There are no bricks upstairs, its only a small section around the door.
Browse Forums Building A New House Re: Metricon Winchester 28- Home Straight 781Aug 06, 2018 1:03 pm MyFirst My question is , can it really be fixed without removing all the rendered bricks around the door and then also the bricks on the 1st floor above it? There are no bricks upstairs, its only a small section around the door. Metricon Winchester 28- Home Straight 782Aug 06, 2018 1:15 pm I wouldn’t even accept the metal. As much as you think it would be ok. I don’t think it would look great too be honest. It would make it all look out of whack. But In saying that if they made the mistake. I would take it higher up. That’s not good enough. And if something was to change like that along the way. He should have contacted you. That’s not very good practice at all. viewtopic.php?t=86597 Re: Metricon Winchester 28- Home Straight 783Aug 06, 2018 1:17 pm Essentially they are saying that because the side of the portico is rendered, they have to continue around to the front door. I think thats a load of you know what. I certainly think they should have discussed that with us rather than going ahead and doing it. Trying to get hold of our BSC now. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Metricon Winchester 28- Home Straight 784Aug 06, 2018 1:18 pm Doulton777 I wouldn’t even accept the metal. As much as you think it would be ok. I don’t think it would look great too be honest. It would make it all look out of whack. But In saying that if they made the mistake. I would take it higher up. That’s not good enough. And if something was to change like that along the way. He should have contacted you. That’s not very good practice at all. viewtopic.php?t=86597 I agree. We paid for brick deliberately and I dont think the render should have overridden that without discussion or permission. I'd have rather we removed the render from the build if that was the case. Re: Metricon Winchester 28- Home Straight 785Aug 06, 2018 1:23 pm blackcat20 Essentially they are saying that because the side of the portico is rendered, they have to continue around to the front door. I think thats a load of you know what. I certainly think they should have discussed that with us rather than going ahead and doing it. Trying to get hold of our BSC now. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I can see what your SS is saying. If the arrow down side is not rendered while the brick wall behind (ie. portico side) it been rendered. The corner of the render will be exposed and chipped off over time. It will definitely look weird. Re: Metricon Winchester 28- Home Straight 786Aug 06, 2018 1:26 pm MyFirst blackcat20 Essentially they are saying that because the side of the portico is rendered, they have to continue around to the front door. I think thats a load of you know what. I certainly think they should have discussed that with us rather than going ahead and doing it. Trying to get hold of our BSC now. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I can see what your SS is saying. If the arrow down side is not rendered while the brick wall behind (ie. portico side) it been rendered. The corner of the render will be exposed and chipped off over time. It will definitely look weird. Which is why they use a metal cap. I also understand what they are saying but it should never have been done without discussion. Re: Metricon Winchester 28- Home Straight 787Aug 06, 2018 1:31 pm blackcat20 MyFirst blackcat20 Essentially they are saying that because the side of the portico is rendered, they have to continue around to the front door. I think thats a load of you know what. I certainly think they should have discussed that with us rather than going ahead and doing it. Trying to get hold of our BSC now. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I can see what your SS is saying. If the arrow down side is not rendered while the brick wall behind (ie. portico side) it been rendered. The corner of the render will be exposed and chipped off over time. It will definitely look weird. Which is why they use a metal cap. I also understand what they are saying but it should never have been done without discussion. What do you think you will do blackcat20 ? Are you going to accept the option to have the metal strip, if they can in fact remove the render? I agree, that while it isn't ideal, I would much prefer the metal strip to the full render, if I felt as strongly about the render as you do. It is so hard to pick up everything from looking at the plans - especially when there is no clear notation about what the finish is going to be. Good luck! Re: Metricon Winchester 28- Home Straight 788Aug 06, 2018 1:35 pm shokel1975 blackcat20 Which is why they use a metal cap. I also understand what they are saying but it should never have been done without discussion. What do you think you will do blackcat20 ? Are you going to accept the option to have the metal strip, if they can in fact remove the render? I agree, that while it isn't ideal, I would much prefer the metal strip to the full render, if I felt as strongly about the render as you do. It is so hard to pick up everything from looking at the plans - especially when there is no clear notation about what the finish is going to be. Good luck! I would honestly prefer the metal strip. At least it could be painted to be less obvious. I would never in a million years have chosen grey render around the door if it was going to be rendered. Its dull, I hate it, and its the first thing I'm going to see every time I walk into my dream home. The problem is going to be convincing them to remove it even though its not as per our plans/contracts etc. Re: Metricon Winchester 28- Home Straight 789Aug 06, 2018 1:47 pm blackcat20 shokel1975 blackcat20 Which is why they use a metal cap. I also understand what they are saying but it should never have been done without discussion. What do you think you will do blackcat20 ? Are you going to accept the option to have the metal strip, if they can in fact remove the render? I agree, that while it isn't ideal, I would much prefer the metal strip to the full render, if I felt as strongly about the render as you do. It is so hard to pick up everything from looking at the plans - especially when there is no clear notation about what the finish is going to be. Good luck! I would honestly prefer the metal strip. At least it could be painted to be less obvious. I would never in a million years have chosen grey render around the door if it was going to be rendered. Its dull, I hate it, and its the first thing I'm going to see every time I walk into my dream home. The problem is going to be convincing them to remove it even though its not as per our plans/contracts etc. Maybe asked for them to re-render it with a color of your choice.? That should be an easier job, just scrap off the render and re-render... and then refund you the extra payment for the brick. Re: Metricon Winchester 28- Home Straight 790Aug 06, 2018 1:49 pm MyFirst Maybe asked for them to re-render it with a color of your choice.? That should be an easier job, just scrap off the render and re-render... and then refund you the extra payment for the brick. I want the brick though. What I dont understand is why it was rendered correctly a week ago.... Re: Metricon Winchester 28- Home Straight 791Aug 06, 2018 1:59 pm What happens as the rendering technician turns a corner using standard plastic edge. Explains a deal as to why issue has emerged. 1412_preptorendercorners_25.jpg Re: Metricon Winchester 28- Home Straight 792Aug 06, 2018 2:01 pm blackcat20 MyFirst Maybe asked for them to re-render it with a color of your choice.? That should be an easier job, just scrap off the render and re-render... and then refund you the extra payment for the brick. I want the brick though. What I dont understand is why it was rendered correctly a week ago.... sending you a PM Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Home Straight 793Aug 06, 2018 2:05 pm Yep I agree stand your ground. It’s not good enough. They can’t do something this major without notifying you first. I would go higher up then the BC. I really hope it all works out for you. viewtopic.php?t=86597 Re: Metricon Winchester 28- Home Straight 794Aug 06, 2018 2:13 pm kks What happens as the rendering technician turns a corner using standard plastic edge. Explains a deal as to why issue has emerged. 1412_preptorendercorners_25.jpg I completely understand the logistics of it but I think it and the alternatives should have been discussed with us rather than someone just deciding the knew best. A better option (to me) would be to render to the corner then cap with a metal strip, probably black to match the window and door frames. Just spoke to our BSC who completely understands and is going to follow up; I've said I would much prefer the above so she's going to see if that can be done. I feel like I'm being unreasonably stubborn but I also don't want to be pushed into something I hate. And she agreed the fact its not on the plans means we arent obliged to accept it. Re: Metricon Winchester 28- Home Straight 795Aug 06, 2018 2:16 pm blackcat20 kks What happens as the rendering technician turns a corner using standard plastic edge. Explains a deal as to why issue has emerged. 1412_preptorendercorners_25.jpg I completely understand the logistics of it but I think it and the alternatives should have been discussed with us rather than someone just deciding the knew best. A better option (to me) would be to render to the corner then cap with a metal strip, probably black to match the window and door frames. Just spoke to our BSC who completely understands and is going to follow up; I've said I would much prefer the above so she's going to see if that can be done. I feel like I'm being unreasonably stubborn but I also don't want to be pushed into something I hate. And she agreed the fact its not on the plans means we arent obliged to accept it. You are absolutely not being 'unreasonably stubborn'.... this is the front of your house - the biggest investment of your life. You have to love it & it has to be right for you. Don't let them push you around.... keep at em! You are already being reasonable by accepting the option of having the strip. You are completely within your rights. Re: Metricon Winchester 28- Home Straight 796Aug 06, 2018 2:19 pm shokel1975 You are absolutely not being 'unreasonably stubborn'.... this is the front of your house - the biggest investment of your life. You have to love it & it has to be right for you. Don't let them push you around.... keep at em! You are already being reasonable by accepting the option of having the strip. You are completely within your rights. Most definitely; the most I ever spent before was my car I do really like our BSC, and she really is doing her best to make it so I'm happy. Really hope it can be resolved. My poor husband, I don't think he really cared (except for the fact we'd paid extra for the brick) but he can see just how unhappy I am with it. I get very set on having things a certain way and I do not like change. Re: Metricon Winchester 28- Home Straight 797Aug 06, 2018 4:55 pm I think it looks better like this. But they still shouldn't have done it without asking. Re: Metricon Winchester 28- Home Straight 798Aug 06, 2018 5:06 pm craigo I think it looks better like this. But they still shouldn't have done it without asking. And I think it looks terrible 😞 The mock up on the M Website shows it how I expected it to look. Nothing like a bit of false advertising. Re: Metricon Winchester 28- Home Straight 799Aug 06, 2018 5:24 pm If they end up putting the steel up. Make sure you get a refund for your bricks that you paid extra for. viewtopic.php?t=86597 Re: Metricon Winchester 28- Home Straight 800Aug 07, 2018 8:18 am Hmmm, I have checked your past posts and it seems that you are in NSW, not WA as I had thought. It pays to show your State in your avatar. Retaining wall regulations… 5 7917 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35452 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 13732 |
