Browse Forums Building A New House 1 May 13, 2017 10:43 pm Hi, what building straucture can one build on the second easement of 60/60/60 firerating 2.05m meters from padmount substation? If we want to place garage within that easement area, do we need to build e the whole garage with 60/60/60 material? How expensive is that? You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17138 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16130 Thanks - yea sounds like I need to submit build over easement application....ugh guess I better start finding someone who can do the engineering drawings 3 3328 |
