Browse Forums Building A New House Re: NBN - should we be adding to a new build? 3Apr 19, 2017 2:40 pm It's not actually a case of "do we need it". It's more a case of "has NBN been switched on yet in my area?". If it has, then yes you should absolutely get an NBN box in your house... if you are in an NBN-active area then they can't connect you up to the old copper network, you have to go onto the new fibre network. EG if you live in an NBN area, and you want a phone line or internet in the house, it must be NBN. If you're not in an NBN area yet, find out when NBN will be coming to you. Once it comes to you, 2 years from the date it's switched on, all copper phone lines and old ADSL modems won't work anymore, they all transition over to NBN. Re: NBN - should we be adding to a new build? 4Apr 19, 2017 2:42 pm Ratnesh Hi Ezza, It better to do NBN wiring in the house it will affect speed of internet. in future all houses will have NBN in new estates it is compulsory to have NBN wiring in house Ta Thanks Ratnesh - which option/package did you choose? Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4922 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16270 hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 21173 |
