Thanks Norfolk, this is really key information. I am at pre construction stage and will raise this point with my PCA and how they going to ensure that it is taken care of.
Cheers
Browse Forums Building A New House Re: Rawson Homes - General Thread 749Mar 01, 2021 10:46 am Hi guys I didn't want to create a separate thread for this, and assume people search on keywords anyway & so here was as good a place as any to query. I am building a slightly modified Avoca 26 design. Just wanted to reach out to see if anyone else has built this design and what facade they went with. I have chosen the Vogue facade, but have differing feedback from Rawson about 'what' that actually is (e.g. render, brick, weatherboard, combo, etc.). The 'artists impression' version on the website depicts rendered finish to the front, but my pre-construction plans indicate that its selected face brick. Or perhaps someone can tell me where I might be able to see an Avoca built so that I can get a look. Sadly, they don't have that design as a display anywhere. Any feedback from anyone would be great! Cheers Re: Rawson Homes - General Thread 750Mar 01, 2021 5:29 pm You can only go by the preconstruction plans etc and your specific plan documents. The contract states marketing material isn't part of the contract. So if there is something missing you think should be in there, make sure its on your plan and also tender/selections, otherwise you will have trouble having it included. If it says face brick, thats what it will be, unless you get it corrected or raised as a variation. Re: Rawson Homes - General Thread 751Mar 01, 2021 6:33 pm luxbuild You can only go by the preconstruction plans etc and your specific plan documents. The contract states marketing material isn't part of the contract. So if there is something missing you think should be in there, make sure its on your plan and also tender/selections, otherwise you will have trouble having it included. If it says face brick, thats what it will be, unless you get it corrected or raised as a variation. Hi guys, I plan to change my facade from vogue to trend and has requested for the brick for the top floor instead of cladding. Would these changes increase the cost significantly? Re: Rawson Homes - General Thread 752Mar 01, 2021 8:41 pm Depending on the design they might need to add steel beams to support the extra weight of the bricks. Your choice of bricks could also significantly add to the cost. So yes, it could be expensive to go full brick. I'd suggest picking a brick that the colour goes most of the way through, so if there are chips its not a noticeable. If you pick a glazed one they charge crazy prices as they expect they'll have to throw a lot of chipped ones away. They should give you a cost on it so you can decide if its worth it. Re: Rawson Homes - General Thread 753Mar 01, 2021 10:31 pm luxbuild Depending on the design they might need to add steel beams to support the extra weight of the bricks. Your choice of bricks could also significantly add to the cost. So yes, it could be expensive to go full brick. I'd suggest picking a brick that the colour goes most of the way through, so if there are chips its not a noticeable. If you pick a glazed one they charge crazy prices as they expect they'll have to throw a lot of chipped ones away. They should give you a cost on it so you can decide if its worth it. Thanks Lux, I have my tender presentation this week. If changing to bricks will become too expensive, then, I will have no option than to go cladding which is what I'm being offered in the house and land package. Re: Rawson Homes - General Thread 754Mar 02, 2021 11:01 am I think house and land packages are different then say a knock down rebuild, and they'll give you a couple of styles to choose from. I think some estates might also have conditions on the street look and you can only pick from the pre approved styles? If they did give you an option to change, they'd might price it to discourage you. Re: Rawson Homes - General Thread 755Mar 02, 2021 11:46 am luxbuild I think house and land packages are different then say a knock down rebuild, and they'll give you a couple of styles to choose from. I think some estates might also have conditions on the street look and you can only pick from the pre approved styles? If they did give you an option to change, they'd might price it to discourage you. It is a double storey, down is brick and the top floor is cladding. From resale perspective, is a house built with cladding of lesser value than a house built with brick. Re: Rawson Homes - General Thread 756Mar 19, 2021 8:37 pm I have a question about inclusions and selections when building with Rawson. Building a single sorry house. Had my plan presentation this week (they all seem pretty slammed at the moment with the builders stimulus). I want to change my ensuite/WIR layout - so to fit within the footprint already set out for them, but for improved flow & would achieve wallspace for a towel rail (current design that went through tender has nowhere to do this - a miss on my part as much as theirs). Salesperson said walls, internals can be altered at plan presentation - indeed, I'm moving my main bedroom wall (shared with walk in storage) to make the main bed 4m x 4m. Moving a bedroom door, installing some cavity sliders and infilling an opening for this, etc. They have come back to say 'ensuite changes should have been done at tender, so... no. No change allowed'. Not happy, Jan. What are my options? Also, I got offered choice of one bath tub for main bathroom. I'm not happy with the depth. Too bad, they said, that's all that is allowed. I asked about sourcing /upgrading to another bath - can I source my own? Etc. Nope. That's it. That's the bath you get. Does this sound right? There were other arguments /inconsistenties, mistakes they've made etc., and still waiting on written confirmation that they will amend these things. I've file noted or discussions for my own reference, but that was Tuesday, it's now Friday and I haven't heard a peep from them. Not sure at what point is appropriate /reasonable to reach out to say 'hey, what are the next steps? Can we resolve these question marks please?'. It hasn't been a good start to the process Re: Rawson Homes - General Thread 757Mar 21, 2021 11:44 pm Moki I have a question about inclusions and selections when building with Rawson. Building a single sorry house. Had my plan presentation this week (they all seem pretty slammed at the moment with the builders stimulus). I want to change my ensuite/WIR layout - so to fit within the footprint already set out for them, but for improved flow & would achieve wallspace for a towel rail (current design that went through tender has nowhere to do this - a miss on my part as much as theirs). Salesperson said walls, internals can be altered at plan presentation - indeed, I'm moving my main bedroom wall (shared with walk in storage) to make the main bed 4m x 4m. Moving a bedroom door, installing some cavity sliders and infilling an opening for this, etc. They have come back to say 'ensuite changes should have been done at tender, so... no. No change allowed'. Not happy, Jan. What are my options? Also, I got offered choice of one bath tub for main bathroom. I'm not happy with the depth. Too bad, they said, that's all that is allowed. I asked about sourcing /upgrading to another bath - can I source my own? Etc. Nope. That's it. That's the bath you get. Does this sound right? There were other arguments /inconsistenties, mistakes they've made etc., and still waiting on written confirmation that they will amend these things. I've file noted or discussions for my own reference, but that was Tuesday, it's now Friday and I haven't heard a peep from them. Not sure at what point is appropriate /reasonable to reach out to say 'hey, what are the next steps? Can we resolve these question marks please?'. It hasn't been a good start to the process Our plan presentation confirmation email from Rawson had a bunch of instructions, one of which was that we should come prepared with any non structural plan changes we wanted. We moved a number of internal walls, changed room sizes, adjusted the layout of all the bathrooms (shower room, ensuite, main bathroom) and changed the front facade... just to name the main changes. By the time we finished there were over 50 variation items from our plan presentation meeting and our plan presenter didn't complain about any of it. So if you think your changes are not structural then tell them so and ask them to get on with your change requests. Having said that, making changes really slows down their process. In our experience most routine changes had a 3 week turnaround time, so best to get all your changes sorted early. Of course you can't control their mistakes, and fixing those is treated just like any other changes... so expect 3 week turnarounds for those as well. We still refer to this period as the preconstruction administration hell. It can be frustrating, but stick with it, we're a few months away from handover and it's finally appearing to be all worthwhile. Re: Rawson Homes - General Thread 758Mar 23, 2021 4:39 pm Hi all, Getting ready for the brick option. This is the PGH/Austral bricks with rawson homes Townhouse, Summervilla, Foundations and Desert - LUXURY Elements, Botanicals, Coastal Hamptons and Dark and Stormy Everyday Life, Whitsunday and Wilderness Off White PRESTIGE Highlands, Botanicals , Coastal Hamptons, Alfresco, Spinifex and Velour The Avenue, Urbane One, and Metropolis Do they allow you to choose outside the range? As we like the PGH Manhattan Trebica recycled brick appearance to be paired with monument gray painted cladding. I can’t squeezed out info from local office here as the usual their reply is to wait until the plan presentation. Thanks heaps! Re: Rawson Homes - General Thread 759Mar 23, 2021 8:59 pm Leona33 Hi all, Getting ready for the brick option. This is the PGH/Austral bricks with rawson homes Townhouse, Summervilla, Foundations and Desert - LUXURY Elements, Botanicals, Coastal Hamptons and Dark and Stormy Everyday Life, Whitsunday and Wilderness Off White PRESTIGE Highlands, Botanicals , Coastal Hamptons, Alfresco, Spinifex and Velour The Avenue, Urbane One, and Metropolis Do they allow you to choose outside the range? As we like the PGH Manhattan Trebica recycled brick appearance to be paired with monument gray painted cladding. I can’t squeezed out info from local office here as the usual their reply is to wait until the plan presentation. Thanks heaps! Rawson (like most builders) have a standard range of bricks for which the cost is included in the house base price. You can select any other bricks from PGH or Austral, but at additional cost. Rawson/PGH/Austral make this easy... if you visit a PGH or Austral display centre, tell them in the office you're a Rawson customer and ask for the brick upgrade price list. This list will give you an estimate of what each of the bricks will cost you. Depending on the size of your house the exact price for your selected brick will differ slightly from the upgrade list, but it will be close enough to help you decide. For us, we would have liked the Bowral Blue or Mowbray Blue however the upgrade price list indicated these would cost us more than $20,000 for the upgrade, which in our view wasn't good value for money. In the end we selected a brick called Maddox which is from The Avenue range by Daniel Robertson (a company owned by Austral) and was only a $1,000 upgrade. Re: Rawson Homes - General Thread 760Mar 23, 2021 9:22 pm robw17 Leona33 Hi all, Getting ready for the brick option. This is the PGH/Austral bricks with rawson homes Townhouse, Summervilla, Foundations and Desert - LUXURY Elements, Botanicals, Coastal Hamptons and Dark and Stormy Everyday Life, Whitsunday and Wilderness Off White PRESTIGE Highlands, Botanicals , Coastal Hamptons, Alfresco, Spinifex and Velour The Avenue, Urbane One, and Metropolis Do they allow you to choose outside the range? As we like the PGH Manhattan Trebica recycled brick appearance to be paired with monument gray painted cladding. I can’t squeezed out info from local office here as the usual their reply is to wait until the plan presentation. Thanks heaps! Rawson (like most builders) have a standard range of bricks for which the cost is included in the house base price. You can select any other bricks from PGH or Austral, but at additional cost. Rawson/PGH/Austral make this easy... if you visit a PGH or Austral display centre, tell them in the office you're a Rawson customer and ask for the brick upgrade price list. This list will give you an estimate of what each of the bricks will cost you. Depending on the size of your house the exact price for your selected brick will differ slightly from the upgrade list, but it will be close enough to help you decide. For us, we would have liked the Bowral Blue or Mowbray Blue however the upgrade price list indicated these would cost us more than $20,000 for the upgrade, which in our view wasn't good value for money. In the end we selected a brick called Maddox which is from The Avenue range by Daniel Robertson (a company owned by Austral) and was only a $1,000 upgrade. Thanks! That helps a lot! You should check your detail drawings, it may show downpipe within brick pier. 14 14121 Just started the Build process for Chifley 42 with Rawson homes, will keep you all posted with the Build progress. 0 2463 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11121 |
