Bulkhead in Bathroom! Surprise! Not happy
The bulkhead is going to come out just over half the width of the shower and is only 300mm above the shower head outlet, basically it looks bloody terrible and when I initially questioned the builder about having no eave on the plan I was told that it would not effect the house at all, I agreed to it only because it was on the southern side and for 6.5m long. To find this is now what we are left with is very disappointing and I can not find anything on the plans to show that it was going to be there apart from it showing a line with 'beam over' written on it. Is this normal building practice, ceiling height is 2.4m throughout but now 2.1m under the bulkheads.
Bottom line is it looks like crap and sticks out like nothing else especially over half the shower, has anyone else had one of these surprises? Thoughts?
If you can post a photo of your plan, and a photo of the head
I asked about going out to the eaves to make the garage wider and was told by our sales to avoid it because you'd need a bulkhead along that entire side of the house.
I'm sorry that you weren't given the same advice.
I can't see the pictures but can imagine and can understand your disappointment, not sure much can be done at this stage but I don't know a lot about it so I'm hoping it's not too late for you
Can't see pictures.
Hmm I can see them so not sure how to fix it??
Hope it works for you eventually.
still nothing!
Hahahah me to, I can no longer see them in my first post or second post.but if I click on edit they show up!!
- B
A vue of the pines on the Gold Coast
forum.homeone.com.au/viewtopic.php?f=31&t=87210
1
No one can give you a meaningful answer without looking at your building contract, what happened on site and who designed your house You should get experienced building…
22/05/2023
3
Render your bathroom walls, two opinions versus the one, makes you wonder.
30/05/2023
2
Hi Geoff Install Puddle Flange prior to any screed. Puddle flange needs to be flush with the surface so you may need to grind away the surface to achieve this. Also as…
