Browse Forums Building A New House 1 Feb 01, 2017 5:21 pm Hi Everyone, I have got some tenders ready to chose the builder but all of them trying to chop the original floor plan and make house smaller to comply with AS regarding driveway gradient. This also includes massive site cost. Just seeking help from anyone who had same issue. Besides I was wondering to know whether anyone has leveled the land to reduce the site costs prior to building process. Any comment and advice much appreciated. Many Thanks Re: Leveling sloping land 2Feb 01, 2017 7:36 pm sounds like as your floor plan is currently, your driveway gradient is not compliant. i've known some circumstances in the past where this hasn't been properly calculated/investigated, and when the time came to pour the driveway (roof was on, had been bricked up), it was picked up as non-compliant. the outcome was they had to cut into the slab in the garage, re-pour it lower, whilst adding steps in the garage, to accomodate a suitable driveway gradient. structurally was a challenge, and was quite a lot more expensive to do mid-build compared to getting it right at the start of the job. if multiple builders are suggesting that you need to adjust the plan to suit the driveway, then there is a good reason unfortunately. the rules are in place for good reason, no one wants to scrape the bottom of their car everytime they drive into the garage! which council are you in? every council should have a standard detail for their driveway gradients, which may sometimes differ from australian standards, and generally over-rules AS. they usually show things like transitions along the driveway, which can help to achieve a suitable gradient. another option would be to move the house further back into the lot, which is usually the easiest option. of course most people would want a larger backyard, and sometimes if the design/setbacks may not allow this. if you have access to your RL at boundary, the distance from the boundary to garage door and the finished floor RL then i'd be able to look at this for you and see if there's a solution around incurring the additional site costs. i can't comment on the leveling of land to reduce site costs, as i haven't experienced that myself, but hopefully others can comment. Re: Leveling sloping land 3Feb 01, 2017 9:15 pm innerbloom sounds like as your floor plan is currently, your driveway gradient is not compliant. i've known some circumstances in the past where this hasn't been properly calculated/investigated, and when the time came to pour the driveway (roof was on, had been bricked up), it was picked up as non-compliant. the outcome was they had to cut into the slab in the garage, re-pour it lower, whilst adding steps in the garage, to accomodate a suitable driveway gradient. structurally was a challenge, and was quite a lot more expensive to do mid-build compared to getting it right at the start of the job. if multiple builders are suggesting that you need to adjust the plan to suit the driveway, then there is a good reason unfortunately. the rules are in place for good reason, no one wants to scrape the bottom of their car everytime they drive into the garage! which council are you in? every council should have a standard detail for their driveway gradients, which may sometimes differ from australian standards, and generally over-rules AS. they usually show things like transitions along the driveway, which can help to achieve a suitable gradient. another option would be to move the house further back into the lot, which is usually the easiest option. of course most people would want a larger backyard, and sometimes if the design/setbacks may not allow this. if you have access to your RL at boundary, the distance from the boundary to garage door and the finished floor RL then i'd be able to look at this for you and see if there's a solution around incurring the additional site costs. i can't comment on the leveling of land to reduce site costs, as i haven't experienced that myself, but hopefully others can comment. Thanks for ur comment. I will send u a PM. Re: Leveling sloping land 4Feb 02, 2017 5:39 am We had to change our design and seperate our house from our garage because of angles, gradients and trees. Once we did that we had more options with design and site positions. Don't know if it would help, depends on your plan and the shape and size of your block but it may be something. Re: Leveling sloping land 5Feb 02, 2017 5:55 am Philip_J We had to change our design and seperate our house from our garage because of angles, gradients and trees. Once we did that we had more options with design and site positions. Don't know if it would help, depends on your plan and the shape and size of your block but it may be something. Thanks Philip. We are happy to have split slab and dropped garage but builders beilive these things are not good enough and we should push the garage toward back of the house which means wasting land on the side of the house. I have been told by friends to approach custom built builder but don't know how to find them. My land is pretty flat but elevated of the street. Re: Leveling sloping land 8Feb 06, 2017 7:08 pm Hi how much is the elevation? is it more than 1m? Sparkie Philip_J We had to change our design and seperate our house from our garage because of angles, gradients and trees. Once we did that we had more options with design and site positions. Don't know if it would help, depends on your plan and the shape and size of your block but it may be something. Thanks Philip. We are happy to have split slab and dropped garage but builders beilive these things are not good enough and we should push the garage toward back of the house which means wasting land on the side of the house. I have been told by friends to approach custom built builder but don't know how to find them. My land is pretty flat but elevated of the street. Re: Leveling sloping land 9Feb 06, 2017 9:30 pm faykis Hi how much is the elevation? is it more than 1m? Sparkie Philip_J We had to change our design and seperate our house from our garage because of angles, gradients and trees. Once we did that we had more options with design and site positions. Don't know if it would help, depends on your plan and the shape and size of your block but it may be something. Thanks Philip. We are happy to have split slab and dropped garage but builders beilive these things are not good enough and we should push the garage toward back of the house which means wasting land on the side of the house. I have been told by friends to approach custom built builder but don't know how to find them. My land is pretty flat but elevated of the street. Hi Mate, land itself is around 1 meter but whole block elevated from the street and it is around 1.6 Meter. Re: Leveling sloping land 10Feb 07, 2017 10:22 am Thats sad! you probably had no idea prior to your purchase of the land that there was 1.6M elevation from the road and it would affect driveway gradient? Things come out just from nowhere : Hi Mate, land itself is around 1 meter but whole block elevated from the street and it is around 1.6 Meter. Re: Leveling sloping land 11Feb 07, 2017 11:03 am faykis Thats sad! you probably had no idea prior to your purchase of the land that there was 1.6M elevation from the road and it would affect driveway gradient? Things come out just from nowhere : Hi Mate, land itself is around 1 meter but whole block elevated from the street and it is around 1.6 Meter. Yeah mate. I got ripped and didn't have any clue. Put me under massive pressure. Howdy all. I am looking for feedback on what people would do to maximise and make an area as flat as possible. First, out the front of the house is a sloping hill, pretty… 0 20153 Give Jonathan a call. Tell him you know me. He is in my opinion the best surveyor I have ever worked with. His number is 0425 285 622 All the best Simeon 3 12414 i did click it, still couldnt make it out rofl. in any case, doesnt look like too extreme a slope, you may be in luck. Just shoot out some emails to volume builders in… 3 18563 |
