Browse Forums Building A New House 1 Sep 27, 2016 10:27 am Appreciate advice on the easement details for the land lot as I am not familiar with these terms in the plan. Lot 1382. It has been mentioned on the plan that A: 1.5m WIDE EASEMENT TO DRAIN WATER and B: 0.9m WIDE EASEMENT FOR MAINTENANCE AND ACCESS But I couldn't find A: or B: on lot 1382 except one small symbol at the front of the lot. Thanks.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Easement Query 3Sep 27, 2016 6:04 pm Can you post the full picture of the developers engineering plans? I'm pretty sure that you have a 1.5m easement at the front of your block(dotted line) but I'm not an expert I could be wrong. You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17113 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16105 Thanks - yea sounds like I need to submit build over easement application....ugh guess I better start finding someone who can do the engineering drawings 3 3321 |
