Browse Forums Building A New House Re: Your Connected Home. What have you done / what do you ne 23Apr 20, 2017 3:55 pm arcadelt parawolf Wires are far from dead. You make a lot of good points, but there are always alternatives. Many wireless solutions are often at lower initial and total ownership cost. Madora Dreamer I am totally new at this but do like techno stuff. I have allowed a $10000 budget for smart wiring. Things I would like are lighting, aircon, security system, multi room audio. Some examples based on functionality the OP suggested he or she might want include: Philips Hue smart lighting Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Nest Thermostats Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Netgear Arlo security cameras Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Elgato Eve security sensors Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sonos multi-room audio Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any thoughts on using the Sonos system as a home theatre system in a theatre room? I'm tossing up between getting a normal wired system in place vs a Sonos or Bose (or whoever else) wireless system. I've got plenty of power points in place so that I can go with the wireless if I want, but not sure what the sound quality is like compared to an equivalently priced wired system. I'd probably be looking at about $3-5k either way. Building a Kew 28 with Porter Davis Your Connected Home. What have you done / what do you need? 24Apr 20, 2017 5:40 pm I have a Sonos 5.1 system plus about six other zones. I have had wired 5.1, 6.1 and 7.1 systems in the past. The difference is not so marked that it would outstrip the convenience of the Sonos. That is not to say the the Sonos doesn't sound good too, as IMHO it sounds just as good, but you need the right TV to get real 5.1. Better still, the Sonos just keeps getting better because they constantly upgrade the software. Re: Your Connected Home. What have you done / what do you ne 25Apr 20, 2017 10:32 pm scubabe I'm loving this thread. Not investing tooooooo much $ in home tech as this isn't my forever home, just a starter home. But I am wiring every room (sparky today said "gee you've got a lot of network cabling..." and getting the Ubiquiti UniFi AC Pro ceiling mounted in the rear of the house. Getting a TP-Link Gigabit switch with POE for the WAP and possible future video cameras with POE. Front door will have a Ring Pro doorbell and an electronic door lock - currently looking at the Kwikset Kevo with Kevo Plus gateway to allow me to open it from anywhere... but have read a few people having issues with a possible geoblock on the Kevo Plus, so I have more research to do there. Oh, and yes I want a watering controller too. And a robot vacuum and possibly a robot mower as well, just starting research on them at the moment. I *love* technology In relation to KEVO, watch this. https://youtu.be/H1mmjVvMsGs Im presently using a $99 Touch Screen Digital Deadbolt Door Lock (from the old Masters!) Works well but has some light delamination (like the thin plastic film on the your mobile phone when you first get it) Re: Your Connected Home. What have you done / what do you ne 26Apr 21, 2017 1:14 pm arcadelt I have a Sonos 5.1 system plus about six other zones. I have had wired 5.1, 6.1 and 7.1 systems in the past. The difference is not so marked that it would outstrip the convenience of the Sonos. That is not to say the the Sonos doesn't sound good too, as IMHO it sounds just as good, but you need the right TV to get real 5.1. Better still, the Sonos just keeps getting better because they constantly upgrade the software. I think Sonos would certainly be useful in terms of being an easy setup for being able to play music throughout the house etc so that would be good. If it's fine for a home theatre as well then that's ideal, particularly with the upgrades. Any thoughts on what the right TV's are for getting 5.1? Building a Kew 28 with Porter Davis Re: Your Connected Home. What have you done / what do you ne 27Apr 21, 2017 1:44 pm Hurrow Any thoughts on what the right TV's are for getting 5.1? When you use Sonos for your home theatre, you use the TV as the source switcher, similar to how surround receivers used to be used. You need a TV that can pass Dolby 5.1 to the Sonos Playbar, otherwise the Sonos system will only provide digitised surround sound (still good, but not the fullest extent of its capabilities). In my testing, Sony is good but Samsung not. I have not installed with other brands. Re: Your Connected Home. What have you done / what do you ne 28Apr 22, 2017 4:11 pm Madora Dreamer Do I need a plan before Pre start do you know? Will I need to get an external party in to do it during the build? I have a house/land package in Perth with Redink Ideally planned along with electrical design and installed during build. Locations for optimal wifi coverage both internal and out, and wired connections and their centralised patch need to be installed at the same time as electrical. Ideally run in conduit so if it needs to be replaced it can be done. Most sparkies can do data cabling and know the requirements around separation and crossover points when installed in a wall Re: Your Connected Home. What have you done / what do you ne 29Apr 22, 2017 4:18 pm Personally I wouldnt bother too much with data cabling in a house. I'd spend my money elsewhere. Wireless is generally fine. I'd run a few cat6 outlets behind the TV and a couple to the office/study. Maybe one or two outlets to prime locations for WiFi routers. I actually am a licenced cabler so I ran 12 cat6 data outlets through my house and the only ones I use are for the smart TV (Netflix), XBox, and my wife's home office computer. If I had to pay someone to do it I wouldn't have bothered. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Your Connected Home. What have you done / what do you ne 30Apr 22, 2017 4:20 pm parawolf Most sparkies can do data cabling and know the requirements around separation and crossover points when installed in a wall I dare say a lot of them know how to do it but do not have the legally required Open Cablers licence with structured cabling endorsement... Just something to keep in mind... Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Your Connected Home. What have you done / what do you ne 31Apr 22, 2017 6:15 pm 1960sModernistHome Personally I wouldnt bother too much with data cabling in a house. I'd spend my money elsewhere. Wireless is generally fine. I'd run a few cat6 outlets behind the TV and a couple to the office/study. Maybe one or two outlets to prime locations for WiFi routers. I actually am a licenced cabler so I ran 12 cat6 data outlets through my house and the only ones I use are for the smart TV (Netflix), XBox, and my wife's home office computer. If I had to pay someone to do it I wouldn't have bothered. Hallelujah Brother Re: Your Connected Home. What have you done / what do you ne 32Apr 23, 2017 7:18 am arcadelt GLO I also really like the BigAss Haiku Fans (the other one is Aeratron) and their summer mode. Ideally I'd like to tie it in with the HVAC system somehow. Big *** Fans are part of the "Works With Nest" program, so if you have Nest thermostats controlling your HVAC, they will work together. I really like the idea if Nest Learning Thermostat and that it links with the Haiku Fans, but I'm not sure if it will link in with Actron ESP+ controller. The alternative to Nest is the EcoBee3 due to Wi-Fi connectivity and compatibility with Alexa and Homekit, lots allows for multiple sensors. The other is the Honeywell Lyric which taps into your location and local weather forecasts via Wi-Fi then anticipate potential temperature changes and compensate for the weather. Anyone have experiences with these units? Re: Your Connected Home. What have you done / what do you ne 34Apr 23, 2017 9:29 am GLO The other is the Honeywell Lyric which taps into your location and local weather forecasts via Wi-Fi then anticipate potential temperature changes and compensate for the weather. Nest does this too, or potentially does. None of these products are available in Australia yet, so any support is incidental. Re: Your Connected Home. What have you done / what do you ne 36Apr 25, 2017 10:42 am GLO Anyone integrating Solar and solar monitoring into their new build? Most inverters are WiFi and the monitoring dashboard is just a web page. You could run a cat6 from your modem/hub location to the inverter of you're worried about the WiFi quality or just in case... Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Your Connected Home. What have you done / what do you ne 37Apr 25, 2017 10:43 am GLO Is anyone considering Solar and what monitoring and cabling requirements to support that? I have the same question too...considering going with Solar and Battery Storage after finishing construction. What cabling should I provide for monitoring and battery storage + backup? Also does anyone know if the batteries are weather resistant? I.e do they need to be indoors, or can they be installed outdoors next to the electricity meters? Re: Your Connected Home. What have you done / what do you ne 38Apr 25, 2017 9:44 pm I believe most are weatherproof, but keep in mind there is probably $10,000 worth of gear involved. I might be being a bit paranoid but I'd be putting it inside or at least somewhere secure Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Your Connected Home. What have you done / what do you ne 39Apr 26, 2017 9:59 am 1960sModernistHome I believe most are weatherproof, but keep in mind there is probably $10,000 worth of gear involved. I might be being a bit paranoid but I'd be putting it inside or at least somewhere secure My initial thought was that I'd put it in the garage, but the electricity meter is on the other side of the house. I'll have to ask the sparkies to run a conduit from the meter to inside the garage then... Re: Your Connected Home. What have you done / what do you ne 40Apr 26, 2017 10:15 pm sinbox 1960sModernistHome I believe most are weatherproof, but keep in mind there is probably $10,000 worth of gear involved. I might be being a bit paranoid but I'd be putting it inside or at least somewhere secure My initial thought was that I'd put it in the garage, but the electricity meter is on the other side of the house. I'll have to ask the sparkies to run a conduit from the meter to inside the garage then... My current solar inverter is on the inside wall almost directly behind the meter box. For me, the cost of batteries is still to high, but I anticipate on the affordability tipping the scales in 2-3 years when they become more mainstream. I currently have 3kw system, but want to add extra 10kw with the KDR. Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 40238 Hi All, I just wanted to close this topic out with an update. So we ended up agreeing to a number with the insurance company, and after an extensive amount of hand… 8 24117 You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18358 |
