Browse Forums Building A New House 1 Nov 23, 2016 10:26 pm Hi. We just buikt a new house and did a 3xe concrete slab out back for our garden shed. Now we put 3 side and back panels on. Then the roof. Then the front panel with the door. Im bloody confused. Both door close but starting from the top where the doors meet. As u go down the gap gets bigger and bigger forming a triangle by the time u look at the bottom. Approx 50mm gap at the bottom of the door. Somethings off. What would make the doors be off key. I am going to take the roof off this week and make sure all 4 sides are good. Then put the roof on again and hope it fixes it. Any help appreciated. How do i make sure the shed is perfectly square as the doors willl shut properly then Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5404 Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3416 |
