Just wondering your thoughts on the Rawson inclusions and LUX package. How do you think it compares to other builders. Also what is the driveway allowance in sqm?
thanks
Approx. $130 a square metre for extra driveway.
Browse Forums Building A New House Re: Rawson Homes - General Thread 401Oct 30, 2017 4:27 pm Building the Rawson Edge 39 MKI - https://forum.homeone.com.au/viewtopic.php?f=31&t=89729&p=1756917#p1756917 Re: Rawson Homes - General Thread 409Nov 06, 2017 6:04 pm Building the Rawson Edge 39 MKI - https://forum.homeone.com.au/viewtopic.php?f=31&t=89729&p=1756917#p1756917 Re: Rawson Homes - General Thread 412Nov 12, 2017 10:52 pm Hi All, Appreciate if you can give some information about Electrical appointment.What all do we need to look at other than putting extra powerpoints? Sorry for the long list of questions below, but I'm having no clue about how to move forward. 1. Is it a good idea to put only the batten points and NOT buy lights from Rawson(except downlights). Will we be able to save some $$? I was thinking about the ceiling lights, pendant lights, external lights etc. 2. For security camera, what is the good option. Can we just ask Rawson to do the cabling(cat6?) and then we can install the system later? 3. What all we need to consider at the external.. Not sure whether we need external junction boxes(don't know why is it used for, but saw in some forums) and external powerpoints? Whats your experience. 4. Are Sensor lights good to have above garage? Rawson has a sensor flood light which costs $255 5. Is NBN Hills Box required? 6. For Downlights, warm white or cool white is preferred? 7. Is it better to put Foxtell prewiring? Satelitte or cable connection better? (I don't have foxtel right now) 8. Video intercom is an upgrade as well costing $1350.Would it be good to do this from Rawson itself? Thanks, Neetha Re: Rawson Homes - General Thread 413Nov 13, 2017 7:32 am neetha Hi All, Appreciate if you can give some information about Electrical appointment.What all do we need to look at other than putting extra powerpoints? Sorry for the long list of questions below, but I'm having no clue about how to move forward. 1. Is it a good idea to put only the batten points and NOT buy lights from Rawson(except downlights). Will we be able to save some $$? I was thinking about the ceiling lights, pendant lights, external lights etc. 2. For security camera, what is the good option. Can we just ask Rawson to do the cabling(cat6?) and then we can install the system later? 3. What all we need to consider at the external.. Not sure whether we need external junction boxes(don't know why is it used for, but saw in some forums) and external powerpoints? Whats your experience. 4. Are Sensor lights good to have above garage? Rawson has a sensor flood light which costs $255 5. Is NBN Hills Box required? 6. For Downlights, warm white or cool white is preferred? 7. Is it better to put Foxtell prewiring? Satelitte or cable connection better? (I don't have foxtel right now) 8. Video intercom is an upgrade as well costing $1350.Would it be good to do this from Rawson itself? Thanks, Neetha 1. Depends on the lights you want. If they need to be hardwired then better to get Rawsons to do it. But if just connect to a baton fitting then not much point. 3. Get them to put in external PowerPoints and any lights sensors you want now. Far easier especially if double story. 4. Yes sensor outside garage is a must IMO. 5. No a Hills box is not required. That said this day and age you need some data cabling (contrary to what many say WiFI doesn’t do it all). And even with wifi you need somewhere to terminate it. Can just be a small patch area with standard data sockets or a hub. Just depends. 6. Depends where. Cooler in kitchens etc and warmer in living area. I have M-Elec D13 multis that were installed by Rawsons that have a switch so you can choose. They are pretty good. 7. Double story for sure get a pre wire or if you want outlets on internal walls. As to what it depends on where you live. And you don’t get a choice of sat or cable. If you are in cable area it is a given it will be cable. That will also more than likely be your NBN. But no cable then it will be satellite. 8. Ther are cheaper video intercoms but doing afterwards is harder to do. So $1350 is at the upper end of what I would pay. Re: Rawson Homes - General Thread 414Nov 13, 2017 10:36 am neetha Hi All, Appreciate if you can give some information about Electrical appointment.What all do we need to look at other than putting extra powerpoints? Sorry for the long list of questions below, but I'm having no clue about how to move forward. 1. Is it a good idea to put only the batten points and NOT buy lights from Rawson(except downlights). Will we be able to save some $$? I was thinking about the ceiling lights, pendant lights, external lights etc. 2. For security camera, what is the good option. Can we just ask Rawson to do the cabling(cat6?) and then we can install the system later? 3. What all we need to consider at the external.. Not sure whether we need external junction boxes(don't know why is it used for, but saw in some forums) and external powerpoints? Whats your experience. 4. Are Sensor lights good to have above garage? Rawson has a sensor flood light which costs $255 5. Is NBN Hills Box required? 6. For Downlights, warm white or cool white is preferred? 7. Is it better to put Foxtell prewiring? Satelitte or cable connection better? (I don't have foxtel right now) 8. Video intercom is an upgrade as well costing $1350.Would it be good to do this from Rawson itself? Thanks, Neetha 1. I read this a fair bit on blogs, and homeone before we did our build.. we put a couple of batten points, so we can change it to a pendent layer, and it cost $55 to rawson, and after chatting to the sparky yesterday, he charges $80 for him to install, so all up it will cost me $135 per light to not have it done through rawson (the same with ceiling fans) - you then have the additional cost of the ceiling fan.. so it is probably worth looking at the price of pendents, and comparing it to rawsons price. I know rawson in newcastle use becon lighting as their suppler , so probably worth finding out the supplier they use for you so you can compare apples to apples. 2.do not get a swan system. get rawson to run data to where you want the cameras (I got them to run cat6, but cat5e would be fine), and get them terminated at where you want your NVR/monitor/mouse to be. you can have them ran back to where you have all your network points to be, but may not suite.. I have put 4mp hikvision cameras around my place. 3. external junction boxes are just a box that electrical cable gets ran to so you can install your own lighting afterwards. if you have a 2 story house rawson will run a JB to your external doors (if single story you will get a batten fitting) 4. personal choice... I personally don't like them.. no point having them turning on using electricitiy at any form of movement. our neighbours have them, and they turn on everytime someone drives past their house. we will just turn an external light on if we are expecting someone. 5. I asked for it to be removed before the tender, I was told I couldn't, and I would need to speak to the Rawson Newcastle CEO, I did, and he was a complete idiot, and I had to argue black and blue for it to be removed. it was by far the worse thing I experienced during the whole build. in the end I got what I wanted (no hills home hub). i know others have got rid of theirs with no problem. 6. warm in bedrooms, cool in hallway and living. 7. sorry, cant help, never have, never will have foxtel. 8. I really dont get video intercoms. I am sure they are good in some circumstances if you have a gate at your driveway, and have it wired to there, or if you are super paranoid and never answer the door to anyone. but for a general residential purpose, I would never answer and talk to the person at the front door, when it would be quicker to just walk to the door and answer it. We got $475 back for deleting our audio intercom, and I just put in a $22 battery door bell on the weekend, that has multiple chimes, and can be heard anywhere in the house. if you are keen on getting video, maybe look at something like ring (https://ring.com/) -if it needs wiring, just get rawson to do that. Re: Rawson Homes - General Thread 415Nov 13, 2017 11:13 am The simplest solution to driveway sensors that light up when the neighbours come home or someone drives down the street is to adjust them properly! They need to be properly pointed and the sensitivity adjusted. Mine only turn on if someone walks up to MY front door or gets half way up my driveway. Though yes my neighbours turns on if I walk down the side of the house between us but that’s because theirs is too sensitive and not correctly aligned. And not everyone can turn a light on before they go out (knowing they coming back before dark) or before they expect someone. Re: Rawson Homes - General Thread 416Nov 13, 2017 11:23 am wreckedandjealous neetha Hi All, Appreciate if you can give some information about Electrical appointment.What all do we need to look at other than putting extra powerpoints? Sorry for the long list of questions below, but I'm having no clue about how to move forward. 1. Is it a good idea to put only the batten points and NOT buy lights from Rawson(except downlights). Will we be able to save some $$? I was thinking about the ceiling lights, pendant lights, external lights etc. 2. For security camera, what is the good option. Can we just ask Rawson to do the cabling(cat6?) and then we can install the system later? 3. What all we need to consider at the external.. Not sure whether we need external junction boxes(don't know why is it used for, but saw in some forums) and external powerpoints? Whats your experience. 4. Are Sensor lights good to have above garage? Rawson has a sensor flood light which costs $255 5. Is NBN Hills Box required? 6. For Downlights, warm white or cool white is preferred? 7. Is it better to put Foxtell prewiring? Satelitte or cable connection better? (I don't have foxtel right now) 8. Video intercom is an upgrade as well costing $1350.Would it be good to do this from Rawson itself? Thanks, Neetha 1. I read this a fair bit on blogs, and homeone before we did our build.. we put a couple of batten points, so we can change it to a pendent layer, and it cost $55 to rawson, and after chatting to the sparky yesterday, he charges $80 for him to install, so all up it will cost me $135 per light to not have it done through rawson (the same with ceiling fans) - you then have the additional cost of the ceiling fan.. so it is probably worth looking at the price of pendents, and comparing it to rawsons price. I know rawson in newcastle use becon lighting as their suppler , so probably worth finding out the supplier they use for you so you can compare apples to apples. 2.do not get a swan system. get rawson to run data to where you want the cameras (I got them to run cat6, but cat5e would be fine), and get them terminated at where you want your NVR/monitor/mouse to be. you can have them ran back to where you have all your network points to be, but may not suite.. I have put 4mp hikvision cameras around my place. 3. external junction boxes are just a box that electrical cable gets ran to so you can install your own lighting afterwards. if you have a 2 story house rawson will run a JB to your external doors (if single story you will get a batten fitting) 4. personal choice... I personally don't like them.. no point having them turning on using electricitiy at any form of movement. our neighbours have them, and they turn on everytime someone drives past their house. we will just turn an external light on if we are expecting someone. 5. I asked for it to be removed before the tender, I was told I couldn't, and I would need to speak to the Rawson Newcastle CEO, I did, and he was a complete idiot, and I had to argue black and blue for it to be removed. it was by far the worse thing I experienced during the whole build. in the end I got what I wanted (no hills home hub). i know others have got rid of theirs with no problem. 6. warm in bedrooms, cool in hallway and living. 7. sorry, cant help, never have, never will have foxtel. 8. I really dont get video intercoms. I am sure they are good in some circumstances if you have a gate at your driveway, and have it wired to there, or if you are super paranoid and never answer the door to anyone. but for a general residential purpose, I would never answer and talk to the person at the front door, when it would be quicker to just walk to the door and answer it. We got $475 back for deleting our audio intercom, and I just put in a $22 battery door bell on the weekend, that has multiple chimes, and can be heard anywhere in the house. if you are keen on getting video, maybe look at something like ring (https://ring.com/) -if it needs wiring, just get rawson to do that. How funny that they insist on making it hard for you to get rid of it, and equally hard for us to have it! Re: Rawson Homes - General Thread 417Nov 13, 2017 12:13 pm AJW The simplest solution to driveway sensors that light up when the neighbours come home or someone drives down the street is to adjust them properly! They need to be properly pointed and the sensitivity adjusted. Mine only turn on if someone walks up to MY front door or gets half way up my driveway. Though yes my neighbours turns on if I walk down the side of the house between us but that’s because theirs is too sensitive and not correctly aligned. And not everyone can turn a light on before they go out (knowing they coming back before dark) or before they expect someone. agree that it is as simple as adjusting them, but so many people don't.. I guess I always grew up without having them at my parents house, and never felt the need to have one. (hence why I said that is all up to personal preference. Rawson Homes - General Thread 418Nov 13, 2017 12:50 pm 1. Is it a good idea to put only the batten points and NOT buy lights from Rawson(except downlights). Will we be able to save some $$? I was thinking about the ceiling lights, pendant lights, external lights etc. > Strongly suggest you look through this thread first. The supplied downlights and fittings sourced from beacon are rubbish. Ask a lighting design engineer - general Q&A https://r.tapatalk.com/shareLink?share_ ... are_type=t 2. For security camera, what is the good option. Can we just ask Rawson to do the cabling(cat6?) and then we can install the system later? > Once again. Consider the areas to monitor and have Rawson provide an cat6 run to the roof cavity or eave. Get a proper company to supply and install the system. The electrical contractors they use aren't very good at post install. You'll never get support from them if you have issues. 3. What all we need to consider at the external.. Not sure whether we need external junction boxes(don't know why is it used for, but saw in some forums) and external powerpoints? Whats your experience. > Put external jboxes in. Don't get the halogen spot light ones Rawson supply from beacon. They are crap. 1 year in and my ones are faded and look very ordinary now. Think about putting a power point in your alfresco and either side of your house and maybe one near the front in case you like to use 240v blowers and or mowers. You'll get a double point where your tank is, along with the gas hot water unit so keep that in mind when your thinking about where to put them. 4. Are Sensor lights good to have above garage? Rawson has a sensor flood light which costs $255 > Way overpriced for the poor quality units stocked by beacon. Save your money and get one from a quality lighting store. 5. Is NBN Hills Box required? > As others have already advised, consider removing this as the cabinet is too shallow and restrictive. 6. For Downlights, warm white or cool white is preferred? > Personally, warm white is better. Cool white can be quite stark and you shouldn't mix one with the other as it will look and feel wrong. Check through the link provided above. 7. Is it better to put Foxtell prewiring? Satelitte or cable connection better? (I don't have foxtel right now) > Nowadays I'd say no to foxtel and use "foxtel now" anyway. But if your planning to get Telstra cable, get it. It will work out cheaper if you've got plans to use nbn cable as well. 8. Video intercom is an upgrade as well costing $1350.Would it be good to do this from Rawson itself? > Kind of overkill of your planning to do video monitoring anyway. Just take the option of a wireless doorbell. $20. My 2c Re: Rawson Homes - General Thread 419Nov 15, 2017 7:44 am For those who have moved in - what NBN equipment does Rawson install? I know they do the hills hub but keen to know whether they install the external nbn utility box and/or the internal NTD/connection box or whether these will be a job for nbnco when I connect with a provider. Re: Rawson Homes - General Thread 420Nov 15, 2017 8:12 am NBN installs that stuff (assuming you are in an NBN fibre area). NBN do have a preinstall program where you can ask the builder to ask NBN to install before you move in. But you need to initiate that and someone needs to be there to let them in. Rawson was ok for me with that, they organised the lot but our NBN is slightly different to standard as our NTD is outdoors installed in a meter type box. So NBN could do that without someone being home. If you are in a NBN fibre to the node or cable area then different story. Oh our install was different because our estate startered our as Transact rather than NBN, NBN brought their fibre network a few years back but Transact had to finish off the estate. So the estate is done to different install standards and Transacts install standard was outdoor NTD. Must admit I like it and am not sure why NBN doesn’t do that as the standard method for new estates. Would be hard as retrofit of course. You should check your detail drawings, it may show downpipe within brick pier. 14 14165 Just started the Build process for Chifley 42 with Rawson homes, will keep you all posted with the Build progress. 0 2625 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11198 |
