Stage 3 guys - any update? Are the blocks titling December?
Thanks
Browse Forums Building A New House Re: The ivy, Doreen 176Jan 22, 2018 5:54 pm Update from the weekend is that Stage 3 will title in February, Stage 4 a couple of months after that... then, the big news, Stage 6 will follow Stage 4 ('only a small stage' and currently at same level of completion as Stage 4 - which you can actually see on google maps these days). Stage 5 anticipated around June-July (hold up in Stage 5 is the drainage pump). Re: The ivy, Doreen 177Jan 23, 2018 5:47 am blackdiamond Update from the weekend is that Stage 3 will title in February, Stage 4 a couple of months after that... then, the big news, Stage 6 will follow Stage 4 ('only a small stage' and currently at same level of completion as Stage 4 - which you can actually see on google maps these days). Stage 5 anticipated around June-July (hold up in Stage 5 is the drainage pump). Hi Blackdiamond, where did you get this information from? Did Rhonda or Rod from RPM gave this info? |
