sorry Southies, i must have missed this thread. When we put in our noggins, we used framing timber. So std noggin material....and put them in at about 800mm high from the concrete slab. If you position the noggins with the thicker side of the timber running vertically instead of horizontally as like the normal studs it will give you a bit of play for the positioning of the height. So just turn the noggins 45 degrees and you'll be right. I've been asked to dig up a photo of the noggin layout before plaster so will post a pic for you here if you want? On top of that we also used some 45 degree aluminium to support it around the walls and attach it firmly to the plaster/noggins. Hmm i might actually raise a thread just in case anyone wants to see it in more detail.... Good Luck! Thanks I think I few of us would like to see the pics. Thanks for taking the time to post them. Happy at Home Re: Noggin height 16Aug 25, 2008 8:20 pm **Phoenix** So just turn the noggins 45 degrees and you'll be right. or is that 90 degrees Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10683 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7741 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9563 |
