Browse Forums Building A New House 1 Nov 21, 2016 8:39 pm I have a problem with my build. according to BCA, the living area height should be 2400mm. My builder had made a mistake and at the moment the height in some area is 24150 mm. According to the plan it should have been 2450mm So once the timber flooring is in, it will be less than 2400mm. Is there are way to get this pass the certification? thanks 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: Help - Ceiling height for living areas 2Nov 25, 2016 6:07 pm any one had similar issue? During the OC certificate inspection, do they measure the heights? 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10595 Can anyone help with the layout of my living room, it seems that no matter what I do it never looks right. I have an awquard kind of l shape with 2 doors, bay window and… 0 8326 Building Standards; Getting It Right! We bought a house in 2015 advertised as a 7/2/2, 4br up, 3br down (7br), and to date, it’s a great house. However, we’ve just had it valued and it’s come in as a… 0 11943 |
