Browse Forums Flooring & Floor Covering 1 Aug 16, 2008 4:05 pm Hi there,
Has anyone recently installed a solid timber floor over a concrete slab? What species of timber was it and how much per square meter did it cost you? We are building a 2 storey house and want to install solid timber spotted gum flooring on the ground floor over 15mm ply underlay. We have been quoted $45K to do approx 160sqm including supply and install of timber and underlay. I was shocked at this price? Any response would be much appreciated. Re: Cost of solid timber flooring? 2Aug 16, 2008 4:18 pm That price is ludicrous - even for spotted gum!!!
We were quoted $175 per square metre for 83x14 installed over 12mm ply (including all materials, installation, polish). If you found a decent installer and ordered the timber direct you could do this even cheaper. Where are you building? Re: Cost of solid timber flooring? 3Aug 16, 2008 4:43 pm Agree with Lyn - we got some quotes about two months ago for solid spotted gum for 80sqm that ranged from $180-$200/sqm. Your quote should be cheaper given the larger area you would think. I'm sorry I can't remember how thick the ply underlay was but I know the quote included everything - materials, installation and polish. 'We make a living by what we get, but we make a life by what we give.' - Winston Churchill Re: Cost of solid timber flooring? 4Aug 16, 2008 8:06 pm You should be able to get select grade 80x19 laid over ply, sanded and coated for about $150-$170 per sq. metre.
The timber itself will cost you about $65 sq. metre for that quantity. Keep in mind there is a fair difference between NSW Spotty and Qld Spotty - the Qld being much darker. Re: Cost of solid timber flooring? 5Aug 17, 2008 3:57 pm Thanks everyone for your response, much appreciated. I thought this price was ridiculous. I had estimated around $120 - $150 per square metre fully installed, not $300 per square. We are building in the eastern suburbs of Melbourne and I will look at getting my own price for this part of the construction. Re: Cost of solid timber flooring? 6Aug 17, 2008 9:59 pm If you source your own timber and arrange the sand & polish separately it may work out to be a bit cheaper.
I will PM you our installer details - he does a really neat, professional job. I wouldn't recommend our polishers, not neat or good! Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15884 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8289 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6173 |
