Browse Forums Building A New House 1 Dec 08, 2016 4:27 pm How are cables concealed when wall mounting a TV? I was under the assumption that internal wall ducting was used (not sure where I got this idea). We are about to build a new home. I asked the builder to quote on installing some internal wall ducting for AV/HDMI and power cables so that the cables enter the wall cavity at roughly floor level then pop out of a hole behind the TV a little bit further up the wall. The builder came back and said 32mm conduit was the biggest they could do, but that nowhere near wide enough to fit a few cables in. So how is it done? I know you can get plastic panels/plates that you screw in where the hole in the wall is made to make it look nice and neat, but is there plastic ducting or conduit made for this kind of job or are the cables just fed in behind the gyprock as is? I hope this all makes sense. Many thanks. Re: Internal wall ducting for AV cables? 2Dec 09, 2016 1:21 pm I think a 32mm conduit should be fine without the power cables. Just ask them to put a power point next to the conduit or get one after handover), which would be hidden by the tv anyway. The other option is to get an av wall plate installed as well as a power point, this option can be pretty expensive depending on your setup though. I guess you could run a second conduit for the power but depending on the height of your tv would the power cable even reach? Re: Internal wall ducting for AV cables? 3Dec 10, 2016 5:42 pm Check out cable clear http://www.repelec.com.au/www2/download ... 0Flyer.pdf Repelec distribute it, available from any electrical wholesaler. Will give 50mm channel, can be done before or after plastering (although if after, need to be sure no noggins in the way) Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7937 3 10205 Sorry, don't know costs, but there are a couple of very important principles you need to get right (and now) .... (1) never agree to any "upgrade" unless you first know… 5 6838 |
