Browse Forums Building A New House 1 Aug 28, 2016 10:04 pm Hi all, we bought a block of land in the foothills of Adelaide several months ago and are seeking some feedback from anyone who might be able to help out. The land development was surveyed and set out earlier in the year, with roads/footpaths and other associated infrastructure installed shortly after that. Just before the land was released for sale, we noticed an area almost directly in the middle of out allotment that had been pegged-out with several star droppers and had orange bunting flags roping it off. The rest of the allotment was just dirt but the area within the flagged-off area was green grass. Soon after the bunting was removed but the star droppers remained. When I queried it with the development company I was told it was a "Temporary Survey Marker" and was nothing to worry about. My concern was that there were no other similar areas on any of the other surrounding blocks, and it appeared there was a borehole drilled in the middle of the grassy area, with the ground quite soft under foot. I've attached a couple of pics, can anyone offer any suggestions as to what this might be? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Survey Marker or something else?? 2Aug 28, 2016 10:21 pm It is not unusual when setting out roads and sewers to fix a survey marker on the site. It is important this is not disturbed so temporary fencing is erected around it to keep construction equipment away. Consequently it is the only undisturbed ground on the site. This means you can probably see the original ground, complete with grass. I suspect the borehole would be a trial borehole as part of the developers site investigation. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Survey Marker or something else?? 3Aug 29, 2016 7:23 pm Not sure if it helps is anyway but did you get the survey reports for your street? It might have something marked on there, like a reference survey mark or something like that? I'm just looking at our street initial survey plan and taking a guess we aren't far from you, I recognise those foothills! Re: Survey Marker or something else?? 4Nov 06, 2016 7:34 pm hey bpglendale,, we drove pass your block today..your water meter has been installed, your development approval should have been granted!! ??? Build thread - viewtopic.php?f=31&t=83484 Our Glendale 39, SA A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223606 I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 15275 Hi Everyone I learned something this week that I thought would be worth sharing. In NSW a lot of developers of subdivisions put covenants on the land which normally… 0 6549 |
