Browse Forums Building A New House 1 Jan 25, 2017 9:41 pm We are looking to build a house with 4 bedrooms, 2 bathrooms, and a double garage in the northern suburb of Melbourne. Our land is 270 square metres with 12.85m frontage and 0.46m fall and no easement. We have been enquiring with some bigger builders but they seem to be out of budget. We are basically looking to build a double storey due to size of the land and with standard inclusions. I hear that building a double storey costs a lot more due to higher labour costs etc. But we were told by builders who built there that there shouldn't be any site cost as the land is almost flat and without rocks etc. I've sort of looked around different pricing of different builders and it looks like the building cost is about $10,000 per square. I was after some advice from who are building now or recently built their home if the price is about right. Thanks. Re: Lowest cost of building a small double storey house in M 2Jan 26, 2017 8:36 am Congratulations on starting a journey! To be honest the price really varies between builders and their standard finishes & . Your lot is a little bit small so you would be restricted to a max 12.5 design frontage, assuming very flat site conditions (which usually means the home is longer and a home of no more than about 15 metres deep to satisfy requirements of garage from road, etc. Perhaps look at townhouses as most of the volume builders are doing these now? What's your budget? The other option would work better if you are more specific about design is trying to go custom. FYI on site costs, even if the land is really flat I reckon it will still cost you minimum $5-7k especially if it's a double as they may need to reinforce the land ie piers etc. For the house itself I reckon for standard / basic finishes $10k/square is achievable. Good luck Jason My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 Re: Lowest cost of building a small double storey house in M 3Jan 29, 2017 9:35 am $10k per square is high end. I am building a 34sq house by Burbank with a lot of structural changes for $280k. Do the math. But I guess there's diminishing returns with the bigger house you build, the cheaper it is p/square. $10k per square sounds like a really specced up house, too. Re: Lowest cost of building a small double storey house in M 4Jan 29, 2017 6:43 pm There's always site costs. But sounds like they will be minimal. I expected my land to be flat, rock free, etc.. but ended up having fill put on it by the developer so the site costs jumped up 6k. Doubles are expensive. They were min 50k more then any single design I looked at for my block. Re: Lowest cost of building a small double storey house in M 5Jan 29, 2017 8:14 pm I guess it's a matter of opinion. I'd say based on my build $10k / sq would give you a finish above standard but certainly not high end - this would be more like $15k/sq assuming you're looking at all the upgrades to finishes, flooring, electrical, facade upgrades etc and not just the base price plus structural changes. My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 Re: Lowest cost of building a small double storey house in M 6Jan 30, 2017 1:13 pm I thought 10k/sq was average. Given a double is usually around 20% more expensive, I would have thought 10k/sq would be the bottom end for a double storey. Be careful believing builders that say you won't have any site costs, that seems unlikely in Melbourne, unless they already have a H1 or 2 slab included. Re: Lowest cost of building a small double storey house in M 7Jan 30, 2017 6:45 pm Thanks very much for your advice guys. Really appreciate it. So about $10K per square looks about right for a very basic double storey. We just want a very basic double storey with 4,2,2 and standard inclusions for a 20-22 square home for $210-220K including everything. Would there any builders out there who will be able to do it? I've approached GJ Gardners as they seem to have many different designs on their website and also do custom designs. I just wanted to get an idea of how much it would cost to build such a home and was told to pay $1500 to get a custom design done to get a quote. Is that the way to go or just go out there myself and get a custom design done and approach other/small builders? I've also spoken to Burbank but they don't seem to do custom designed homes. Re: Lowest cost of building a small double storey house in M 8Jan 30, 2017 6:54 pm Btw Jason, you're right, I forgot to mention it but the width of is 12.85m and depth 21m of which I was advised there needs to be 3m each at the front and back. And technically we could build up to 70% of the land size of less than 300sqm, there are requirements of private open space etc at the rear and side of the house. So anyway we were told that single storey with 3 bedrooms and a study room, and a double garage is not possible. The length of single storey was 15m on a design that was suggested but had only 3,2,2. So with townhouse design you mentioned in your post, would they be able to put 4,2,2 in there? Thanks again for your advice. Re: Lowest cost of building a small double storey house in M 9Jan 30, 2017 6:56 pm Vdubbed 12 Thanks very much for your advice guys. Really appreciate it. So about $10K per square looks about right for a very basic double storey. We just want a very basic double storey with 4,2,2 and standard inclusions for a 20-22 square home for $210-220K including everything. Would there any builders out there who will be able to do it? I've approached GJ Gardners as they seem to have many different designs on their website and also do custom designs. I just wanted to get an idea of how much it would cost to build such a home and was told to pay $1500 to get a custom design done to get a quote. Is that the way to go or just go out there myself and get a custom design done and approach other/small builders? I've also spoken to Burbank but they don't seem to do custom designed homes. Going custom is going to cost you a whole lot more...most custom builders Ive seen won't do a project less than about $350-400k though I can't say I've done a mass of research. Sounds like you are really looking at townhouses which will give you yoir 4-2-2. I'd suggest a volume builder like Metricon or Porter Davis ... These 2 come to mind for me straight away as I've seen them do big developments ... I've also seen communities by Burbank. I'm feeling like you may struggle to find something double for this price outside the volume builders.... Good luck My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 Re: Lowest cost of building a small double storey house in M 10Jan 30, 2017 7:42 pm Thanks for that again. Maybe I haven't looked closely but I haven't noticed such designs on their website. I'll have a look again and enquire with them. But I'm not sure if we can build a townhouse on our block as the estate has to approve certain designs from the builder before applying for a building permit. Hope it's doable. Re: Lowest cost of building a small double storey house in M 11Jan 30, 2017 7:58 pm I did a quick search on Metricon and it's challenging to find a double to suit your block but check out the Zita 25 by Metricon...could be just the perfect fit! http://www.metricon.com.au/new-home-des ... e2EhrL3.97 It's also a really nice floor plan! My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 Re: Lowest cost of building a small double storey house in M 13Feb 05, 2017 8:11 pm Yeah I've actually spoken to the sales consultant at Homebuyers centre but there was only that one model and was out of our budget. I've set up a time with Hamilton this week so we will see how we go. I think Hotondo had two that would fit our land but not sure about the cost yet. Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 9887 there is a few calculators you can use if you just google it 7 7477 1 4521 |
