Browse Forums Building A New House 1 Apr 20, 2017 5:57 pm Hi all, I am building Banksia 24 (double storey) with Eden Brae home. I am not sure which place I should pick it up for the rainwater location. Here are the options with number 1, 2 and 3 highlighted with green circles Option 1 & 2 - it will look ugly in the backyard Option 3 - access space will be only 30cm from laundry to backyard after putting the slimline water tank Option 4 - under slab rainwater tank. It's expensive and cost me around $3600. Much appreciate your advise. Thank you. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Rainwater location (new build) 2Apr 20, 2017 7:28 pm Option 3 isn't actually an option, you need 400mm clearance between tank and fence line, that's why we couldn't have ours in a similar location, if you don't want it in the backyard (you could build a screen to hide it from view), you'll need to put it on the other side of the house Re: Rainwater location (new build) 3Apr 20, 2017 8:41 pm Can you place it in the back corner of your yard? Then like pp said screen it. We moved ours to front backyard to keep it out of my view and really it was a dead spot. At the time it stood out but now fencing is up you don't notice it so much from the front and it's out of my main view area of my house as the only window that opens to it is a bathroom so no one really opens it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ So kinda out there before fencing. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kinda not a great photo as I haven't done a front view photo since fencing. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Looking from back to front - while landscaping. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Part of view I didn't want to lose. ~Shellby~ GJ Bridgewater 203 11/3/2016 - Site Work Started 29/9/2016 - Handover 142 Work Days 6 Work Days Over https://forum.homeone.com.au/viewtopic.php?f=31&t=80174 Re: Rainwater location (new build) 4Apr 20, 2017 9:40 pm Hi Joanna, Thank you for your response. Are you referring to option 2? Re: Rainwater location (new build) 5Apr 20, 2017 9:46 pm Thank you Shellby for your response. I really appreciate it. Not sure if technically I can keep it in the corner. I will find it out. I am inclining towards to option 2 and thinking to install the clothes line next to rainwater tank in the corner? What's your opinion on this? Cheers, Badal Re: Rainwater location (new build) 6Apr 20, 2017 10:43 pm Badal Ratra Hi all, I am building Banksia 24 (double storey) with Eden Brae home. I am not sure which place I should pick it up for the rainwater location. Here are the options with number 1, 2 and 3 highlighted with green circles Option 1 & 2 - it will look ugly in the backyard Option 3 - access space will be only 30cm from laundry to backyard after putting the slimline water tank Option 4 - under slab rainwater tank. It's expensive and cost me around $3600. Much appreciate your advise. Thank you. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Can you put it on the other side of the house, the non garage side? You have your AC unit there anyway, so already some of the side partially blocked. Building Monte Carlo 40- Wisdom homes Re: Rainwater location (new build) 8May 20, 2017 4:01 pm The company that Eden Brae use for watertanks is Kingspan/tankworks. They build custom tanks - have you considered a longer thinner tank for down the side? We are putting one at the rear of our Jasper 28Mk2 against the back wall, but due to the window height, we are getting custom to fit under the window as the standard slimline is too high. https://kingspanwater.com.au Re: Rainwater location (new build) 9May 20, 2017 5:19 pm That tank's overflow has no mitigation, it is a terrible design. I hope that you are not harvesting a large roof area. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31286 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19521 There is a whole lot more to know than just the answers you seek but they are a good start. Overflow outlets have a mosquito proof mesh. These… 3 8434 |
