The island is 2632 and the under window bench is around 3310.
Browse Forums Building A New House Re: Metricon Winchester 28- Home Straight 847Aug 17, 2018 6:24 pm blackcat20 Bronte19 The white paint looks really good. What's the length of your kitchen bench and island? The island is 2632 and the under window bench is around 3310. That's great. Your bench is good length. Re: Metricon Winchester 28- Home Straight 848Aug 17, 2018 11:32 pm excited_builders When they cleaned our bricks, we noticed the flaws with the mortar....like holes in some areas or gaps, different coloured mortar on a full wall.....the new SM said they will be fixing that in the next week. The Brick company probably came too early to do their QA or check. https://r.tapatalk.com/shareLink?url=ht ... are_type=t The mortar getting washed out is pretty normal, we've got quite a lot like that, they'll patch it up and you won't even know the difference Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Home Straight 850Aug 18, 2018 8:52 pm MyFirst I thought expose down pipe where water just run down the brick wall and then to the slab Isn't that a big no no? Definitely a big no no. Once the bricks have been cleaned they'll attach th remainder of the down pipe and connect it. Re: Metricon Winchester 28- Home Straight 851Aug 18, 2018 8:56 pm blackcat20 MyFirst I thought expose down pipe where water just run down the brick wall and then to the slab Isn't that a big no no? Definitely a big no no. Once the bricks have been cleaned they'll attach th remainder of the down pipe and connect it. They should have temporary plastic down pipe to direct water away during construction stage. Re: Metricon Winchester 28- Home Straight 852Aug 18, 2018 9:00 pm MyFirst blackcat20 MyFirst I thought expose down pipe where water just run down the brick wall and then to the slab Isn't that a big no no? Definitely a big no no. Once the bricks have been cleaned they'll attach th remainder of the down pipe and connect it. They should have temporary plastic down pipe to direct water away during construction stage. Re: Metricon Winchester 28- Home Straight 853Aug 20, 2018 10:02 am Re: Metricon Winchester 28- Home Straight 855Aug 20, 2018 10:21 am I found getting a response from fencing contractors like playing Russian Roulette... I rang 11, and 2 got back to me... End up with the third quote from a guy who travels down from South Seymour via word of mouth, and he was the cheapest quote... Go figure Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Home Straight 856Aug 20, 2018 10:27 am I went with Endless fencing. The price was very reasonable for two side fences and a merbau gate. Their work looks good too. Re: Metricon Winchester 28- Home Straight 857Aug 20, 2018 11:04 am Drew01 I found getting a response from fencing contractors like playing Russian Roulette... I rang 11, and 2 got back to me... End up with the third quote from a guy who travels down from South Seymour via word of mouth, and he was the cheapest quote... Go figure I have that problem at well. Rang many but only 2 called back. 😓 Re: Metricon Winchester 28- Home Straight 859Aug 20, 2018 11:07 am Looks promising! So near to finishing line! Do you have any idea how long will be from PCI to handover? Re: Metricon Winchester 28- Home Straight 860Aug 20, 2018 11:14 am Kimmykim Looks promising! So near to finishing line! Do you have any idea how long will be from PCI to handover? Hmmm, I have checked your past posts and it seems that you are in NSW, not WA as I had thought. It pays to show your State in your avatar. Retaining wall regulations… 5 5596 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 31778 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 10315 |
