Browse Forums Building A New House 1 Mar 23, 2017 2:06 pm Hi We have a 350sqm block in the suburbs of Sydney. We are looking for a double storey design that utilise the allowable floor space ratio. A design must be atleast 35 squares. Land specifics are: 12.5(w) x 28- zero lot. Some of the council regulations I can think of. 4.5 metres from the front and 4 metres from the rear. Therefore the ground floor can't be more than 19.5m in depth. 0.9m from the sides, therefore 10.7m should be the width. This can change to 11.6 if the design could make use of the zero lot for the double garage. Your suggestions are much appreciated. Re: Double Storey Suggestions 2Mar 23, 2017 2:41 pm Wisdom Homes have quite a few designs that fit on blocks shorter than 30m. Not sure if they have anything as big as 35 squares that will fit though. We have a 335m2 lot (12.5x26.5-27.5) zero lot and 31 squares is about as big as we could fit on (Aspiration 31) Check your councils requirements for 2nd storey setback. CDC requires 8m set back for 2nd storey but sometime council will allow it to be closer to the back boundary. If you can do 4m back boundary setback for 2nd storey then Mojo Homes may have some designs which might suit you. They were all too close to back boundary for us even through council. Re: Double Storey Suggestions 3Mar 23, 2017 2:51 pm Jenifermarie Wisdom Homes have quite a few designs that fit on blocks shorter than 30m. Not sure if they have anything as big as 35 squares that will fit though. We have a 335m2 lot (12.5x26.5-27.5) zero lot and 31 squares is about as big as we could fit on (Aspiration 31) Check your councils requirements for 2nd storey setback. CDC requires 8m set back for 2nd storey but sometime council will allow it to be closer to the back boundary. If you can do 4m back boundary setback for 2nd storey then Mojo Homes may have some designs which might suit you. They were all too close to back boundary for us even through council. Thanks for that. So far I have shortlisted Manhattan 36 from Wisdom and Cremorne 34 from EBH. Our council rear setback for 2nd storey is 6m. Ground floor is 4m. Maximum floor space is 140sqm for the 2nd storey. Re: Double Storey Suggestions 5Mar 23, 2017 10:27 pm 1. Would you consider three-storey!? Would be totally fetch! 2. Maybe consider a smaller house? 3. Apply to council for relaxations of boundaries....? Good luck and all the best! Follow our first house build here! -> https://forum.homeone.com.au/viewtopic.php?f=31&t=86484 Re: Double Storey Suggestions 6Mar 23, 2017 10:54 pm ruraldoc 1. Would you consider three-storey!? Would be totally fetch! 2. Maybe consider a smaller house? 3. Apply to council for relaxations of boundaries....? Good luck and all the best! Your comments aren't helpful but thanks for taking the time to give your 2c worth. Re: Double Storey Suggestions 7Mar 24, 2017 9:23 pm Mtfranklin ruraldoc 1. Would you consider three-storey!? Would be totally fetch! 2. Maybe consider a smaller house? 3. Apply to council for relaxations of boundaries....? Good luck and all the best! Your comments aren't helpful but thanks for taking the time to give your 2c worth. Appreciate the feedback. Again, good luck and all the best! Follow our first house build here! -> https://forum.homeone.com.au/viewtopic.php?f=31&t=86484 Re: Double Storey Suggestions 8Mar 24, 2017 10:54 pm Out of curiosity, is there a particular reason why the design must be at least 35 squares? Re: Double Storey Suggestions 9Mar 25, 2017 11:11 am algernon Out of curiosity, is there a particular reason why the design must be at least 35 squares? We live in a 30sq home, no point in upgrading if less than 35. Re: Double Storey Suggestions 10Apr 05, 2017 5:26 pm Mtfranklin Jenifermarie Wisdom Homes have quite a few designs that fit on blocks shorter than 30m. Not sure if they have anything as big as 35 squares that will fit though. We have a 335m2 lot (12.5x26.5-27.5) zero lot and 31 squares is about as big as we could fit on (Aspiration 31) Check your councils requirements for 2nd storey setback. CDC requires 8m set back for 2nd storey but sometime council will allow it to be closer to the back boundary. If you can do 4m back boundary setback for 2nd storey then Mojo Homes may have some designs which might suit you. They were all too close to back boundary for us even through council. Thanks for that. So far I have shortlisted Manhattan 36 from Wisdom and Cremorne 34 from EBH. Our council rear setback for 2nd storey is 6m. Ground floor is 4m. Maximum floor space is 140sqm for the 2nd storey. I loved manhattan over cremorne But live Lincoln and marina more from EBH. Not sure if they would fit or not. Re: Double Storey Suggestions 11Apr 06, 2017 8:33 pm Thanks, the other designs from EBH won't fit my block. But they are good designs. Re: Double Storey Suggestions 13Apr 08, 2017 7:17 pm Thanks, but the parkhill 34 floor space ratio for the first floor is over 40% of the land area. I have been able to find another design from Mojo homes called Enigma 34 with an added Rumpus to a total of 36squares. 1 2470 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 754 Surrey Hills, Vic 3127 Garage is being built with metal, 3m distance away from my cover deck. It is parallel to my cover deck, living room, family room and kitchen,… 0 7036 |
