Browse Forums Building A New House 1 Nov 18, 2016 12:38 am Hi , Please advice me regarding dimensions of a land I am considering to buy. The dimensions are odd but location is perfect, also Its a bit higher in terms of price but location is great so I dont wanna miss it. Please advice can I build a good size designer home on this land. Total area 651 Sq mt. Frontage:12.19 Rear: 27.63 Side1: 43.31 Side2: 31.58 Thanks Re: Help - buying irregular size land 2Nov 18, 2016 1:02 am We have just completed our home on a slightly larger sized block than this but with similar dimensions and triangular shape - however our frontage is the wider part and the rear narrower. We also had a slope down to the right side to contend with too. A good builder will be able to design and work a home that has all you need so don't stress too much. Does the area have many requirements that you have to fulfill? Re: Help - buying irregular size land 3Nov 18, 2016 2:57 pm Is the block in an established area or is it a land release? If it's established you will need to look at where your neighbours houses sit on the block as this will determine where your house sits. Does the block gradually widen ? You will probably want to talk to a custom builder as a standard project home may not make the most of your block. Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6440 1 1923 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7496 |
