Browse Forums Building A New House Re: Double storey base price 4May 14, 2017 9:01 am wongbruce paraga Hi All, I'm planning to build a 25-square double storey house. Can anybody suggest a base quote per square meter or per square ? Thanks It's varies from builder to builder depending on quality. What you need to do is really compare Apples with Apples not an Apple and Pear. Kind Regards, Bruce "Building an Eden Brae Waldorf 50 in North Kellyville" Blog: http://waldorf50.blogspot.com.au A Mobile Solicitor at Wong & Horta Lawyers Website: http://www.whlawyers.com.au Re: Double storey base price 5May 14, 2017 9:40 am paraga Can you please give me an idea of a range from the cheapest to the costliest? I have no idea about the cheapest, as this would also be dependent of where you are located, but the costliest can run into millions. Re: Double storey base price 7May 14, 2017 10:10 am I looked at two storey houses, but they were out of our budget once you added on all the things we wanted to upgrade. Metricon cheapest is around 258K now this is regional Victoria pricing for Glendale 34. Re: Double storey base price 8May 14, 2017 10:12 am Project builder? Custom builder? Architect design? Owner builder? What location? Which state? Suburban, outer urban, acreage or rural? What size second floor compared to the first? How many wet areas, and on which floors? What is the slope of the land? Size? Chokepoints or minimum dimensions? Estate covenants? Access? Site storage? What structural material? Exterior walls? Roof? Upper floor? Ground floor slab or on piers? Re: Double storey base price 10May 14, 2017 10:28 am dalgernon Project builder? Custom builder? Architect design? Owner builder? Custom, Owner Occupier What location? Which state? Suburban, outer urban, acreage or rural? South Morang, Melbourne What size second floor compared to the first? First - around 130 sqm Second - 45 sqm How many wet areas, and on which floors? First Floor-ensuite only Ground Floor-all other wet areas What is the slope of the land? Size? Chokepoints or minimum dimensions? Estate covenants? No slope Access? Site storage? Accessible..didnt understand site storage What structural material? Exterior walls? Roof? Upper floor? Ground floor slab or on piers? site classified as "P", so maybe have to go for piers My answers are in blue above Re: Double storey base price 13May 14, 2017 11:18 am Architect design in Sydney starts at around $1,500 psqm. Re: Double storey base price 15May 14, 2017 12:01 pm 8000sq to 14,000 Sq, the lowest rate will include waffle slabs, lowest builders range fit outs, minimum code generally done anywhere from OK to really poor, basic outside house shape, basic single glaze lower end windows, low amount of power points etc. Re: Double storey base price 17May 14, 2017 12:13 pm Based on the info provided and the calculators I normally use I'd say that you're looking at a bare minimum of $300K (note that when you're looking at the bottom end rates per square/square metre can be extremely misleading) and probably a bit more (depending on your builder and the materials selected) for the base build. That will be extremely basic, and does not include site works, landscaping, flooring, window treatments, design costs, approval/compliance processes etc. Issues such as not being able to store a decent amount of material on-site will also add to costs, as will any access issues. It also assumes that your upper floor loads line up nicely on your ground floor structure and you have no large spans or requirement for structural steel. Your site works have the potential to add a bit more to this, depending upon the reasons for the 'P' rating. If it were me, I'd start with a baseline budget of a minimum 1,700 per square metre and work up from there. Why are you asking this? The answer to that informs what you need to do next. Re: Double storey base price 19May 14, 2017 4:32 pm paraga Can you recommend any custom builder in Melbourne who does a decent job in a budget(entry level) price ? I'd say you get what you pay for! Re: Double storey base price 20May 14, 2017 7:25 pm Hi Paraga, It very hard to put one number on building cost. It depends on too many variables like upgrades, inclusions, slab cost etc etc. Cost could be around $10,000 to $12,000 per sqm. How i know? I work for builder. I have clients who just want basic turn key packages(~$10,000 to $11,000) and some want all the upgrades they can get(~$13-$14,000). Thanks Jas Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 9948 1 4581 I've filled, levelled and compacted around 100mm of roadbase in preparation to lay some outdoor court tiles. Prior to doing the final compaction, I dusted the top with… 0 3043 |
