Browse Forums Building A New House 1 Oct 25, 2016 8:15 am Hi there we have bought a sloping block in newcastle. It is a large 1300sqm block with an overall fall of 4 meters, with the main building area being 2 meters of fall. We are going to get the land cut and filled before we deal with any builders and are wondering what the process is. Do we get a surveyor or engineer to come out to the land to work out the best way to cut and fill and pass this info onto our excavator? We are completely new to this and have no idea where to start. Any info is greatly appreciated. Re: Advice for cut and filling sloping block 2Oct 25, 2016 8:22 am Hi, Disclaimer: I am not an expert I believe the cut and fill depends on the house plan you choose... I put the garage on the lower side of the slope so I can step into the house and don't need to do lot of cut and fill to make the block dead flat... Other option is you can have split house..like garage and lounge in one level and the rest of the house bit above (if it make sense) If it is me, I would choose a plan first and then do the cut and fill or let the builder do it... Cheers, Re: Advice for cut and filling sloping block 3Oct 25, 2016 8:32 am Thanks reg. all of our neighbours have been able to level out the first level with a slight slope down from the street into the level part. Some have then gone on to add more fill for split level or to leave as is for two story. I guess my main question is who do i contact to get the right measurments etc to give to our excavatour for cutting and filling the land. If we level a large enough area we can do both split or two story with enough room for a pool on the same level. We are dealing with a couple of project home builders to determine the perfect house but havent worked that part out yet 100% Re: Advice for cut and filling sloping block 5Oct 25, 2016 12:40 pm We also have a slope and have already selected our house. The builder is going to cut and fill the site as they need to in accordance to what is best for the house we have chosen. Re: Advice for cut and filling sloping block 6Oct 25, 2016 12:42 pm newwyhouse22 Hi there we have bought a sloping block in newcastle. It is a large 1300sqm block with an overall fall of 4 meters, with the main building area being 2 meters of fall. We are going to get the land cut and filled before we deal with any builders and are wondering what the process is. Do we get a surveyor or engineer to come out to the land to work out the best way to cut and fill and pass this info onto our excavator? We are completely new to this and have no idea where to start. Any info is greatly appreciated. G'day, We too are building in Newy with a sloping block - I think I saw you post in the Mojo Homes thread. Where abouts are you building? We are at Pacific Dunes Medowie. I think the most cut/fill we were allowed with Mojo was 1m, which is same as you with 2m fall across the build site. We are building single level with drop edge beams - extra site costs allowance for us has been $25k because of the slope. Would be interested to hear how you go with excavation before locking in a builder, I did think it might be beneficial because we could level the backyard and everything in one go. Cheers, Mort. Re: Advice for cut and filling sloping block 7Oct 25, 2016 12:47 pm Morticus newwyhouse22 Hi there we have bought a sloping block in newcastle. It is a large 1300sqm block with an overall fall of 4 meters, with the main building area being 2 meters of fall. We are going to get the land cut and filled before we deal with any builders and are wondering what the process is. Do we get a surveyor or engineer to come out to the land to work out the best way to cut and fill and pass this info onto our excavator? We are completely new to this and have no idea where to start. Any info is greatly appreciated. G'day, We too are building in Newy with a sloping block - I think I saw you post in the Mojo Homes thread. Where abouts are you building? We are at Pacific Dunes Medowie. I think the most cut/fill we were allowed with Mojo was 1m, which is same as you with 2m fall across the build site. We are building single level with drop edge beams - extra site costs allowance for us has been $25k because of the slope. Would be interested to hear how you go with excavation before locking in a builder, I did think it might be beneficial because we could level the backyard and everything in one go. Cheers, Mort. We are building with Mojo too! The Enigma 41 - was the extra $25 allocated in your tender? Re: Advice for cut and filling sloping block 8Oct 25, 2016 12:49 pm We looked into doing earthworks before contracting a builder. But we're adviced it's best to have a house design/plan first. That way they know the best way to make it all work together. We got the builder to I corporate room for a shed and flattening our front yard in the cut and fill. We also got the earthworks dude to do some work in our back yard once he had done our site. Re: Advice for cut and filling sloping block 9Oct 25, 2016 1:17 pm purpleal We are building with Mojo too! The Enigma 41 - was the extra $25 allocated in your tender? We are building the verve 25 - we wanted the bohemia 29 but the extra site costs ate into our budget. the $25k is a "Provisional allowance - provide an allowance for additional site costs". Whats the best way to approach the excavator driver? do they give you a heads up they are on their way to do your site works? We also want the front leveled a bit and also a flat area right up the back for my double shed. We are on a corner block so have side access at rear to get to the shed. Re: Advice for cut and filling sloping block 10Oct 25, 2016 5:24 pm Morticus newwyhouse22 Hi there we have bought a sloping block in newcastle. It is a large 1300sqm block with an overall fall of 4 meters, with the main building area being 2 meters of fall. We are going to get the land cut and filled before we deal with any builders and are wondering what the process is. Do we get a surveyor or engineer to come out to the land to work out the best way to cut and fill and pass this info onto our excavator? We are completely new to this and have no idea where to start. Any info is greatly appreciated. G'day, We too are building in Newy with a sloping block - I think I saw you post in the Mojo Homes thread. Where abouts are you building? We are at Pacific Dunes Medowie. I think the most cut/fill we were allowed with Mojo was 1m, which is same as you with 2m fall across the build site. We are building single level with drop edge beams - extra site costs allowance for us has been $25k because of the slope. Would be interested to hear how you go with excavation before locking in a builder, I did think it might be beneficial because we could level the backyard and everything in one go. Cheers, Mort. Hey! We are building in cameron park. We just purchased our land, we actually were looking at pacific dunes its so lovely out there but then this block of land came up for sale and is close to our inlaws and has a bush outlook. Our neighbours have all leveled and built up their blocks and the sales lady believes we can just do the one level (two stories) with extra long peirs. We have family that are excavators so thats why we are getting the work done before a builder, and then once we choose our builder they can do any extra work needed but we are hoping it will save us a bit of money in site costs, because there is lots of extras that i want in the house! Lol What house are you guys doing? Where are you at in your build? Re: Advice for cut and filling sloping block 11Oct 25, 2016 5:26 pm Craigasaurus We looked into doing earthworks before contracting a builder. But we're adviced it's best to have a house design/plan first. That way they know the best way to make it all work together. We got the builder to I corporate room for a shed and flattening our front yard in the cut and fill. We also got the earthworks dude to do some work in our back yard once he had done our site. Hi Craig We were thinking about that, but we have a design of how we want our land with the levels and retaining walls, so we kind of want to level, cut and fill and then see what we can do with it. We have family members who are excavators so can hopefully get the work done pretty cheap, and this can be done while we save up for the deposit on the construction loan. What we thought is we will do majority of the work and then the builder can come in and adjust what needs to be done for the house. Re: Advice for cut and filling sloping block 12Oct 25, 2016 5:27 pm purpleal Morticus newwyhouse22 Hi there we have bought a sloping block in newcastle. It is a large 1300sqm block with an overall fall of 4 meters, with the main building area being 2 meters of fall. We are going to get the land cut and filled before we deal with any builders and are wondering what the process is. Do we get a surveyor or engineer to come out to the land to work out the best way to cut and fill and pass this info onto our excavator? We are completely new to this and have no idea where to start. Any info is greatly appreciated. G'day, We too are building in Newy with a sloping block - I think I saw you post in the Mojo Homes thread. Where abouts are you building? We are at Pacific Dunes Medowie. I think the most cut/fill we were allowed with Mojo was 1m, which is same as you with 2m fall across the build site. We are building single level with drop edge beams - extra site costs allowance for us has been $25k because of the slope. Would be interested to hear how you go with excavation before locking in a builder, I did think it might be beneficial because we could level the backyard and everything in one go. Cheers, Mort. We are building with Mojo too! The Enigma 41 - was the extra $25 allocated in your tender? We are looking at the enigma, although prb the 36! Where are you at in your build? How are you finding the experience? Re: Advice for cut and filling sloping block 13Oct 25, 2016 6:00 pm We are doing a KDRB on the Northern Beaches. We love the house however, admin can be slow at times. Generally speaking it has been a very positive experience. We have our plans appointment towards the end of Nov and colour selections at the end of November. We paid our deposit on the 31st of July. Re: Advice for cut and filling sloping block 14Oct 25, 2016 6:41 pm We have had to include a split into our design as well as cut/full over 1m. Without being an expert, I would have thought you would have needed to choose a house first or get one designed to fit your topography. To ensure the gradient of our driveway was acceptable, we added the split so that was ok and we didn't have a huge step off the alfresco. If you see my plans on my thread you'll see what I mean. - otherwise known as Kym - Re: Advice for cut and filling sloping block 15Oct 26, 2016 8:06 am newwyhouse22 Hey! We are building in cameron park. We just purchased our land, we actually were looking at pacific dunes its so lovely out there but then this block of land came up for sale and is close to our inlaws and has a bush outlook. Our neighbours have all leveled and built up their blocks and the sales lady believes we can just do the one level (two stories) with extra long peirs. We have family that are excavators so thats why we are getting the work done before a builder, and then once we choose our builder they can do any extra work needed but we are hoping it will save us a bit of money in site costs, because there is lots of extras that i want in the house! Lol What house are you guys doing? Where are you at in your build? We are building the Verve 25, which will have a 600mm split at the front of the house and a lower set garage to reduce the incline on the driveway. This will mean approx 3.3m ceilings in the main bedroom and front hallway, then a few steps to get to the back of the house. Something different i guess! Seems there are a fair few design requirements for Pacific Dunes but we figure the house will look good once its all done. Unfortunately land doesn't register until March so we wont be able to commence until then, however we have heaps of stuff to do so i'm sure the time will fly. How many cartons of beer do I need to throw your way to get your family to do my extra excavations!! Re: Advice for cut and filling sloping block 16Oct 27, 2016 8:29 am Morticus newwyhouse22 Hey! We are building in cameron park. We just purchased our land, we actually were looking at pacific dunes its so lovely out there but then this block of land came up for sale and is close to our inlaws and has a bush outlook. Our neighbours have all leveled and built up their blocks and the sales lady believes we can just do the one level (two stories) with extra long peirs. We have family that are excavators so thats why we are getting the work done before a builder, and then once we choose our builder they can do any extra work needed but we are hoping it will save us a bit of money in site costs, because there is lots of extras that i want in the house! Lol What house are you guys doing? Where are you at in your build? We are building the Verve 25, which will have a 600mm split at the front of the house and a lower set garage to reduce the incline on the driveway. This will mean approx 3.3m ceilings in the main bedroom and front hallway, then a few steps to get to the back of the house. Something different i guess! Seems there are a fair few design requirements for Pacific Dunes but we figure the house will look good once its all done. Unfortunately land doesn't register until March so we wont be able to commence until then, however we have heaps of stuff to do so i'm sure the time will fly. How many cartons of beer do I need to throw your way to get your family to do my extra excavations!! Yes i think the waiting game is a good thing, will have plenty of time to make all the important decisions and be certain of them! Im terrible at making up my mind so im just going to research every aspect so im ready to go next year. Did adding the split add a large cost? Im hoping we can avoid it but we will have to wait and see. I have spoken to my mojo sales lady and we are going to use the enigma as a guide line for cutting and filling and hopefully it will turn out we can have one flat slab. She put the house on a picture of our site and i didnt realise how massive the block is the house looks tiny! If only we could afford a bigger house! We will just have to do plenty of garden i think! Yep! We are very lucky, although in saying that he hasnt actually seen the block and how big it is, so he might not be a family member for long Re: Advice for cut and filling sloping block 17Oct 28, 2016 9:28 pm Our split was about $2700 and that includes the 2.7m ceilings in the lower section (over half the house) - otherwise known as Kym - Advice for cut and filling sloping block 18Nov 07, 2016 8:54 pm needsausername Our split was about $2700 and that includes the 2.7m ceilings in the lower section (over half the house) Hey thanks for your reply $2700 seems very cheap! I was thinking like an extra 20grand or something! With mojo their standard ceilings we are getting included at 2700mm, i would assume if they needed to the split would be done at the back end of the house so that would make the ceiling super high which would probably be a nice thing, i wonder if they would then increase the height of the alfresco area... Give Jonathan a call. Tell him you know me. He is in my opinion the best surveyor I have ever worked with. His number is 0425 285 622 All the best Simeon 3 12422 i did click it, still couldnt make it out rofl. in any case, doesnt look like too extreme a slope, you may be in luck. Just shoot out some emails to volume builders in… 3 18572 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31284 |
