Browse Forums Building A New House 1 Apr 24, 2017 10:44 am Hi All, We are building Washington 32 with Wisdom. Washington 32+ Savannah facade+Luxury inclusion + wise choice We have taken below upgrades: Height 2590 mm for ground & Upper floor Sliding doors in wardrobes Study changed to bedroom with sliding door & wardrobe Added shower to powder room 1020 mm entry door upgrade Undermount sink in kitchen Door below stairs Full 2 walls in ensuite & main bathroom tiled PA for staircase 10000 PA for tiles 6000 PA for wet area tiling full 2 walls 2000 PA for Kitchen 4000 PA for electrical 2000 PA for landscaping 5000 +(5500 from wisdom) NBN Kindly advise about what all you expect we have missed? Also if there are pictures or blogs of washington 32 kindly share. BuildingWashington 32 with W https://buildyourfirsthome.wordpress.com/ Contract: 26/11/2017 DA: 28/03/2018 Admin : 26/04/2018 Const: 11/05/2018 Slab: 16/05/2018 Re: Building Washington 32 with Wisdom 2Apr 24, 2017 1:07 pm Kvav27 Hi All, We are building Washington 32 with Wisdom. Washington 32+ Savannah facade+Luxury inclusion + wise choice We have taken below upgrades: Height 2590 mm for ground & Upper floor Sliding doors in wardrobes Study changed to bedroom with sliding door & wardrobe Added shower to powder room 1020 mm entry door upgrade Undermount sink Door below stairs Full 2 walls in ensuite & main bathroom tiled PA for staircase 10000 PA for tiles 6000 PA for Kitchen 4000 PA for electrical 2000 Kindly advise about what all you expect we have missed? Also if there are pictures or blogs of washington 32 kindly share. Hi Kvav I've sent you a PM about staircases. We're still waiting on our kitchen quote but everything added up pretty quick once you start adding all the little extras - soft close drawers and cupboards, extra pot drawers, Riven or Nuance finishes to laminate cupboard, hidden bin in cupboard, extra cabinetry in pantry/butlers pantry. Caesarstone upgrades and/or waterfall ends will bump the price pretty quickly too. We got told at our appointment that if we put in pot drawers but didn't add the soft close to them then they can't hold much weight and don't open all the way out - so essentially it's pointless getting pot drawers without the soft close mechanisms too. The standard range of choices for the poly cupboards and handles are pretty good. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I would say you won't get very much with only $2000 for electrical. Extra double power point or bayonet light fitting are $58 each. $130 per downlight, $120 for double outdoor power point, $140 for a cat6 network point, $412 for a TV antenna, $190 for an external up/down light. We plan to put fans with lights in all the bedrooms except the master - if we do them through wisdom that will be nearly $1500 just for the 3 bedrooms, or $600 just for provisions to install then we still have to buy our own and get an electrician in to fit it all after. Other things we put provisions in for were air con (it's about $6k to step up to the next AC unit that can have more than 2 zones and is more power efficient), colours upgrades (additional paint colours, wood look garage door, tapware changes), landscaping (we only plan to do a driveway and letterbox with Wisdom, but we expect it to cost about $4-5K on top of the voucher they give). Re: Building Washington 32 with Wisdom 3Apr 24, 2017 2:06 pm Thanks a ton Jenifermarie. It helps a lot. Your blog too helps a lot. We had our first tender, but we ended up with some changes and awaiting second and final tender. I understand my electrical PA is less and may be i will put more from my staircase into electrical and Kitchen and go for simple stairs. Wisdom has shared with me the stairs and other pdfs via usb.But stairs one was not very clear to me. Like I only want basic wooden stairs and not carpeted one. and wanted to understand how much i should be looking towards it. so if we go for Raven look polyurethane its a upgrade? I was not aware of it. BuildingWashington 32 with W https://buildyourfirsthome.wordpress.com/ Contract: 26/11/2017 DA: 28/03/2018 Admin : 26/04/2018 Const: 11/05/2018 Slab: 16/05/2018 Building Washington 32 with Wisdom 4Apr 24, 2017 2:27 pm Kvav27 Hi All, We are building Washington 32 with Wisdom. Washington 32+ Savannah facade+Luxury inclusion + wise choice We have taken below upgrades: Height 2590 mm for ground & Upper floor Sliding doors in wardrobes Study changed to bedroom with sliding door & wardrobe Added shower to powder room 1020 mm entry door upgrade Undermount sink Door below stairs Full 2 walls in ensuite & main bathroom tiled PA for staircase 10000 PA for tiles 6000 PA for Kitchen 4000 PA for electrical 2000 PA for landscaping 5000 Kindly advise about what all you expect we have missed? Also if there are pictures or blogs of washington 32 kindly share. With your entry door, did you upgrade the height as well as the width, or just sticking with standard? We upgraded all our ground floor doors to be 2340 high except our laundry external door. Is your tile PA including the main floor tiles? We went with the included laminate flooring and carpet but a lot of people upgrade here. We also spent $1000ish upgrading the carpet underlay. We spent $7000 on wet area tiling upgrades with a few walls full height tiles that weren't in tender but mostly because I chose more expensive tiles Do you want waterfall ends on your kitchen bench? If not, your budget there will probably be fine. Add $3kish if you want a laundry fit out and another $3k if you want waterfall ends. Your electrical budget is not enough. I'd allow at least $6k here. We spent $9000 with about $2000 to spend after handover (in a 40 square house). Landscaping is also low, you will need a few thousand for your driveway even after the $5000 Wisdom give you. Fencing. Privacy glass in bathrooms. Fly screens and screen doors. NBN. Wiring for speakers in ceilings or home security cameras. If you want a rainforest showerhead that's $800. Also you may want to upgrade your aircon. We didn't upgrade the unit, but we did add an extra controller, an extra zone and added a linear outlet, came to $1000. If you choose to upgrade to a more energy efficient unit it's around $5000. Building Monte Carlo 40- Wisdom homes Re: Building Washington 32 with Wisdom 5Apr 24, 2017 2:50 pm MandM+4 Kvav27 Hi All, We are building Washington 32 with Wisdom. Washington 32+ Savannah facade+Luxury inclusion + wise choice We have taken below upgrades: Height 2590 mm for ground & Upper floor Sliding doors in wardrobes Study changed to bedroom with sliding door & wardrobe Added shower to powder room 1020 mm entry door upgrade Undermount sink Door below stairs Full 2 walls in ensuite & main bathroom tiled PA for staircase 10000 PA for tiles 6000 PA for Kitchen 4000 PA for electrical 2000 PA for landscaping 5000 Kindly advise about what all you expect we have missed? Also if there are pictures or blogs of washington 32 kindly share. With your entry door, did you upgrade the height as well as the width, or just sticking with standard? We upgraded all our ground floor doors to be 2340 high except our laundry external door. Is your tile PA including the main floor tiles? We went with the included laminate flooring and carpet but a lot of people upgrade here. We also spent $1000ish upgrading the carpet underlay. We spent $7000 on wet area tiling upgrades with a few walls full height tiles that weren't in tender but mostly because I chose more expensive tiles Do you want waterfall ends on your kitchen bench? If not, your budget there will probably be fine. Add $3kish if you want a laundry fit out and another $3k if you want waterfall ends. Your electrical budget is not enough. I'd allow at least $6k here. We spent $9000 with about $2000 to spend after handover (in a 40 square house). Landscaping is also low, you will need a few thousand for your driveway even after the $5000 Wisdom give you. Fencing. Privacy glass in bathrooms. Fly screens and screen doors. NBN. Wiring for speakers in ceilings or home security cameras. If you want a rainforest showerhead that's $800. Also you may want to upgrade your aircon. We didn't upgrade the unit, but we did add an extra controller, an extra zone and added a linear outlet, came to $1000. If you choose to upgrade to a more energy efficient unit it's around $5000. Thanks a ton for your reply MandM+4. It helps a lot. We upgraded main door to 2340*1020 Our plan is for a wood look glazed porcelain tile which would be $(45+ 40)-$25/ m2 With that we think it will be $5280 for main floor. So we may still have something for underlay We are planning to stick too included wet area tile. We have another $2000 included for wet areas to fully tile 2 walls. Privacy glasses tint we have included, i forgot to mention As for Kitchen I guess we have to be happy without the waterfall if thats the case:) Now when you explain, I think we have put 10000 for stairs and that we may end up sharing with electrical. NBN is separately included again forgot to add. As for landscaping that is extra 5000 after 5500 from wisdom. Hope that helps. BuildingWashington 32 with W https://buildyourfirsthome.wordpress.com/ Contract: 26/11/2017 DA: 28/03/2018 Admin : 26/04/2018 Const: 11/05/2018 Slab: 16/05/2018 Re: Building Washington 32 with Wisdom 6Apr 24, 2017 3:07 pm Kvav27 MandM+4 Kvav27 Hi All, We are building Washington 32 with Wisdom. Washington 32+ Savannah facade+Luxury inclusion + wise choice We have taken below upgrades: Height 2590 mm for ground & Upper floor Sliding doors in wardrobes Study changed to bedroom with sliding door & wardrobe Added shower to powder room 1020 mm entry door upgrade Undermount sink Door below stairs Full 2 walls in ensuite & main bathroom tiled PA for staircase 10000 PA for tiles 6000 PA for Kitchen 4000 PA for electrical 2000 PA for landscaping 5000 Kindly advise about what all you expect we have missed? Also if there are pictures or blogs of washington 32 kindly share. With your entry door, did you upgrade the height as well as the width, or just sticking with standard? We upgraded all our ground floor doors to be 2340 high except our laundry external door. Is your tile PA including the main floor tiles? We went with the included laminate flooring and carpet but a lot of people upgrade here. We also spent $1000ish upgrading the carpet underlay. We spent $7000 on wet area tiling upgrades with a few walls full height tiles that weren't in tender but mostly because I chose more expensive tiles Do you want waterfall ends on your kitchen bench? If not, your budget there will probably be fine. Add $3kish if you want a laundry fit out and another $3k if you want waterfall ends. Your electrical budget is not enough. I'd allow at least $6k here. We spent $9000 with about $2000 to spend after handover (in a 40 square house). Landscaping is also low, you will need a few thousand for your driveway even after the $5000 Wisdom give you. Fencing. Privacy glass in bathrooms. Fly screens and screen doors. NBN. Wiring for speakers in ceilings or home security cameras. If you want a rainforest showerhead that's $800. Also you may want to upgrade your aircon. We didn't upgrade the unit, but we did add an extra controller, an extra zone and added a linear outlet, came to $1000. If you choose to upgrade to a more energy efficient unit it's around $5000. Thanks a ton for your reply MandM+4. It helps a lot. We upgraded main door to 2340*1020 Our plan is for a wood look glazed porcelain tile which would be $(45+ 40)-$25/ m2 With that we think it will be $5280 for main floor. So we may still have something for underlay We are planning to stick too included wet area tile. We have another $2000 included for wet areas to fully tile 2 walls. Privacy glasses tint we have included, i forgot to mention As for Kitchen I guess we have to be happy without the waterfall if thats the case:) Now when you explain, I think we have put 10000 for stairs and that we may end up sharing with electrical. NBN is separately included again forgot to add. As for landscaping that is extra 5000 after 5500 from wisdom. Hope that helps. Just with the landscaping, I haven't seen Wisdom quote less than about $8k for driveway, so you'd use at least half your budget for that, but could be plenty more depending on your block. If you wanted a concrete side path or 2 gravel paths that would use up the rest Building Monte Carlo 40- Wisdom homes Re: Building Washington 32 with Wisdom 7Apr 24, 2017 6:11 pm Jenifermarie Kvav27 Hi All, We are building Washington 32 with Wisdom. Washington 32+ Savannah facade+Luxury inclusion + wise choice We have taken below upgrades: Height 2590 mm for ground & Upper floor Sliding doors in wardrobes Study changed to bedroom with sliding door & wardrobe Added shower to powder room 1020 mm entry door upgrade Undermount sink Door below stairs Full 2 walls in ensuite & main bathroom tiled PA for staircase 10000 PA for tiles 6000 PA for Kitchen 4000 PA for electrical 2000 Kindly advise about what all you expect we have missed? Also if there are pictures or blogs of washington 32 kindly share. Hi Kvav I've sent you a PM about staircases. We're still waiting on our kitchen quote but everything added up pretty quick once you start adding all the little extras - soft close drawers and cupboards, extra pot drawers, Riven or Nuance finishes to laminate cupboard, hidden bin in cupboard, extra cabinetry in pantry/butlers pantry. Caesarstone upgrades and/or waterfall ends will bump the price pretty quickly too. We got told at our appointment that if we put in pot drawers but didn't add the soft close to them then they can't hold much weight and don't open all the way out - so essentially it's pointless getting pot drawers without the soft close mechanisms too. The standard range of choices for the poly cupboards and handles are pretty good. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I would say you won't get very much with only $2000 for electrical. Extra double power point or bayonet light fitting are $58 each. $130 per downlight, $120 for double outdoor power point, $140 for a cat6 network point, $412 for a TV antenna, $190 for an external up/down light. We plan to put fans with lights in all the bedrooms except the master - if we do them through wisdom that will be nearly $1500 just for the 3 bedrooms, or $600 just for provisions to install then we still have to buy our own and get an electrician in to fit it all after. Other things we put provisions in for were air con (it's about $6k to step up to the next AC unit that can have more than 2 zones and is more power efficient), colours upgrades (additional paint colours, wood look garage door, tapware changes), landscaping (we only plan to do a driveway and letterbox with Wisdom, but we expect it to cost about $4-5K on top of the voucher they give). Hi Jennifer, Are you able to share with me information about staircases 😃 Thank you! Re: Building Washington 32 with Wisdom 8Apr 24, 2017 8:28 pm Kvav27 MandM+4 Kvav27 Hi All, We are building Washington 32 with Wisdom. Washington 32+ Savannah facade+Luxury inclusion + wise choice We have taken below upgrades: Height 2590 mm for ground & Upper floor Sliding doors in wardrobes Study changed to bedroom with sliding door & wardrobe Added shower to powder room 1020 mm entry door upgrade Undermount sink Door below stairs Full 2 walls in ensuite & main bathroom tiled PA for staircase 10000 PA for tiles 6000 PA for Kitchen 4000 PA for electrical 2000 PA for landscaping 5000 Kindly advise about what all you expect we have missed? Also if there are pictures or blogs of washington 32 kindly share. With your entry door, did you upgrade the height as well as the width, or just sticking with standard? We upgraded all our ground floor doors to be 2340 high except our laundry external door. Is your tile PA including the main floor tiles? We went with the included laminate flooring and carpet but a lot of people upgrade here. We also spent $1000ish upgrading the carpet underlay. We spent $7000 on wet area tiling upgrades with a few walls full height tiles that weren't in tender but mostly because I chose more expensive tiles Do you want waterfall ends on your kitchen bench? If not, your budget there will probably be fine. Add $3kish if you want a laundry fit out and another $3k if you want waterfall ends. Your electrical budget is not enough. I'd allow at least $6k here. We spent $9000 with about $2000 to spend after handover (in a 40 square house). Landscaping is also low, you will need a few thousand for your driveway even after the $5000 Wisdom give you. Fencing. Privacy glass in bathrooms. Fly screens and screen doors. NBN. Wiring for speakers in ceilings or home security cameras. If you want a rainforest showerhead that's $800. Also you may want to upgrade your aircon. We didn't upgrade the unit, but we did add an extra controller, an extra zone and added a linear outlet, came to $1000. If you choose to upgrade to a more energy efficient unit it's around $5000. Thanks a ton for your reply MandM+4. It helps a lot. We upgraded main door to 2340*1020 Our plan is for a wood look glazed porcelain tile which would be $(45+ 40)-$25/ m2 With that we think it will be $5280 for main floor. So we may still have something for underlay We are planning to stick too included wet area tile. We have another $2000 included for wet areas to fully tile 2 walls. Privacy glasses tint we have included, i forgot to mention As for Kitchen I guess we have to be happy without the waterfall if thats the case:) Now when you explain, I think we have put 10000 for stairs and that we may end up sharing with electrical. NBN is separately included again forgot to add. As for landscaping that is extra 5000 after 5500 from wisdom. Hope that helps. The wood look tiles also have extra laying costs attached. We had a 35square house and the quote was about $8000 Definitely add more to your electrical! We did very basic fit out and spent $4000. Kitchen PA is definitely tight. Integrated bin is about $800 alone. Landscaping will be ok for driveway and maybe a small path but not much more. Good luck with it all, very exciting majestic35.weebly.com Re: Building Washington 32 with Wisdom 9Apr 27, 2017 6:18 pm Has anyone build washington 32 and have a blog link to it. I really want to see some washington 32 blogs .Kindly help. BuildingWashington 32 with W https://buildyourfirsthome.wordpress.com/ Contract: 26/11/2017 DA: 28/03/2018 Admin : 26/04/2018 Const: 11/05/2018 Slab: 16/05/2018 Re: Building Washington 32 with Wisdom 10May 08, 2017 11:13 am Hi I was going through the thread. I am a looking to build my home with Wisdom. I will most likely go with the Washington 32 design. How was your experience with Wisdom and how long did the planning process take right from contract signing date to Council approval stage. Did you get your building approved with CDC or did you apply for DA? Thanks, Re: Building Washington 32 with Wisdom 11Nov 27, 2017 2:19 pm homealone Hi I was going through the thread. I am a looking to build my home with Wisdom. I will most likely go with the Washington 32 design. How was your experience with Wisdom and how long did the planning process take right from contract signing date to Council approval stage. Did you get your building approved with CDC or did you apply for DA? Thanks, we just sign our contract. we are waiting for land registration and appointments BuildingWashington 32 with W https://buildyourfirsthome.wordpress.com/ Contract: 26/11/2017 DA: 28/03/2018 Admin : 26/04/2018 Const: 11/05/2018 Slab: 16/05/2018 Re: Building Washington 32 with Wisdom 12Nov 27, 2017 2:23 pm Kindly help: viewtopic.php?f=31&t=90378&p=1771649 BuildingWashington 32 with W https://buildyourfirsthome.wordpress.com/ Contract: 26/11/2017 DA: 28/03/2018 Admin : 26/04/2018 Const: 11/05/2018 Slab: 16/05/2018 Hi, guys! If you've built with Wisdom Homes, would you mind sharing images of your front facades once they're all rendered? I'm considering signing up with them for a wide… 0 13886 Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18466 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73474 |
