Browse Forums Building A New House Re: Hickinbotham Build at Penfield (SA) - Valuation in 41Jul 07, 2017 12:28 pm at last stage for final approval and took about 4-5 weeks i think to get here
footings report etc came about 4 weeks after master plans from memory Just got my final plans and they have extended the entire garage to the toilet wall so my garage is now 7.8 meters deep. not how i pictured the modification but i think its a lot better as now I have plenty of storage space in the garage. Also have a larger contiguous northern facing roofspace for future solar panels as well. Wont be needing a garden shed i think. I have replaced the floorplan with the modified one now on the first page Re: Hickinbotham Build at Penfield (SA) 42Jul 07, 2017 2:50 pm got my first quote for roller shutters today - might be 6 months away but its nice to have an idea of what i will be up for expect i will just be doing the front window to start with though Front window 21-18 $975 manual Windows 21-21 $1060 manual 18-15 $840 manual 18-15 $840 manual Also been going through the beacon DIY section and worked out my initial lighting scheme. and at about $700 for lights in the lounge,dining, kitchen, living Hallway and entry Using DIY Batten fix suspension cord and a white batten fix shade (either 30 or 40cm) Will add heat lamps to bathroom and ensuite later on and also add Ceiling fans to all bedrooms as well as add the two external wall mount lights at some point next year also plenty of time to take advantage of any sales or cheaper prices i see for these types of products or to change my mind Re: Hickinbotham Build Northern Adelaide 44Jul 11, 2017 4:37 pm It sounds like things are coming together quite nicely! You guys are going to get to start building soon and then it'll be a matter of time before you get to move in! I really can't wait to start seeing pictures of the actual s tuff getting installed and put it - you must be on the edge of your seat to see how things are going to look all together! Have your builders told you about their time frame for the build and are you intending to in on the job yourself? What seems to be the officer's problem? Re: Hickinbotham Build Northern Adelaide 45Jul 12, 2017 8:48 am I don't have a time frame for build but have watched the others they are putting up around me and they have gone up fast - 1 was about 6-8 weeks from slab to lock up i think. Once its released for construction and i have a date for slab then i will ask about time frames. Looking forward to when i can walk through it after framing as that's when i will finally be able to see exactly what i am building. Re: Hickinbotham Build Northern Adelaide 46Jul 12, 2017 9:54 pm finally heard from my lender re valuation today - its not back yet and she is going on a weeks leave so will ring me next wednesday to discuss result and required mortgage etc. i just want this sorted now. so will be at least another 3-4 weeks before finance can be finalised and it can be released to construction Re: Hickinbotham Build Northern Adelaide 47Jul 12, 2017 10:07 pm Awh the waiting is a killer! We are still awaiting our soil test/reports etc for footings But on a good note our selections is finalized with our master plans and signed off Then waiting for counsil approval. We are going through homestart with financing so our settlement and evaluation is only after full council approval. (Saving at least on repayment till then) Re: Hickinbotham Build Northern Adelaide 48Jul 13, 2017 8:47 am How frustrating for you - so close, but so far. Hope the next week goes quickly and you get the valuation you need to get 79%. Hope you get good soil Lovisa and council are quick for you. Re: Hickinbotham Build Northern Adelaide 49Jul 15, 2017 6:52 pm well full development approval came through yesterday so now ready to release to construction. hopefully my lender wont take to long once she returns from leave on wednesday another month or so and i will hopefully be able to put some new pics up Re: Hickinbotham Build Northern Adelaide 51Jul 15, 2017 7:35 pm yay - congrats for approvals. Hope the lender has you as her first job on return. Looking forward to seeing progress pics of your site. Re: Hickinbotham Build Northern Adelaide 52Jul 19, 2017 11:22 am with all this rain i went past my block yesterday and also checked out other houses in my estate.
was a little dissapointed to see huge puddles of water against some slabs and no temporary downpipes attached to the gutters of houses under construction to channel the water away from the slab - considering the soil type i would think it should be done and is something i will raise with my SS once i get one assigned if i see water pooling at all Hopefully by the time they start my house will be end of the really wet weather anyway Noticed another builder with temp pipes running from gutter. Re: Hickinbotham Build Northern Adelaide 53Jul 19, 2017 12:24 pm well valuation came back 10k under what i hoped for Can still do it but leaves no money for anything at the end after base concrete/stormwater/fencing. will have to cut costs by reducing concreting and opt for the cheaper flooring. either that or exceed the 80% LVR Re: Hickinbotham Build Northern Adelaide 54Jul 19, 2017 12:43 pm Oh no! Hope better weather when both our building starts. Did they take the current flooring in consideration for the valuation? Might it effect the value as well when opting for cheaper options? Is re evaluation an option? Re: Hickinbotham Build Northern Adelaide 55Jul 19, 2017 12:49 pm don't want to spend the extra for another valuation if avoidable. have enquired about the costings in fees/LMI etc if i was to add another 15k to the mortgage and exceed the 80% LVR that im currently operating on. don't think changing the flooring etc will affect their valuation as they said re my submitting my flooring/concreting choice to my lender that i can change to a different concreter etc if i get a cheaper quote Re: Hickinbotham Build Northern Adelaide 56Jul 19, 2017 12:58 pm would think thT vinyl planks will have some added value over vinyl sheeting. Will pavers work out cheaper than concrete for perimeter and drive way? Hoping it wont affect you to much with adding extra $$$ Did you look at Solimans flooring or at Bunnings for vinyl planks? ( might get better prices) they were not too bad we looked at them before deciding on ones we have now Re: Hickinbotham Build Northern Adelaide 57Jul 19, 2017 1:44 pm damn about valuation and about the puddles. We were told that LMI would be about 6000 (CBA) - not sure whether that is standard cost or sliding scale for loan amount. Re: Hickinbotham Build Northern Adelaide 58Jul 19, 2017 2:23 pm well told to add another 15k to my mortgage will cost 2300 LMI plus another 280 valuation fee So only really a 12000 benefit think i would rather cut costs elsewhere and avoid it all it really means is i added 10k extras to house along the way that isnt reflected in the banks conservative valuation 2k in data cabling and electrical work would certainly be part of that Re: Hickinbotham Build Northern Adelaide 59Jul 19, 2017 3:10 pm Can they send you the valuation report? Then you might pick up what it was or they did not take the flooring quote into account? Hope we dont have same issues. We tried to keep everything standard but only upgraded floor grates to ss. Shower head to rail one, kitchen apliences to ss, security doors , floors to vinyl board, and gutters to colorbond. we didnt go to extra light fitungs/ extra paint cotes. Will br goid to know what they dont take into account? Can it be something the builder does thats their mark up and although you get the value added its not meeting the value including their extras added on? If you find out what was nit seen or added value pls let us know 😊 Hi, I'll be starting on my verandah repair soon - replace ledger, rafters, roofing iron, flashing etc. (fascia board already done). My question is about the timber ledger… 0 3323 1 2976 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8451 |
