Browse Forums Building A New House 1 Oct 04, 2016 3:14 pm Hello, We are at a very early stage of our building process, trying to come up with reasonable budget for the project. One of the biggest unknowns is site costs. Pretty much every buillder says this won't be confirmed under soil test is done however they provide some ballpark estimates based on engineering plan. The issue is that the quotes are very different. Some say it will cost us $15k, others quote $30k and today we were told to allow $70k for site costs Our block is on a sloppy land however we expect it will be levelled with extra fill and retaining walls (see the attached plan, our site is marked with the star). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The work will be done by the estate developer and it's included in the cost of our land. So in the end the fall is only about 40cm but that would include about 3m of fill. The developer have also said, they provide us with 'M' class compacting certificate. However pretty much every builder says we need piering to support the slab anyway. And the one with the highest quote has also mentioned need of suspended slab, additional connections charges etc. Has anyone dealt with a similar situation and can suggest what budget should we allow for our site? Appreciate any advice. Re: Estimated site costs 2Oct 04, 2016 5:03 pm It's so hard to know. I can't help much, but I'll share my experience anyway. I expected flat land to build on, 294m2 block, but by the time the land settled the estate had put a lot of uncontrolled fill on the land. Original quote for site costs was about 10k with most builders, after soil test with my builder I had to pay another 6k due to reinforcement needed (thanks estate people!!) and I also have a rock clause cause which says if they find rock I have to pay for it to be removed.. which builder said could be 6k+ depending on how many rocks they find. Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 9977 I am not sure whether Perth has its own way of doing things in regards to this. Most of Perth has class A (sandy soil), except for some areas near rivers or hills. 2 13100 Is anyone building with Mojo and have a recent site cost tender 0 15952 |
