Browse Forums Building A New House 1 Mar 08, 2017 2:44 pm Hi , I inspected my new house today and I found a 6 inch white pipe cap on the middle of driveway which looked little odd to look with a different color ( white ) in middle of a black driveway . What is this ? Are there any advantages of having this in middle of drive way ? can we paint it with the same color as of drive way so that it doesn't look odd ? by the way later in the community i observed for few other houses also they have the same white pipe cover on the drive way ... Thanks. Regards, SYDSR. Re: Driveway white pvc pipe 2Mar 08, 2017 4:46 pm It sounds like a sewer inspection point. It needs to be above where the sewer pipe runs. You might be able to get an alternative coloured cover for it or failing that a new concrete or steel trafficable cover as a replacement Building a Fairmont Custom in Seaford Meadows Our Build Thread yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7326 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4872 DIY, Home Maintenance & Repair 3 pipes are coming from upstairs bathroom. 40mm from bathroom sink, 50mm from shower and another 50mm from the bathtub. Highly unlikely that any of these will be open at… 2 853 |
