now to clean up my garage so i can start parking in it after easter
Hickinbotham Torquay Mod - Rear Verandah done
Page 37 of 38
The white stones will continue all the way down the side of the house and along the back fence.
Just want my brickwork fixed up - the holes and the non compliant window sills. (one side of house has 3 windows and all are at different angles (2 of them are almost flat)
they also need to come back and do more intense clean on several sections of my bricks - the maintenance guy has cleaned my porch bricks twice now and while you cant see the marks then as soon as what he uses dries they come back as even bigger smudges - most of the marks are a result of paint or grout on tiles with some being mortar stains as well. Have drawn their attention to the photos in my inspection report that show the same marks on the bricks
had a big huntsman next to my side table as i went to bed last night - saw him when i plugged my phone charger in
Lucky for him he co-operated with my broom and went out the front door.
why did the electrician bother installing something that is not solar compatible in a house with solar panels installed
would have rathered being given the box and giving it to soemone else to install who could have benefited from it.
with nothing turned on it shows my usage at 4.2kw.
turn on the AC and it drops to 1.2kw usgae despite my solar system telling me i was using 4.5kw and exporting .5 to the grid still
Made it clear upfront their was a solar system installed on premises and trust the fronius smart meter connected to my inverter over this crap
now i will have to pay to get it removed so that i can give it away
but will test it again tonight to see how accurate it is by night time anyway
estate encumberance manager advised he will look into the updated devices
no response from builder though as expected
and on a positive note the house next door started siteworks today
wont be to long now till i can get my side secured and fence finished off.
and once their driveway is done i will do my front landscaping
Fedup1 - that last picture showed the weepholes in my front porch area - all my paving and concrete is between 75mm and 80mm below dampcourse. Picture was just showing result of the builders maintenance guy cleaning my bricks - just creating a bigger grout smudge
all i have oustanding now is my laundry tiles to be checked by tiler and then the timber that has been put under my kitchen bench supports to be removed and the bench support height rectified
and slowly making a list of things for my 3 month defects list - looking hard for anything i can.
havent been able to pin down who or when either but it is being looked at - occured sometime prior in the week prior to monday lunchtime or so but expect more recently has i would like to think i would have noticed it (i think monday morning myself)
there is actually a footpath under this and you can see the ground compressed where whatever it is was unloaded/driven down the footpath
It is being looked at by the Developer
hard to believe its been over 3 months now but have finally collected my last boxes from storage and unpacked them.
going through my defect list i'm convinced i'm missing stuff as it doesn't seem very long so having a last look for issues this weekend before sending it in
I kept delaying it looking for more issues as couldn't find many to document other than the few remaining issues left over from my handover inspection plus 2 doors that have bad hinges and have come out of alignment - leaves me worried about other doors down the track
however have noticed another small indentation in my driveway
can see some stark differences between builders currently
house next door (different builder) was slabbed last weekend in april and has been at lockup since last week at least. 3 doors down by same builder as me was slabbed one week later and is being lined this week but still has no bricks delivered let alone started.
And to top it off in the last week or so i have started turning of power points a lot more frequently when im going out and realized today that the double power point used in my study doesn't turn off. both of them are on regardless of the switch position.
Will be escalating this tomorrow for an Immediate fix as consider it to be a safety hazard.
at handover i checked all power points worked but obviously didn't check all of them to make sure they where off when turned off
noticed today that my concreter has come back and fixed up the dent in my crosover - cant even tell unless looking closely that it has been patched.
like i have read here in other posts less than 5 months after handover and all the stress i had during constructions about progress and what was being done or not being done is a distant memory.
Amazing how 6 months ago i thought I had minimal furniture yet somehow i have still managed to end up filling this house up.
while i have had thoughts of things i would have liked to have done differently i am very happy with the way things have turned out and if i ever built again would probably choose hickinbotham again.
Hi, I'll be starting on my verandah repair soon - replace ledger, rafters, roofing iron, flashing etc. (fascia board already done). My question is about the timber ledger…
29/01/2024
1
Depends on size, local regulations etc. Ask your Council.
30/05/2023
Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly…
