Browse Forums Building A New House Re: Building an Aegean230 with Mainvue. 182Sep 28, 2017 2:41 pm well - we had the taps put on 22/09/17. follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building an Aegean230 with Mainvue. 184Sep 29, 2017 10:14 am Awesome! You're so close now. Energy was the only thing I wasn't overly fussed about having to spend the money, it will only save you in the long run and make the house more comfortable. Our Henley Aegean45 Re: Building an Aegean230 with Mainvue. 185Sep 29, 2017 1:59 pm It should only be a couple of weeks now - so exciting. Did you go ok with Energy rating? Re: Building an Aegean230 with Mainvue. 186Oct 01, 2017 4:06 pm Rachael13 It should only be a couple of weeks now - so exciting. Did you go ok with Energy rating? Yes, just needed some extra insulation, cost us around $1,500 from memory. Our Henley Aegean45 Re: Building an Aegean230 with Mainvue. 187Oct 01, 2017 4:47 pm I think u got double glazing in ur promo - which means at the most u may need to upgrade the insulation which may probably cost around 1000 to 1500 - hopefully follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building an Aegean230 with Mainvue. 188Oct 01, 2017 8:18 pm Energy rating and what you may need to upgrade will depending on the orientation of your house on your block. If you review my link, it has what I had to upgrade as well as change window sizings to keep the aluminium windows and the original size stackers. We changed all windows from timber, which has a better energy rating, but not something that we wanted on our home. I just hope that you don't need to go through what we did. Good Luck Re: Building an Aegean230 with Mainvue. 189Oct 01, 2017 9:35 pm Rachael13 Energy rating and what you may need to upgrade will depending on the orientation of your house on your block. If you review my link, it has what I had to upgrade as well as change window sizings to keep the aluminium windows and the original size stackers. We changed all windows from timber, which has a better energy rating, but not something that we wanted on our home. I just hope that you don't need to go through what we did. Good Luck Yeah, I followed your build thread in detail when it came to the energy rating. We face north with no neighbours to our north or west side so all our living areas will have plenty of light. All windows double glazed and timber is plus none of the windows are frosted. Only issue is we have 44 down lights and both ground and first floor ceilings have been increased which won't help. Once I find out about the energy rating I'll post the details. Re: Building an Aegean230 with Mainvue. 190Oct 01, 2017 9:37 pm pEast I think u got double glazing in ur promo - which means at the most u may need to upgrade the insulation which may probably cost around 1000 to 1500 - hopefully The double glazing promo saved us a fair bit of $$$. Just like Aegean430 said, if we need to upgrade the insulation that's only a positive on the house. Re: Building an Aegean230 with Mainvue. 191Oct 03, 2017 2:05 pm Hi firsttime What was the soil type that you had in soil report. I have got H1 and foundation going 1 metre thx follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building an Aegean230 with Mainvue. 192Oct 03, 2017 4:30 pm firsttime_homies1401 pEast I think u got double glazing in ur promo - which means at the most u may need to upgrade the insulation which may probably cost around 1000 to 1500 - hopefully The double glazing promo saved us a fair bit of $$$. Just like Aegean430 said, if we need to upgrade the insulation that's only a positive on the house. Sorry first Just checked your Elliston post and u mentioned soil type as M. I am just awaiting anxiously for site cost with 200mm fill and soil H1 follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building an Aegean230 with Mainvue. 193Oct 03, 2017 4:49 pm WOOHOO!!!! Wont be long now!! Will be good to see it all go up!! I will be seeing it every day as I drive past towards ours! Re: Building an Aegean230 with Mainvue. 194Oct 06, 2017 9:20 am Rachael13 It should only be a couple of weeks now - so exciting. Did you go ok with Energy rating? We got the energy back yesterday and we've had to double glaze both our alfresco doors at a cost of $1200. On a good note, henley upgraded our floor/ceiling and garage insulation at no cost. The provision they allocated was $3500 so we've got quite a bit back. Re: Building an Aegean230 with Mainvue. 195Oct 06, 2017 9:28 am firsttime_homies1401 Rachael13 It should only be a couple of weeks now - so exciting. Did you go ok with Energy rating? We got the energy back yesterday and we've had to double glaze both our alfresco doors at a cost of $1200. On a good note, henley upgraded our floor/ceiling and garage insulation at no cost. The provision they allocated was $3500 so we've got quite a bit back. That was good follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building an Aegean230 with Mainvue. 196Oct 06, 2017 2:59 pm firsttime_homies1401 Rachael13 It should only be a couple of weeks now - so exciting. Did you go ok with Energy rating? We got the energy back yesterday and we've had to double glaze both our alfresco doors at a cost of $1200. On a good note, henley upgraded our floor/ceiling and garage insulation at no cost. The provision they allocated was $3500 so we've got quite a bit back. That's brilliant pricing for the alfresco - we were slugged $2319 for ours but also had some of our insulation upgraded at no additional cost. So from here they will re-check all of your drawings and Cosham selections, if there are no issues, they will send your docs to estimating and then over to constructions. You're nearly there. YAY!!!! Re: Building an Aegean230 with Mainvue. 198Oct 16, 2017 10:46 pm SAFA1 Following your thread with a lot of interest. Glad it’s going so well!! Am a little jealous of your progress.... We're just waiting for the building permits and for ordering to do their thing than off to construction. Can't wait to see this house actually take shape instead of looking at photos. Re: Building an Aegean230 with Mainvue. 199Oct 28, 2017 5:55 pm Our taps lasted a month and someone stole taps in our estate from about 6 lots just today follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building an Aegean230 with Mainvue. 200Oct 29, 2017 7:27 pm Touch wood they stay there. The fact our block is at the main entrance and there's a lot off foot and vehicle traffic hopefully that deters these thieving a$$h0les. We got an email saying that our SS couldn't find 2 x pegs. Got the shovel out and found them. That's $900 less the builder will be getting from us. Thanks for your reply. I will just wait and see I guess. Trying to get some more information from our builder. 9 30235 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110523 |
