Browse Forums Building A New House 1 May 06, 2017 11:21 pm Is there any appro cost $ per sqm for buidling a 4b house (2 storey) (eg in Box Hill)? Trying to make guess of building/construction part after buying Land only. Re: What is building cost $/sqm? 2May 06, 2017 11:37 pm The cost is dependent on the type of house, the quality of the build, the level of amenity you want and how fast you want it built. Standard advice is $1500 per square metre upwards. For example, it could be $4000 per square metre for an architect designed home. Petercurtis You able to contact the certifier and get a copy of your structural plans, if they are not in your contract. If your home was approved via CDC then they… 1 20185 custom probably not. Volume, most defiantly, but spec would vary. If youre doing a knock down, there additional costs associated with that that will eat into your budget… 1 10283 multiple occ properties are always billed by trades at a premium, rarely per sqm for the lot. You either have trades you know whoe will do by sqm or youre going to get… 1 2252 |
