Browse Forums Building A New House Re: 2 Gas Points in Alfresco? Or 1 is enough? 2Feb 14, 2017 11:48 am To be safe, I asked for 2. However if you are going with one bayonet point, ensure that the gas line to that point will be capable of supplying sufficient gas to multiple appliances. Re: 2 Gas Points in Alfresco? Or 1 is enough? 3Feb 15, 2017 12:22 am Is there a maximum number of gas appliances that can be connected before the size of the gas pipe needs to be upgraded? Re: 2 Gas Points in Alfresco? Or 1 is enough? 4Feb 15, 2017 2:58 pm I think it depends on the individual appliances which will run on the gas line. When signing off on the contract, the builder asked me what sort of appliances I intended to run from the gas line to the alfresco so they could brief their plumber. Most of the time, council will push you out to a private certifier as it ties up their limited resources. Where a builder has gone belly up, the certifier passes the file… 7 5375 As per title, unsure if my land doesn’t have enough fill. The house on the left seems to have higher elevation. Not sure if the empty lot in between has just been… 0 560 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13846 |
