Browse Forums Building A New House Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1202Oct 07, 2017 11:48 pm Orpheus stanus Orph, its cheap but when you have 230 plus sqm it ads up. Yeah my top floor is only 100sqm (excluding wet areas) so $7k is a good investment. Our builder is repairing our timber floor to first floor due to excessive squeaks in all the carpeted areas and uneven floors due to warping (prob caused by rain when they installed timber flooring without a roof!) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Oh no - hopefully I don't get squeaking on my block. From memory my upstairs flooring was exposed to heavy rain for 1 day. Do you have a video of the squeaking? Would be good to see what is deemed as excessive. Also - why is one of the floor joists unattached at the end? And the other floor joist seems to be nailed into another piece of wood to hold it. I thought they floor joists aren't meant to "float" or be nailed to another piece of wood parallel to it for more reach. Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1203Oct 08, 2017 7:23 am This area where they had to fix the floor because it was uneven. I don't know why the end doesn't join the other joists. The carpenter had to re-brace the joists again. All the bedrooms have squeaks so I'm making M to lift the carpets to re-screw all the floor boards. If it doesn't get fixed now then the squeaks will get worse in the future. Orpheus Building the Metricon Glendale 38|Sydney Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1204Oct 08, 2017 10:12 am Quirmeball1280 Nice pics Renman, can’t wait to see more interior pics, especially of the stairs - looks like our interiors will take a while so it’s good to drool over yours Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Is there a hold up? My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1205Oct 08, 2017 10:14 am iceberg. Orpheus stanus Orph, its cheap but when you have 230 plus sqm it ads up. Yeah my top floor is only 100sqm (excluding wet areas) so $7k is a good investment. Our builder is repairing our timber floor to first floor due to excessive squeaks in all the carpeted areas and uneven floors due to warping (prob caused by rain when they installed timber flooring without a roof!) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Oh no - hopefully I don't get squeaking on my block. From memory my upstairs flooring was exposed to heavy rain for 1 day. Do you have a video of the squeaking? Would be good to see what is deemed as excessive. Also - why is one of the floor joists unattached at the end? And the other floor joist seems to be nailed into another piece of wood to hold it. I thought they floor joists aren't meant to "float" or be nailed to another piece of wood parallel to it for more reach. It is worth while getting additional nails into the floors before the carpet is lay? My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1206Oct 08, 2017 10:15 am Orpheus This area where they had to fix the floor because it was uneven. I don't know why the end doesn't join the other joists. The carpenter had to re-brace the joists again. All the bedrooms have squeaks so I'm making M to lift the carpets to re-screw all the floor boards. If it doesn't get fixed now then the squeaks will get worse in the future. Was your carpet done with M? My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1207Oct 08, 2017 10:24 am Renman iceberg. Orpheus [quote="stanus"]Orph, its cheap but when you have 230 plus sqm it ads up. Yeah my top floor is only 100sqm (excluding wet areas) so $7k is a good investment. Our builder is repairing our timber floor to first floor due to excessive squeaks in all the carpeted areas and uneven floors due to warping (prob caused by rain when they installed timber flooring without a roof!) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Oh no - hopefully I don't get squeaking on my block. From memory my upstairs flooring was exposed to heavy rain for 1 day. Do you have a video of the squeaking? Would be good to see what is deemed as excessive. Also - why is one of the floor joists unattached at the end? And the other floor joist seems to be nailed into another piece of wood to hold it. I thought they floor joists aren't meant to "float" or be nailed to another piece of wood parallel to it for more reach. It is worth while getting additional nails into the floors before the carpet is lay? My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t[/quote]Totally. It's not just a few, the carpenter fixing our flooring used screws every 400mm so he used heaps. Yup carpet done through M with Carpet Call. Orpheus Building the Metricon Glendale 38|Sydney Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1208Oct 08, 2017 10:36 am Thanks for the tip. Will ask the carpet installer to do the same for ours. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1209Oct 08, 2017 10:40 am Renman Thanks for the tip. Will ask the carpet installer to do the same for ours. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Orpheus Building the Metricon Glendale 38|Sydney Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1210Oct 08, 2017 10:47 am Renman Is there a hold up? My KDR Metricon Hampshire - Liberty - 45 Melb Just the usual delays to get the right tradies in to fix stuff There hasn’t been any rain the last few months so I guess business in NSW must be booming Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1211Oct 08, 2017 1:19 pm Orpheus Renman Thanks for the tip. Will ask the carpet installer to do the same for ours. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Well the carpenters are M, so I don’t think they will do more than it’s required too. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1212Oct 08, 2017 8:19 pm jessicagauci Kandi An electrical question Cool white or warm white? which one is better. Depends what you are going for. Our house is quite modern and we went for cool white which suits. The warm white looks a bit yellowish which throws our wall colour a bit yellow. Thanks for that, are you able to post a picture please. Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1213Oct 08, 2017 8:20 pm jessicagauci Kandi An electrical question Cool white or warm white? which one is better. Depends what you are going for. Our house is quite modern and we went for cool white which suits. The warm white looks a bit yellowish which throws our wall colour a bit yellow. Thanks for that, are you able to post a picture please. Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1214Oct 09, 2017 6:46 am Kandi jessicagauci Kandi An electrical question Cool white or warm white? which one is better. Depends what you are going for. Our house is quite modern and we went for cool white which suits. The warm white looks a bit yellowish which throws our wall colour a bit yellow. Thanks for that, are you able to post a picture please. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cool white Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Warm white Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1215Oct 09, 2017 8:33 am I actually prefer Cool White inside the house but wifey wants Warm. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1216Oct 09, 2017 8:35 am Renman I actually prefer Cool White inside the house but wifey wants Warm. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Orpheus Building the Metricon Glendale 38|Sydney Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1217Oct 09, 2017 8:39 am I’ve seen them. Going to be an expensive exercise since we have around 100+ LEDs. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1218Oct 09, 2017 9:48 am Oh man. The warm white is a lot yellower than I imagined. Having grown up in a house that uses cool white i wish my husband hasn't chosen warm! Metricon Vantage https://r.tapatalk.com/shareLink?share_ ... are_type=t My KDR Metricon Hampshire - Liberty - 45 Melb 1219Oct 09, 2017 10:50 am We’ve used warm lights as well but the pics show it as being so yellow It will be interesting to see how the wall colours look under light. Our lights underneath the kitchen cabinetry are cool lights though. Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: My KDR Metricon Hampshire - Liberty - 45 Melb 1220Oct 09, 2017 11:09 am We have warm lights all through our house. Doesn't look that yellow in person, that pic up there isn't a fair comparison, cause it wasn't warm down lights. Though I actually wanted all cool white, but misses wanted warm. Happy wife, happy life. We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37140 The biggest challenge will be if you take out a loan and then run out of money - you'll have an incomplete security and lenders do not like this so you can get stuck.… 2 19096 Hi, I am looking into doing a KDR in Melbourne and am contemplating using Kialla Homes. I am looking for feedback on them from others who have built with them. 0 13443 |
