Browse Forums Building A New House 1 Mar 23, 2017 4:42 pm We are currently cut and filling our sloping block so that it is level, i would like to avoid having to pay extra when the house is being built, for drop edgebeams. 2 questions: -what are drop edge beams and when and why are they required -what can we do to our block to avoid having to get drop edge beams? (Family member is an excavater/earth mover so we have the opportunity to get whatever we need done to the block very cheaply) Thanks Re: What is a drop edge beam and when and why are they requi 2Mar 23, 2017 5:07 pm We have a DEB on one side of our build. I think with a sloping site you either retain the land to make block flat to build on or you incorporate a DEB during construction. We went with a DEB as it meant we didn't need to allow for an increased setback with retaining close to the boundary. Our DEB looks like this Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ KDR Masterton Harmony Elite + custom granny flat Aug 2015 - Deposit paid Dec 2015 - Contracts signed Feb 2016 - Colours appointments Mar 2016 - DA submitted Jun 2016 - DA approved Re: What is a drop edge beam and when and why are they requi 3Mar 23, 2017 7:32 pm MartinsHarmony We have a DEB on one side of our build. I think with a sloping site you either retain the land to make block flat to build on or you incorporate a DEB during construction. We went with a DEB as it meant we didn't need to allow for an increased setback with retaining close to the boundary. Our DEB looks like this Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey thanks for the reply! This is great info, we are going to completley level and retain the property so i gues that means it is unlikely we will need a drop edge beam, well hopefully not after all the work Re: What is a drop edge beam and when and why are they requi 4Mar 23, 2017 8:03 pm Although you might save the need for drop edge beams, digging a sloping block until it's completely level could mean that you will need retaining walls instead. Re: What is a drop edge beam and when and why are they requi 5Mar 23, 2017 8:13 pm anonymous- Although you might save the need for drop edge beams, digging a sloping block until it's completely level could mean that you will need retaining walls instead. Hi yep we are getting two retaining walls put in to have two seperate levels one for the house one for garden and extra lawn (the block is 1300sqm) To build on the block it needed to be level regardless we are just lucky that we can save a fair bit of money due to the contacts we have in the industry, otherwise it wouldnt have been possible. Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12873 The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27310 I would like to build our new house with the rear section approx 1 metre out of the ground, I don't particularly like to go bearers and joists so concrete slab all the way… 0 3822 |
