Browse Forums Building A New House Re: Metricon Winchester 28- Home Straight 821Aug 08, 2018 11:46 am bank I don't have access to it any more, it was on the boundary, but I'll look through my construction photos and see what I can find. It is was the same as Trippypossums except it extends 1.5m. Very common in estates where the guidelines state that facade materials must return a certain distance. Re: Metricon Winchester 28- Home Straight 822Aug 08, 2018 12:14 pm blackcat20 bank I don't have access to it any more, it was on the boundary, but I'll look through my construction photos and see what I can find. It is was the same as Trippypossums except it extends 1.5m. Very common in estates where the guidelines state that facade materials must return a certain distance. Over 3000 photos and I found 1 that shows it, and not very close. It definitely can be done and up above your head there really shouldn't be any concern about the edge being damaged. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: Metricon Winchester 28- Home Straight 823Aug 08, 2018 12:16 pm bank blackcat20 bank I don't have access to it any more, it was on the boundary, but I'll look through my construction photos and see what I can find. It is was the same as Trippypossums except it extends 1.5m. Very common in estates where the guidelines state that facade materials must return a certain distance. Over 3000 photos and I found 1 that shows it, and not very close. It definitely can be done and up above your head there really shouldn't be any concern about the edge being damaged. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: Metricon Winchester 28- Home Straight 824Aug 10, 2018 9:11 am Re: Metricon Winchester 28- Home Straight 826Aug 10, 2018 6:28 pm Looking really good inside, the paint really lightens the whole place. Supervisor is going to run my render suggestion past the big boss so hopefully that will be a good resolution. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Metricon Winchester 28- Home Straight 827Aug 11, 2018 1:13 pm blackcat20 Looking really good inside, the paint really lightens the whole place. Supervisor is going to run my render suggestion past the big boss so hopefully that will be a good resolution. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You chose a white for walls. What colour White is that? Re: Metricon Winchester 28- Home Straight 828Aug 11, 2018 1:16 pm sandymeo blackcat20 Looking really good inside, the paint really lightens the whole place. Supervisor is going to run my render suggestion past the big boss so hopefully that will be a good resolution. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You chose a white for walls. What colour White is that? Re: Metricon Winchester 28- Home Straight 829Aug 16, 2018 5:48 pm Re: Metricon Winchester 28- Home Straight 830Aug 16, 2018 5:50 pm Re: Metricon Winchester 28- Home Straight 831Aug 16, 2018 6:01 pm Looks amazing....how long did painting take. Ours just started painting today. https://r.tapatalk.com/shareLink?url=ht ... are_type=t Re: Metricon Winchester 28- Home Straight 832Aug 16, 2018 6:12 pm Just over a week for the painting. When we went last Friday they had finished the ceilings and done one coat in the walls. Re: Metricon Winchester 28- Home Straight 833Aug 16, 2018 7:54 pm blackcat20 Just over a week for the painting. When we went last Friday they had finished the ceilings and done one coat in the walls. I can’t believe the pace of the build! Such a great result after your admin nightmare. Did you get a resolution re the render? Re: Metricon Winchester 28- Home Straight 834Aug 16, 2018 8:00 pm shokel1975 blackcat20 Just over a week for the painting. When we went last Friday they had finished the ceilings and done one coat in the walls. I can’t believe the pace of the build! Such a great result after your admin nightmare. Did you get a resolution re the render? Re: Metricon Winchester 28- Home Straight 835Aug 16, 2018 8:06 pm blackcat20 shokel1975 blackcat20 Just over a week for the painting. When we went last Friday they had finished the ceilings and done one coat in the walls. I can’t believe the pace of the build! Such a great result after your admin nightmare. Did you get a resolution re the render? Oh bugger.... maybe start looking at ways you can dress up the entry to your liking - maybe something hanging on the wall to the RHS of door to hide the render a little? Re: Metricon Winchester 28- Home Straight 838Aug 16, 2018 11:15 pm That window splashback is stealing the spotlight! PCI next month so it only takes 4 months for the build?! That pace is unbelievable! Re: Metricon Winchester 28- Home Straight 840Aug 17, 2018 8:00 am Kimmykim That window splashback is stealing the spotlight! PCI next month so it only takes 4 months for the build?! That pace is unbelievable! Hmmm, I have checked your past posts and it seems that you are in NSW, not WA as I had thought. It pays to show your State in your avatar. Retaining wall regulations… 5 7966 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35561 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 13835 |
