Browse Forums Building A New House 1 Feb 20, 2017 8:03 pm Hi Everyone ,
First Post Looking to build a Split level home, If we can find exactly what we like with a project home we will be interested? Anyone know of any project home builders that do a split level , With the block sloping up front to back Location West Pymble NSW If not it is off to custom builders Thanks everyone Re: Split Level Home 5Feb 21, 2017 6:10 am We modified our gjs design to put a split into it. Perhaps if you found a design you liked you could look at doing that, pending the severity of the slope and the split required of course. - otherwise known as Kym - Move your linen into laundry and access laundry from your present linen space 1 7998 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17502 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6578 |
