Metricon Liberty 45, Ryde NSW
viewtopic.php?t=82846
Browse Forums Building A New House Re: North Shore Newhaven (Sydney) 81Feb 15, 2017 10:53 pm Build thread: Metricon Liberty 45 in Ryde, NSW Re: North Shore Newhaven (Sydney) 82Mar 06, 2017 11:50 pm ![]() Good progress! Did they agree to fix the rips in the wall wrap? Yeah they have but only when I escalated to the Construction Manager. He's a very reasonable chap and gets stuff resolved fast. But, having reviewed matters recently, it seems as though that patch up work hasn't progressed despite them having a contractor attend to wrap the first floor. This has now revealed even more issues like wrap not being applied tightly ( against Aust Standard and code) and overlaps not being taped correctly in places where it is <150mm. The latest progress on my house is that the second floor is installed and the eave linings and top half of the downpipes have been fitted. They were supposed to render but all this wet weather has stopped them for attending site. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 84Mar 15, 2017 7:40 pm Electrical rough in happened today. Lucky I met them on site because it turns out there was no data point provisioned from the nbn box to under the stairs where I will put the router. So had to call Vaccaro and hand over the credit card plus pay for a couple of power points and light points and noggins to be installed over the dining table and stair void for future lighting solutions. Would have been pretty screwed (excuse the pun) with out the pre data wiring for nbn. Also was able to discuss positioning of light switch heights too. In NSW, the standard height is 1400mm but unless you specify this, the switches will be put at 1050mm which i'm told is the VIC standard. Finally was able to discuss the Panasonic intercom that I bought and asked if they could quote me for how much to install as well as make sure that the wiring they will do is the right type since some systems use cat 6 and others use RJ45. Cat 6 is the standard wiring I understand. Was also an opportunity to discuss whether i have the right amperage wired for some of the kitchen appliances. For example, the miele speed ovens which are an oven, microwave and grill in one, need a 15 amp switch so unless you ask for it, it's hard to get it done afterward as a standard point is only 10 amps (or so i'm told). Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 85Mar 15, 2017 9:55 pm That's a good point on the light height Nom. I didn't even notice that note in our electrical plans ![]() Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: North Shore Newhaven (Sydney) 86Mar 15, 2017 11:23 pm ![]() That's a good point on the light height Nom. I didn't even notice that note in our electrical plans ![]() Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Glad you've found it helpful Q! To be honest, I had to come home today and measure what we have in our flat just to double check and sure enough, it is 1400mm to the centre of the plate. One of the sparkles did say today that the advantage of 1050mm is kids can reach it, but I find my 2.5 yr old can reach the switch at 1400mm. One other thing I just noticed, for some reason, they've put the light switch for one of the bedrooms behind a door. Hopefully I can get that changed tomorrow as that would really be annoying. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 87Mar 16, 2017 5:51 am I realised the height of the light switch the day after they installed the pre wiring. It was a bit of a debate with the wife but ended up leaving it at 1050mm. Reading this post again it brings up doubts. Oh well too late now. My Journey H1 thread | viewtopic.php?f=31&t=77665 Nev _________________ Blog | ( will start once received tender ) H1 thread | https://forum.homeone.com.au/viewtopic.php?f=31&t=77665 Re: North Shore Newhaven (Sydney) 88Mar 16, 2017 7:04 am ![]() I realised the height of the light switch the day after they installed the pre wiring. It was a bit of a debate with the wife but ended up leaving it at 1050mm. Reading this post again it brings up doubts. Oh well too late now. My Journey H1 thread | viewtopic.php?f=31&t=77665 Hi Nev, I'm sure it'll be fine. After a day or two you won't even notice I think. I'm real happy I made sure to meet the sparkies on site. I cringe thinking that i nearly didn't have the right pre wiring set up for the nbn which is already at my block. Hope your walk through goes ok today! If it's with NS, it'd be interesting to hear where he's off to next? I was told that the other SM named N who also works for M has left to go to Masterton, so they're 2 short in our area. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 89Mar 16, 2017 10:06 am ![]() ![]() I realised the height of the light switch the day after they installed the pre wiring. It was a bit of a debate with the wife but ended up leaving it at 1050mm. Reading this post again it brings up doubts. Oh well too late now. My Journey H1 thread | viewtopic.php?f=31&t=77665 Hi Nev, I'm sure it'll be fine. After a day or two you won't even notice I think. I'm real happy I made sure to meet the sparkies on site. I cringe thinking that i nearly didn't have the right pre wiring set up for the nbn which is already at my block. Hope your walk through goes ok today! If it's with NS, it'd be interesting to hear where he's off to next? I was told that the other SM named N who also works for M has left to go to Masterton, so they're 2 short in our area. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Agree I had to be onsite also for electrical and moved some things. SM rescheduled ![]() Nev _________________ Blog | ( will start once received tender ) H1 thread | https://forum.homeone.com.au/viewtopic.php?f=31&t=77665 North Shore Newhaven (Sydney) 90Mar 18, 2017 11:54 pm So I went and had a look through the house today and the electrical job looks pretty good. I was really worried about the light switch being behind the door of Bedroom 2 (see below pic) but when I went to site today, clearly someone had some common sense and put it on the other side! Thankyou Vaccaro! In some areas the drilling was a little trigger happy as holes drilled in noggins made some look like a swiss cheese. I'm also a bit concerned that the aircon installers have put too few outlets in. Contract says up to 15 outlets will be installed but we only have maybe 10 in the house. I'm a bit puzzled. How do I confirm what the correct number should be? Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 91Mar 19, 2017 1:30 am Hi nom, good to see some progress. Didnt you get an electrical plan showing all the heating/cooling outlets? If not, maybe ask them to send you the plan. Re: North Shore Newhaven (Sydney) 92Mar 19, 2017 7:27 am In Melbourne in actually tells you and has different symbols for power points at different heights which it specifies. They don't have that in nsw? Re: North Shore Newhaven (Sydney) 93Mar 19, 2017 3:45 pm ![]() Hi nom, good to see some progress. Didnt you get an electrical plan showing all the heating/cooling outlets? If not, maybe ask them to send you the plan. They don't give us a plan like that in NSW AFAIK. In the contract it states placement of outlets at the disgression of their air con contractor. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 94Mar 19, 2017 3:47 pm ![]() In Melbourne in actually tells you and has different symbols for power points at different heights which it specifies. They don't have that in nsw? All powerpoints are installed 110mm from FFL from memory. The pic above shows the power points and the light switches, and fans and light locations etc. It doesn't show where the aircon outlets go though. Only the aircon return. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 95Mar 21, 2017 4:31 pm ![]() ![]() Hi nom, good to see some progress. Didnt you get an electrical plan showing all the heating/cooling outlets? If not, maybe ask them to send you the plan. They don't give us a plan like that in NSW AFAIK. In the contract it states placement of outlets at the disgression of their air con contractor. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092[/quote Yep, I remember asking the electricals consultant about placement of outlets and she mentioned upto the a/c guy installing, and we could see if they will accomodate our wishes on the placement (don't want it above the beds) North Shore Newhaven (Sydney) 96Mar 25, 2017 12:54 am ![]() ![]() ![]() Hi nom, good to see some progress. Didnt you get an electrical plan showing all the heating/cooling outlets? If not, maybe ask them to send you the plan. They don't give us a plan like that in NSW AFAIK. In the contract it states placement of outlets at the disgression of their air con contractor. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092[/quote Yep, I remember asking the electricals consultant about placement of outlets and she mentioned upto the a/c guy installing, and we could see if they will accomodate our wishes on the placement (don't want it above the beds) In the contract it states up to 15 air con outlets. In mine, there are maybe only 10 max. Has anyone had any luck in getting a credit for the unused balance? If it was one or two I probably wouldn't mind but this is one third so .... Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 97Jun 08, 2017 1:13 am Yay! we have a front door, internal stairs and internal doors, architraves and skirting. Plus cabinetry installed too! Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - http://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 98Jun 08, 2017 1:50 am Looks fantastic Nom! Is there some extra backboard where the rangehood will go? Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: North Shore Newhaven (Sydney) 99Jun 08, 2017 2:45 am ![]() Looks fantastic Nom! Is there some extra backboard where the rangehood will go? Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Well spotted, yeah I forgot all about it. When we had our appointment with Kitchen culture, they suggested a back board as it will stop discolouration from grease etc. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - http://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 100Jun 08, 2017 8:28 am Looking great! Starting to feel like a home there ![]() Your builder has been stretching the truth by the sounds of it, there is no significant reason why a custom build should take longer, everything is basically computer… 7 2486 Hi Moudzj, You are a real champion, I think this image file will do for me. Would you recommend any alterations in the plan from the northerly aspect of the property? We… 11 3216 right. i can imagine... we figured we will have veryy less amount of time in the day having east sun and hence we finalised having our kitchen and living in the west.… 10 2892 |
