Browse Forums Building A New House 1 May 02, 2017 9:31 pm This is 29.3x11.5m block ~ 337sqm Is building area of 158sqm (this specific plan 1:2) too small? We see lot of space wasted in this plan but the dev is not ready to change it so gonna give it a pass. Thoughts on this specific plan? http://imgur.com/0Mou9Om Re: Is 1:2 Building:House ratio area too small? 3May 03, 2017 9:04 am Yes, I work it out as 82.5sqm, or 24.5% (not including the 'optional alfresco'). That would give a decent amount of garden/yard space for that size block, or possibly even room to go dual-occupancy in the future (granny flat or even townhouse, depending on the block dimensions and zoning regulations). It's not the most space-efficient plan ever and could definitely be improved, but I've also seen worse. As to whether or not it's "too small": that'd be up to you and what your requirements are. I'd caution against looking at areas and ratios and instead look at functionality. Do you want a yard/garden? Swimming pool? What are your requirements for the house? How many bedrooms? Living area arrangements? How long are you intending to live there? How many people? How is your living/family situation anticipated to change over time? etc. Focusing on numerical ratios means that you can easily lose sight of what a house is actually for. It's like those people who say "well, we're living in a house of XX size now, so to be a decent upgrade the new house as to be at least YY in size", and who then end up with an expensive house (with associated mortgage stress) that's actually worse to live in than their old one. Re: Is 1:2 Building:House ratio area too small? 4May 03, 2017 10:56 am Thanks Do you want a yard/garden? No Swimming pool? No What are your requirements for the house? How many bedrooms? Living area arrangements? 4bedrooms, more living space the better. How long are you intending to live there? How many people? How is your living/family situation anticipated to change over time? It will be investment prop. Looking at the 350sqm lot size, re there any other recommended builders or any specific plans from them which offers better layout (and higher than this construction area than the above builder - Noble Group) and rough estimate of price of construction? Appreciate some guidance here Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2586 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16562 Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4709 |
