Browse Forums Building A New House 1 Apr 05, 2017 11:49 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our Builder have asked me to get the info reg the depth, offset and Dia of the storm water drain. i have uploaded the image of the Plan of subdivision, they have got the information re the sewer, how to read this plan thanks Anand Re: how to find information related to Storm-water drain dep 3Apr 05, 2017 9:30 pm Would have thought that's what builders get paid for... unless it's not on the councils area maps yet (they all have this info available online). The plan is too small to read. how to find information related to Storm-water drain depth, 4Apr 06, 2017 12:47 am Hello rsanand, What your after is your individual lots As Con. A as con is the infrastructure information for your block it shows all the pipe gauge sizes for storm water, sewer and it also shows easements and any technical information required by the builder. What you have is your stage as con which is great, but your lot as con will show your builder exactly what they need. If your land hasn't registered yet give the developer a call as they will have a preliminary as con as it was required to lodge to council for the original sub division. If your land had registered then council will have a stamped and certified copy on file. Good luck Re: how to find information related to Storm-water drain dep 5Apr 19, 2017 6:41 pm Thanks fortunately there is a company that the builders use to collect all those information on behalf of the builder, the information was delayed, it arrived couple of days later. thanks for the Help. the company they use is called PSI http://www.psivic.com.au/ thanks Anand 2 6288 Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 6317 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 5668 |
