Browse Forums Building A New House Re: Metricon Winchester 28- Started...then stopped again. 461May 10, 2018 12:08 pm We were told they would do it. Re: Metricon Winchester 28- Started...then stopped again. 462May 10, 2018 12:56 pm That's unusual unless they've sold you a house and land package Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Started...then stopped again. 463May 10, 2018 12:59 pm Drew01 That's unusual unless they've sold you a house and land package Re: Metricon Winchester 28- Started...then stopped again. 464May 10, 2018 1:04 pm blackcat20 Drew01 That's unusual unless they've sold you a house and land package Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Started...then stopped again. 465May 10, 2018 2:28 pm I honestly don't know. It was damaged prior to settlement and the developer is repairing it anyway. Re: Metricon Winchester 28- Started...then stopped again. 466May 10, 2018 2:40 pm blackcat20 I honestly don't know. It was damaged prior to settlement and the developer is repairing it anyway. Hi Blackcat20, Just read your whole ordeal! The delays must drive you crazy. We are also building in Belmond Estate - Stage 18. Land settles 1st June. We are building with Fairhaven. The process has bee really smooth so far. We did consider Metricon but they were extremely rude at display home and on the phone so we did not go ahead with them. Can you share some tips regarding permits with council and estate that we need to be mindful off? Which stage are you in? Thanks Re: Metricon Winchester 28- Started...then stopped again. 467May 10, 2018 3:50 pm Bronte19 blackcat20 I honestly don't know. It was damaged prior to settlement and the developer is repairing it anyway. Hi Blackcat20, Just read your whole ordeal! The delays must drive you crazy. We are also building in Belmond Estate - Stage 18. Land settles 1st June. We are building with Fairhaven. The process has bee really smooth so far. We did consider Metricon but they were extremely rude at display home and on the phone so we did not go ahead with them. Can you share some tips regarding permits with council and estate that we need to be mindful off? Which stage are you in? Thanks We're stage 15. No tips really, the builder takes care of permits. But you will need to ring Casey to pay the compulsory infrastructure levy, they wont issue a permit without it. Check if your builder is doing the asset protection permit; we were told they were but they clearly havent so we're trying to sort that out and get back on track. Re: Metricon Winchester 28- Started...then stopped again. 468May 10, 2018 4:43 pm blackcat20 Bronte19 blackcat20 I honestly don't know. It was damaged prior to settlement and the developer is repairing it anyway. Hi Blackcat20, Just read your whole ordeal! The delays must drive you crazy. We are also building in Belmond Estate - Stage 18. Land settles 1st June. We are building with Fairhaven. The process has bee really smooth so far. We did consider Metricon but they were extremely rude at display home and on the phone so we did not go ahead with them. Can you share some tips regarding permits with council and estate that we need to be mindful off? Which stage are you in? Thanks We're stage 15. No tips really, the builder takes care of permits. But you will need to ring Casey to pay the compulsory infrastructure levy, they wont issue a permit without it. Check if your builder is doing the asset protection permit; we were told they were but they clearly havent so we're trying to sort that out and get back on track. Ok thanks. Yes, I was told about the compulsory infrastructure fee of around $1,100 by my conveyancer. Do you live close to Belmond estate? We live 40kms away. Going each week once build start will be a hassle. Anyway, wishing you smooth build from here, good luck. Re: Metricon Winchester 28- Started...then stopped again. 469May 10, 2018 5:14 pm Bronte19 blackcat20 Bronte19 [quote="blackcat20"]I honestly don't know. It was damaged prior to settlement and the developer is repairing it anyway. Hi Blackcat20, Just read your whole ordeal! The delays must drive you crazy. We are also building in Belmond Estate - Stage 18. Land settles 1st June. We are building with Fairhaven. The process has bee really smooth so far. We did consider Metricon but they were extremely rude at display home and on the phone so we did not go ahead with them. Can you share some tips regarding permits with council and estate that we need to be mindful off? Which stage are you in? Thanks We're stage 15. No tips really, the builder takes care of permits. But you will need to ring Casey to pay the compulsory infrastructure levy, they wont issue a permit without it. Check if your builder is doing the asset protection permit; we were told they were but they clearly havent so we're trying to sort that out and get back on track. Ok thanks. Yes, I was told about the compulsory infrastructure fee of around $1,100 by my conveyancer. Do you live close to Belmond estate? We live 40kms away. Going each week once build start will be a hassle. Anyway, wishing you smooth build from here, good luck.[/quote] We live about 30 minutes away at the moment. You can pay the levy whenever, even before settlement. Just call and do it over the phone. Re: Metricon Winchester 28- Started...then stopped again. 470May 10, 2018 5:15 pm M are all over the permit issue so no stress apparently. It was them that was meant to apply, will have it sorted tomorrow. Re: Metricon Winchester 28- Started...then stopped again. 471May 10, 2018 9:37 pm blackcat20 M are all over the permit issue so no stress apparently. It was them that was meant to apply, will have it sorted tomorrow. I'm so glad to hear things are going to move forward. You will forget these delays once the build is over. Re: Metricon Winchester 28- Started...then stopped again. 472May 11, 2018 7:53 am I've also been told our site supervisor is really good by others in our estate so that's a positive. Away this weekend but hopefully can go sticky beak Tuesday after work to see what's happening. Re: Metricon Winchester 28- Started...then stopped again. 473May 11, 2018 8:37 am Good to hear! Something has to start going right for you!! Re: Metricon Winchester 28- Started...then stopped again. 474May 11, 2018 8:55 am shokel1975 Good to hear! Something has to start going right for you!! Agree! Though I don't think I'll start believing we're actually building a house till I get a chance to see whats happening. At the moment its all a bit theoretical to me. Re: Metricon Winchester 28- Finally Started! 475May 12, 2018 10:40 am Had a good chat with our independent inspector yesterday to start lining things up. They were quite surprised with how bad our admin stage has been. Of course they need the slab supervisors details to organise an inspection and I don’t have them. Called yesterday but still waiting for a call back with the info we need. I did manage to get the site supervisors number though. Re: Metricon Winchester 28- Finally Started! 476May 12, 2018 11:13 am blackcat20 Had a good chat with our independent inspector yesterday to start lining things up. They were quite surprised with how bad our admin stage has been. Of course they need the slab supervisors details to organise an inspection and I don’t have them. Called yesterday but still waiting for a call back with the info we need. I did manage to get the site supervisors number though. Re: Metricon Winchester 28- Finally Started! 477May 12, 2018 11:28 am I heard there should be a sign in on Metricon where you can check all your progress and stuff. It’s something like my metricon.com viewtopic.php?t=86597 Re: Metricon Winchester 28- Finally Started! 478May 12, 2018 12:09 pm The My Metricon total still shows us as Pre Construction, no one has updated it. We have the site supervisor details but not the supervisor for the slab pour. Re: Metricon Winchester 28- Finally Started! 479May 12, 2018 12:09 pm Renman blackcat20 Had a good chat with our independent inspector yesterday to start lining things up. They were quite surprised with how bad our admin stage has been. Of course they need the slab supervisors details to organise an inspection and I don’t have them. Called yesterday but still waiting for a call back with the info we need. I did manage to get the site supervisors number though. Re: Metricon Winchester 28- Finally Started! 480May 12, 2018 1:29 pm blackcat20 Renman blackcat20 Had a good chat with our independent inspector yesterday to start lining things up. They were quite surprised with how bad our admin stage has been. Of course they need the slab supervisors details to organise an inspection and I don’t have them. Called yesterday but still waiting for a call back with the info we need. I did manage to get the site supervisors number though. Hmmm, I have checked your past posts and it seems that you are in NSW, not WA as I had thought. It pays to show your State in your avatar. Retaining wall regulations… 5 8013 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35647 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 13895 |
