Browse Forums Building A New House Re: North Shore Newhaven (Sydney) 142Dec 14, 2017 8:00 am ![]() I’ve had some discussions with people asking about overhead cabinetry height in the kitchen. Just to explain, the default design by Metricon is that if you have a kitchen window as a back splash, then the overhead cabinetry will hang down about 20mm past the top window frame. That is to say that anyone standing outside will see the back of your cabinets! So unless that’s the look you’re going for, You need to specify during your Kitchen Culture appointment that you want the overhead cupboards raised so they are not visible from the outside. It will then be noted in your paperwork. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ One other important reason to do this is because if M don’t install the window straight according to building standard, like they have at mine, then it is quite easy for them to access the window internally and fix it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here you can see the window is 7mm bellied using a 2m level. Thank you so much for posting all the information. I will post our kitchen drawings today. Re: North Shore Newhaven (Sydney) 143Dec 14, 2017 1:59 pm ![]() Floors look great Nom! Thanks Dani! Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 144Dec 14, 2017 2:00 pm ![]() ![]() ![]() Yep, the floor is looking great! Too bad about the rectification work needed - do you have any idea of how long it'll take? Floor levelling all done so should be completed by Sat. Hebel repairer, renderer and painter booked for the week. I have lined up the driveway al There is a slight chance we could be in the week just before xmas🤞 Yeah doesn’t look likely we’ll be in For Xmas now. M are trying to force it but we had a final building inspection this week and there are a number of defects they need to fix. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 145Dec 16, 2017 8:41 pm So final coat of waterbased polyurethane went on the floor this evening and the floor looks absolutely stunning. It’s taken a lot of time and effort to get it to this finish but I am so happy with how it’s turned out. If anyone needs a floor layer, I recommend Kornel Kovacs of #timberfloors. He’s got 20 years experience and his work is worth every cent. Especially considering how helpful he has been in resolving issues with M due to the slab being uneven, Doors not being plumb and the like. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here is the floor being buffed prior to the final coat. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 146Dec 16, 2017 10:01 pm Looks good nomnom So will it be a matt finish? My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: North Shore Newhaven (Sydney) 147Dec 16, 2017 11:11 pm Wow I love it! Just the idea of having real timber floors gets me all excited! North Shore Newhaven (Sydney) 148Dec 17, 2017 12:24 am ![]() Looks good nomnom So will it be a matt finish? My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t It’s a satin finish so semi gloss. The floorer used Lobadur 2k Duo which is a commercial water based Polyurethane. Low in Chemicals and therefore low VOCs. (no smell in house). I’ve got some extra product from him too so I can coat the bottom two steps of the staircase also. Makes me shake my head though because the cheap *** maple wood that M supply as an upgrade on the staircase (but charge a fortune for) is no where near as nice as the spotted gum. Maple is also a soft wood so I’m wondering how long it will last. Anyway the polyurethane should help to make it last a little longer. Carpets on Monday! Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 149Dec 17, 2017 1:10 am ![]() Wow I love it! Just the idea of having real timber floors gets me all excited! Thank Dulie. Yeah, when a mate of mine showed me his floor in blackbutt, I was in awe. A polished timber floor looks awesome and certainly helps with the resale value. Total cost was $16.6k split as $7.5k timber, battens & plastic membrane. $9.1k labour to install, sand, lacquer, do steps and provide edging around the island/kitchen/ pantry and staircase together with removal of the skirting boards and then re attachment. If I build again, the proper way to put timber flooring in is to make sure they put it in before the staircase, the kitchen cabinetry and skirting boards. That way you don’t need to use scotia/beading/mouldings to cover up the gaps. This time around, I was satisfied enough to have the timber at least under the skirting boards. I will have to pay the painter $300 perhaps for him to use no more gaps to seal the skirting, putty up all the nail holes and then paint the entire skirting board. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 151Dec 17, 2017 10:22 am Can you take a closer pic of the finishing? We are still unsure if we getting gloss polished or a matt look. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t North Shore Newhaven (Sydney) 153Dec 17, 2017 3:01 pm ![]() Did everyone had wall warp (sisulation)??, went with standard or upgraded please share you experience please. I had my ceiling wrap (sarking). It’s not cheap but I think it worth it for the long run. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: North Shore Newhaven (Sydney) 154Dec 17, 2017 3:09 pm ![]() ![]() Did everyone had wall warp (sisulation)??, went with standard or upgraded please share you experience please. I had my ceiling wrap (sarking). It’s not cheap but I think it worth it for the long run. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t sarking is included in our base line inclusion. do you have a picture of it I was actually asking the wall wrap? Re: North Shore Newhaven (Sydney) 155Dec 17, 2017 3:12 pm ![]() ![]() Did everyone had wall warp (sisulation)??, went with standard or upgraded please share you experience please. I had my ceiling wrap (sarking). It’s not cheap but I think it worth it for the long run. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t sarking is included in our base line inclusion. do you have a picture of it I was actually asking the wall wrap? Re: North Shore Newhaven (Sydney) 156Dec 17, 2017 6:01 pm Great looking floor pics Nomnom ![]() Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: North Shore Newhaven (Sydney) 157Dec 18, 2017 8:15 am ![]() Did everyone had wall warp (sisulation)??, went with standard or upgraded please share you experience please. I think I might be the only one who’s upgraded the wall wrap to CSR bradford Thermoseal XP (single Foil) The standard wrap is envrioseal by bradford. It’s blue and has Metricons name all over it. Sorry didn’t take a pic. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 North Shore Newhaven (Sydney) 158Dec 18, 2017 8:37 am ![]() ![]() Did everyone had wall warp (sisulation)??, went with standard or upgraded please share you experience please. I think I might be the only one who’s upgraded the wall wrap to CSR bradford Thermoseal XP (single Foil) The standard wrap is envrioseal by bradford. It’s blue and has Metricons name all over it. Sorry didn’t take a pic. I think you are the only person that upgraded their wrap. Given we are in an old weatherboard house at the moment that only has the timberboard and plaster for insulation. We figured hebel, wrap, insulation and plaster should be sufficient. The sarking that we have in our ceiling is probably the same as thermoseal as it’s a thicker material and green in colour. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: North Shore Newhaven (Sydney) 159Dec 18, 2017 8:56 am ![]() Can you take a closer pic of the finishing? We are still unsure if we getting gloss polished or a matt look. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Sure, Taken this morning =) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 160Dec 18, 2017 9:07 am Wow. That looks good. Does it still have a thick layer of clear coat to protect the timber like a good finish? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Your builder has been stretching the truth by the sounds of it, there is no significant reason why a custom build should take longer, everything is basically computer… 7 2486 Hi Moudzj, You are a real champion, I think this image file will do for me. Would you recommend any alterations in the plan from the northerly aspect of the property? We… 11 3216 right. i can imagine... we figured we will have veryy less amount of time in the day having east sun and hence we finalised having our kitchen and living in the west.… 10 2892 |
