Browse Forums Building A New House 1 Oct 10, 2016 11:29 pm Hi, Need some advice on a retaining wall. A builder is building a spec home next to our block of land that we will be starting to build on in the coming weeks. They commenced construction before any one else and have cut and filled there block about .5m. They have then installed a retaining wall about 200mm from the boundary around the whole property. The problem is we are also going to cut and fill .5m so on our shared boundary there is going to be another .5m of fill. As the builder has already constructed his retaining wall to .5m they are saying we have to build a secondary retaining wall on out side of the property. This does no make sense to me and I think since he has cut and I have filled a joint retaining wall would be better. We are on the Sunshine Coast QLD and if any one has any advice on what we could do would be great. Cheers, Donald and Madeline Aurora 32/18 with Stylemaster Homes Beerwah, Sunshine Coast, QLD Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=84479 Re: Advice on Retaining Wall 3Oct 11, 2016 6:04 am This is all I got from council: Retaining Walls located on or near property boundaries: If your new retaining wall or work on an existing retaining wall has the potential to impact on a neighbour, it is recommended that you speak to the neighbour before beginning any work. This helps avoid disputes or legal civil action arising during or after the construction work. Further information in relation to building work disputes on or near property boundaries can be found at the Queensland Government website: www.qld.gov.au/law/housing-andneighbour ... dbuildings The sharing of costs for the construction or maintenance of a boundary retaining wall is a civil matter that must be negotiated between neighbours. Council does not provide advice on these matters or provide dispute resolution. The problem is that the builder has rushed in a built a retaining wall near the boundary that suits there cut but doesn't allow for the fill we will be doing. Cheers, Donald and Madeline Aurora 32/18 with Stylemaster Homes Beerwah, Sunshine Coast, QLD Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=84479 Re: Advice on Retaining Wall 4Oct 11, 2016 8:11 am Yep sadly majority of the time, person that is retaining pays. So they have payed when they where retaining their land. If you now need to add a new one due to your site works, it is solely your responsibility. Yes, a joint retaining wall would of been ideal but they would of had no idea what you where planning when they started designing months ago. Sorry to be bearer of bad news. Re: Advice on Retaining Wall 5Oct 11, 2016 8:19 am Yes they could have known by simplying asking. We had purchased our land before them and had our plans done before them I guess thats why council recommends you speak to your neighbours before beginning work. Cheers, Donald and Madeline Aurora 32/18 with Stylemaster Homes Beerwah, Sunshine Coast, QLD Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=84479 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17478 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6900 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45791 |
