Browse Forums Building A New House 1 Sep 14, 2016 7:22 pm Hi All , I have a question related to Corner Blocks in Elara . If any one knows any information , please do let me know . Say my Lot Size is 450 m . 15 w * 30 depth . 1) Due to the corner block I have to leave setbacks for the building to construct . I am fine with this and that make sense to protect the streets , views ..etc. 2) Finally I will be fencing my 3 sides after house completion . I have some conflict information for fencing for corner blocks . What I heard was as it is a corner block , I have to leave some of my land outside the fencing on the second street side ? Is this true ? Generally we will fence all sides till the boarder of our land limits . But what I heard was for corner blocks on the second street side fencing we have to leave some of our land outside the fence ( say 1 m or so ?) .If I do that my land becomes only 14 w * 30 depth where I will loose 30m of land due to this ? Is this correct ? I spoke with Stock Lands on this and they said conflicting information too . May be a in person discussion would be better with them not in phone call . Can some one who knows / have idea on this please reply . Looking forward for valuable suggestions / information . Thanks in advance for your positive consideration to reply. Regards, Re: Stock Land - Elara - Corner Block Fencing Info 2Sep 14, 2016 7:52 pm Refer Clause 8.6 - Thesecondarystreetsideboundaryfencingmustbesetbackat least 4m behind the main building line or behind the secondary facade articulation, whichever is the greater setback. Re: Stock Land - Elara - Corner Block Fencing Info 4Sep 14, 2016 9:04 pm imrasm It means you have to leave at least 8.5 m ( 4.5 m for house setback and 4 m as per above rule ) out of your fencing Hi IMRASM , Thanks for your reply . There are two points in my initial question : 1) Setbacks - I understand we have to leave setbacks on front and sides . I am fine with it . 2) Fencing - I understand fencing should leave setbacks on all sides from building wall . That is more of leaving the space between building wall till fencing . I understand that . My question is : Do I have to leave any land outside of the Fencing for a corner block on secondary street . I heard from few people that if it is a corner block i might loose some of my own land outside the fencing border which is of no use and will link to the foot path on the side . Is that true . It seems to me a non existent issue , just cross checking. Hope I am clear. Thanks . Thanks, Re: Stock Land - Elara - Corner Block Fencing Info 5Sep 15, 2016 5:12 am Nopes ... I haven't heard of anything about leaving space between fence and lot boundary .. As far as I know and my corner build fencing plan says Your fencing must be on ur lot boundary 4 14448 Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design… 0 4840 |
