Browse Forums Building A New House Re: Metricon Lincoln 32 in Adelaide 66Oct 15, 2017 9:08 am The tilers started this week, things are going smoothly so far. Epoxy grout is going to be used for the tiles, the tiler was querying why I selected this due to the extra labour cost involved, apparently they are charging M an extra $1,300 for the labour. M only charged me $200, I am pretty happy with this. No doubt M made up this money somewhere else, but things are looking good. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Metricon Lincoln 32 in Adelaide 68Oct 18, 2017 10:22 am Epoxy!! Wow that’s a new idea. So they would use the epoxy instead of grout? Is this because it’s easier to clean? Re: Metricon Lincoln 32 in Adelaide 69Oct 18, 2017 10:54 am Renman Epoxy!! Wow that’s a new idea. So they would use the epoxy instead of grout? Is this because it’s easier to clean? Yes, its a special epoxy grout, apparently easier to clean and does not stain like regular grout. This is the stuff they are using, in the "travertine" colour http://www.ardexaustralia.com/products/ ... rdex-eg-15 The sample they showed me looked a similar texture to normal grout, not a plastic looking expoxy which is what I was concerned about when they first mentioned it. Re: Metricon Lincoln 32 in Adelaide 70Oct 18, 2017 12:21 pm Cool. Thanks for the link. Did you do it for whole tiled area? Re: Metricon Lincoln 32 in Adelaide 71Oct 18, 2017 12:28 pm Renman Cool. Thanks for the link. Did you do it for whole tiled area? I did all the floor area (Bathroom, Ensuite, Laundry, Main living area) as I figured they would be the worst for dirt and staining. I didnt get it done for the full height wall tiling in the bathroom or ensuite, but in hindsight I now wish I did the walls too. Re: Metricon Lincoln 32 in Adelaide 72Oct 18, 2017 12:51 pm Would it be an issue where the grout lines won’t look the same since one it epoxy and the other one is standard? Re: Metricon Lincoln 32 in Adelaide 73Oct 18, 2017 12:53 pm Renman Would it be an issue where the grout lines won’t look the same since one it epoxy and the other one is standard? dunno - i will tell you in a week or so when they finish the colours looked very similar between the two grouts in the showroom, but wont know until it is done. Re: Metricon Lincoln 32 in Adelaide 74Oct 24, 2017 8:41 am Re: Metricon Lincoln 32 in Adelaide 75Oct 24, 2017 3:41 pm Colours look very similar to our wet areas! Re: Metricon Lincoln 32 in Adelaide 76Oct 29, 2017 6:36 pm Tiling is now all finished, and the stone benchtops have been installed. The SM called on Friday with an issue with the glass splashback size, apparently they cannot do a single piece of glass the whole length of the kitchen cupboards and stove, so needs to be in two or three pieces. After much hesitation I decided to get three pieces, lining the glass joins up with the edge of the stove, making a symmetrical look. Not real sure how this will come out, the SM has said that both him and the glass people think this is the best way to do it. The carpenter will be back onsite this week finishing off the trim, and replacing my front door. This weekend the carpets and curtains selections were done and deposit paid, these are being done after handover, but booking it all now in the hope that it will be before christmas. Photos of the finished tiling below. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Metricon Lincoln 32 in Adelaide 79Oct 29, 2017 8:24 pm SANDYFAN When you do full height tile did they install tiles behind mirrors? Thank you They have tiled where the mirror goes in the main bathroom, but the ensuite has a backing board mounted and they have tiled around it. I am actually not sure why they have done them differently, but I just looked at my contract and it says that the ensuite is on an MDF backing board. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Metricon Lincoln 32 in Adelaide 80Oct 30, 2017 3:57 pm lincoln32 SANDYFAN When you do full height tile did they install tiles behind mirrors? Thank you They have tiled where the mirror goes in the main bathroom, but the ensuite has a backing board mounted and they have tiled around it. I am actually not sure why they have done them differently, but I just looked at my contract and it says that the ensuite is on an MDF backing board. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thank you for checking. I heard back from my CSC saying they do tiling behind mirrors now Building a new home, and looking for a garage builder (home builder not contracted to do this). Someone to build steel garage (double), colorbond, including supply and… 0 3252 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10750 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8201 |
